Question about HP Color LaserJet 2550n printer + HP Color Training and extended warranty ;U4929E, Next-Day exhange...
Blinking yellow light
Hello
I ahv e a blinking yellow light with a triangle icon next to it.
Cant print with card stock,bt plain paper ok.
This is a hp laserjet P2015
Thanks Margaret
    Problem Solver:
  • 6 Answers
That light indicates a problem with the media/paper. Based on your saying it prints fine with plain paper, but not on card stock, the most likely reason is the card stock is to heavy for the printer. In the Owners Manual (page 21) HP specifies paper from16-47 lbs. If your card stock is heavier, it does will not feed properly and the printer treats it as a jam.
Try a lighter stock and see whether that works. Also, it's best to use the multi-purpose tray for heavier paper and envelopes; the add-on trays really should only be used for plain paper.
Posted on Jul 24, 2009
    Novelist:
  • 102 Answers
I m not sure what the specification of the paper type you are using however if you are using card stock than you should use manual feed Tray and in the printer driver properties you should select paper type as Card-Stock to make sure there is no print quality issue.
Posted on Jul 03, 2009
4 Suggested Answers
  • 17 Answers
SOURCE: Model : HP LaserJet 1320
Hi, If that is the only light on (blinking or not), then you probably have a paper jam or a door open somewhere on the printer. Make sure both doors are closed securely at the back of the printer. Make sure that the toner cartridge is secured inside the printer. You not only have to just insert it, but you have to insert it until you can feel it lock into place. Make sure there is no paper jammed inside the printer or inside the rear doors. If you have a blinking light AND the power light is ON, press the GO button. This is also a sign that a complex print job was sent that max'd out the installed memory. Hope this helps!
Posted on Feb 15, 2007
Nikhil Gedam
  • 87 Answers
SOURCE: Printing problem with HP Laserjet P2015 printer
This can be an issue with one of the faulty sensor across the printer.
Please check if you are able to print from tray 1, e.g. a configuration page.
A config page can be printed by holding the Green Button and releasing it as soon as the Triangle light comes on. This would take approx 5 secs.
If the printer is able to print from tray 1, then it could be an issue with the tray 2 pickup sensor.
Check if the tray 2 pickup sensor ( a black plastic piece to the right of the tray 2 pickup roller) is moving freely (front and back), also check if tray 2 pickup roller is not able to rotate completely.
If the tray 2 sensor is not moving freely and of the pickup roller is rotating completely, then reseat the pickup roller.
Normal use with good media causes wear resulting in the need to periodically clean or replace the pickup roller. Additionally, the use of poor media might require more frequent replacement of the pickup roller. Replacing the pickup roller Complete the following to replace the pickup roller:
CAUTION: Failure to complete this procedure might damage the printer. Unplug the power cord from the printer, and allow the printer to cool.
Figure 1: Unplugging the power cord
mma01_13245_0
2. Open the print cartridge door, and remove the print cartridge.
Figure 2: Removing the print cartridge
mma01_13246_0
3. Remove the main input tray (Tray 2).
Figure 3: Removing the main input tray (tray 2)
mma01_13247_0
4. Open the front automatic two-sided path door (HP LaserJet 1320 series printer only).
Figure 4: Opening automatic two-sided path door
mma01_13248_0
5.Place the printer on the work surface with the front of the printer facing up.
Figure 5: Placement of printer
mma01_13249_0
6. Pull the white tabs outward, and rotate the tabs up.
Figure 6: White tabs
mma01_13250_0
7. Slide the right tab to the right, and leave the tab in this position throughout the procedure.
Figure 7: Right tab movement
mma01_13251_0
8. Slide the pickup roller assembly to the right, and remove the left end cap.
Figure 8: Pickup roller assembly movement
mma01_13252_0
9. Remove the pickup roller.
Figure 9: Pickup roller
mma01_13253_0
10. Insert the left side of the new pickup roller into the left slot (1), and insert the right side (with notches in the shaft) into the right slot (2).
mma01_13254_0
11. Rotate the shaft until the notches engage and the shaft clicks into place. 12.Place the end cap over the shaft on the left side, push the end cap to the right, and rotate the tab downward into position.
Figure 11: Pickup roller end cap
mma01_13255_0
13.Push the right tab to the left, and rotate the tab downward into position. 14.Place the printer on the work surface with the top of the printer facing up. 15.Close the front automatic two-sided path door.
Figure 12: Closed automatic two-sided path door
mma01_13256_0
16.Reinstall the print cartridge, and close the print cartridge door.
Figure 13: Print cartridge
mma01_13257_0
17.Plug the printer in to turn it back on.
Figure 14: Power cord in
mma01_13258_0
Cleaning the pickup roller
Perform the following to clean the pickup roller.
1.Remove the pickup roller as described in steps 1 through 9 of Replacing the pickup roller above.
2. Dab a lint-free cloth in water, and scrub the roller.
mma01_13259_0
Figure 15: Scrubbing the roller
3. Using a dry, lint-free cloth, wipe the pickup roller to remove loosened dirt. Figure 16: Wiping the pickup roller
mma01_13260_0
4. Allow the pickup roller to dry completely before you reinstall it in the printer (see steps 10 through 17 of Section with a task ).
mma01_13261_0
Figure 17: Reinstalling the pickup roller
Posted on Nov 03, 2008
SOURCE: HP Laserjet 1300 yellow light STILL flashing
Re-installing the print driver will not solve a flashing light. If the printer is functionally ok, it will come to ready simply by plugging into the wall. It sounds to me like a fatal error at this point.....could be a long list of things, but I would lean towards a formatter board. bottom line with this printer at this point in it's life is, if it doesn't work, it's not worth fixing. Replaceable for about $100.
Posted on Mar 17, 2009
Hp color laser jet cp4025 blinking yellow light
Yellow toner is getting low, or check to make sure your print driver is set correctly for this printer.
Mar 22, 2013 | HEWLETT PACKARD - LASER JETS New - Hp...
HP 3015 stopped scanning. It still prints, and goes through motions of scanning, but page is blank
HELLO
First of all,
Isolate to a wall outlet and not a strip.
Remove the cartridges.
Remove the power plug and then reconnect.
Reinstal the cartridges.
Try to do a copy direct from the unit.
NEXT
Print a self test page and check for Yellow or Magenta to rule out a partially empty cartridge.
  1. Load plain white paper in the input tray.
  2. Touch the ATM button (c01671671.gif ) next to the Setup icon (c01629002.gif ) in the lower-left corner of the control panel.
  3. Touch the right arrow button (c01185072.jpg ) to select Tools , and then touch OK .
  4. Touch the right arrow button (c01185072.jpg ) to select Printer Status Report , and then touch OK .
Dec 27, 2012 | HP LaserJet 3015 All-In-One Printer
MY PRINTER P2015 IS JUST BRINGING OUT PLAIN PAPER WHEN ASKED TO PRINT AND THERE IS TONER IN IT
This sounds like the tab on the cartridge that opens the shutter on the laser assembly is broken. Do you have another cartridge you can try in the printer?
Mar 31, 2011 | HP LaserJet P2015 Printer
Light with the triangle flashing - printer stopped
That means ATTENTION, you are either out of toner or have a paper jam.
Feb 18, 2010 | HP LaserJet P2015 Printer
Printer streaks on card stock
adjust your thickness guage as card stock is 3 or 4 times thicker than a 20lb plain paper stock. Here is link to a helpful media guide for HP printers.
http://bizsupport2.austin.hp.com/bc/docs/support/SupportManual/bpl05339/bpl05339.pdf
Jan 30, 2010 | HP Color LaserJet 2600n Printer
Hp desktop 1320 printer has yellow light on - it the icon symbol
The symbol for toner low is a box, without a top, with an arrow made of dots pointing up. Insert an new print cartriage.
Nov 12, 2008 | HP LaserJet 1320 Printer
Yellow light is blinking
I ahve the same problem and HP is absolutely NO HELP!! I'm ready to trash a printer that has hardly ever been used.
Sep 14, 2008 | HP LaserJet 1320 Printer
HP 2600 ghosting
It is a massive pain but a solution that worked for me is to run a 'clean' after every card stock sheet. I know it's wicked awful but it actually worked and I had to run 100 times (one for each good color card stock)
First put plain paper in tray 2
Next
Hit left arrow until you get to 'system service' and press green check
Next
then go to 'clean' and press check
Now it should print a clean image without ghosting
May 29, 2008 | HP Color LaserJet 2600n Printer
252 people viewed this question
Seeker5211
Seeker5211
