Question about Cell Phones
WIRE WHICH GOES AROUND EAR OF BLUETOOTH CRACKED. HOW CAN IT BE REPAIRED?
    Brigadier General:
  • 7,752 Answers
Not really...you will need to purchased a new one
Posted on Dec 01, 2008
Step by step on how to setup bluetooth for an MSI CX600
Buy a usb adapter that you plug into the usb port from Tiger Direct. it comes with software, drivers and instructions. The adapter only costs $12.99 You can also buy a bluetooth headseat that goes around your ear if you don't have one. When the site comes up just type: USB Bluetooth Adapter or USB Bluetooth Headset in the white search box at the top of the web page then click GO. When the results are returned sort them by Price Low to High.
http://www.tigerdirect.com
I like the usb bluetooth adapter below.
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=1824464&CatId=909
May 16, 2012 | MSI T4300 (CX600-063US) PC Notebook
The rubber part that goes in your ear has fallen apart but the rest of the 330 works perfectly. Need new earpiece.
I'm sorry, Plantronics does not offer a replacement ear tip for the 330 headset. I will include the link to a webpage for Bluetooth headsets below.
Plantronics Bluetooth Headsets
Good luck from Headsets Direct!
Feb 13, 2011 | Plantronics Explorer 330 Headset
The left and right ear bud work some times. and if i turn the base were you plug it into the device it coukd work how can i fix it so they can both work at the same time.
Probably can't. What typically happens is that the base of the wire gets stressed from wrapping the cord around you media player and it eventually breaks the copper wire inside of the insulation. You likely can not even see the damage, let alone repair it. Be more carefull with the next set, and might I recommend a set of AKG ear buds. I use AKG studio headphones and bought my little sister some AKG ear buds, very impressive quality very close to my studio headphones. AKG K 313
Oct 29, 2010 | Skull Candy LINK Earbuds Consumer...
H12 bluetooth will not charge
As the headset is repeatedly charged, the pins on the charger starts to not reach the blue tooth ear piece to charge. I clean the dust around the edges on the contact area and was able to get it to charge
Feb 09, 2009 | Motorola Mobility Motopure H12 Bluetooth...
Instruction on how to wear plantronics 925 bluetooth
The round portion that has the smaller hole in the center, with the small extension, goes into your ear. The squarish loop then needs to be rotated to out, so that it is "hooked" into the curve of your ear. Try different sizes to get the right fit of the loop (the bodies are identical).
Jan 30, 2009 | Plantronics Discovery 925 Bluetooth...
How do I install a new ear wire piece for HBM 730?
The ear wire simply slides out of the hole on the swivel barrell.  Where can I get a replacement ear wire is what I want to know, mine broke.
Jan 18, 2009 | LG HBM 730 Bluetooth Headset Wireless...
Have 3 jabra bt 135 earpieces and the earhook is broken snappede on all 3 where can i get replacements
Same thing happened to me. For about $5, I went to Home Depot and bought 24 gauge wire (about 5") and a pack of black heat-shrink plastic sleaves (1/8th inch or 3/16) from the electrical department. The 24g wire fits perfectly through the rubber slot after you pull out the broken ear hook. Use a pair of pliars to bend the wire to shape your ear (use the broken jabra ear hook as a template). Once you have the right shape and have filed down the sharp edges, slip the heat-shrink plastic sleave over the wire, making sure you leave the end piece that goes into the slot of the headset as bare metal. Use a hair-drier on high-heat to shrink the black plastic. Mine has worked perfectly for over a year and actualy fits better than the original.
Dec 08, 2008 | Jabra Bluetooth Headset with Adjustable...
Cell Phones Logo
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
