Question about SMC EZ Connect g SMC2862W-G 802.11g/b Wireless Adapter
Software malfunction For a year, this software worked fine. Now, alghough the SMC software detects my wireless network, it can't figure out a way to connect. Also, often the SMC adapter software will open for a split second and then disappear. Very frustrating, I've spent a good two hours with SMC support people trying to trouble shoot this, and they suggested it might be something with my wireless router, but just the other day, a friend was able to connect to the internet in my place with no problem... so it seems there some bug in the SMC software... Thanks for your help.
  • aldo hndz Mar 25, 2008
    I have the same problem and I lost the driver cd
I also have similar problem. It would occasionally disconnect randomly showing 'limited connection' or 'malfunction usb detection' message. After that happened, I'm offline until I restart the computer. Heck, my pc froze some time when I try to mess with it in device manager, and the instant I pull the smc usb out, my pc resumes normally. It also gave me a blue screen (code bf) at one time. I'm using window vista by the way, so that might be the problem
Posted on Mar 26, 2008
    President:
  • 2,961 Answers
I assume they told you to uninstall the software, remove the adapter, then re install driver an re insert adapter, as this normally cures the driver fault. If they didn't try that, if the problem persists the adapter may be faulty although i think it's a software problem. Try not to use Windows to repair connection as it never works and resets your pc's ip address differently than your routers already given it.
Posted on Jan 24, 2007
How do you download the usb to ethernet adapter software?
Here is the SMC driver website. You can search for the model number. Or, they also have a link to old products if yours is old enough.
SMC
Sep 02, 2014 | SMC USB to Ethernet 10/100 Mbps Network...
Smc 802.11g adapter doesnt show in wlan utility
update the wireless drivers for your network card. also check the spec sheet for your wireless card and make sure it's compatable with your OS and system.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_d799f810c7212a78
May 01, 2014 | SMC EZ Connect g SMC2862W-G 802.11g/b...
Hi I have an SMC baracade g wireless router and want to connect my samsung galaxy 580 phone to it wirelessly. My computer connection is working. The phone detects it fine and can see that it has WPA/WPA2...
Hi
Try to unplug the power cable of your router for a minute or 2 to re-establish its connection to server. Then try reconnecting to your home network.
Hope this helps
Dec 09, 2010 | SMC Barricade 7004VWBR Wireless Router
Ethernet connection has just stopped working. 80072ee7 error. However, device manager says adapter working properly, orange green lights working/flashing. cable checked to another comptuer without...
Try going into the control panel and then into the device manager. Find the ethernet device and remove it. Then re-boot the computer and the OS should re-detect the card and re-install the drivers. Hopefully this will get the card working again. Let me know if this helps.
Nov 18, 2009 | SMC Realtek 10/100TX PCI Fast Ethernet...
Cant connect my SMC to other home computer and have a netgear router, how do i connect my smc adapter
Most hardware like an Network Adaptor you install the software CD 1st. Then plug in the hardware.
Then if you configured wireless (wifi, 802.11) settings on your SMC - you should fine the network NAME when you try to connect. You will be asked for the security key for WEP or WPA or WPA2 that you used in the SMC.
SMC should... then assign IP Settings automatically. If the SMC has Internet, you should have Internet.
Jul 07, 2009 | SMC EZ Connect g SMC2862W-G 802.11g/b...
SMC Barricade wireless router needs to be reset constantly
Maybe it is an electricity problem, or it's nearing the end of it's life. I bought 2 routers till now.each one worked fine for 2 years and then never worked.You should buy a new one or check if there's something with the electricity . Maybe a higher voltage
Feb 18, 2009 | SMC (SMCWBR14-G2) Router
SMC EZ Connect 2862W-G does not see Linksys network
It shows that your wireless router and wireless adapters are both working. One thing to try is changing your wireless channel. Since you are already using 11, try maybe 1 or 9. Check if your SMC adapter will pick up the wireless signal.
By the way, how far is your computer (using the SMC adapter) to your wireless router?
Oct 21, 2008 | SMC EZ Connect g SMC2862W-G 802.11g/b...
PS3 and Laptop issues
the new unit you have is the PS3 is not compatible to the SMC barricade router that you had,, you must find a compatible just only for the PS3 unit,, you can ask from authorization wer you bought it!!
Dec 04, 2007 | SMC Barricade g SMC2804WBR Wireless Router
SMC signal suddenly extremely weak
login with ur router and change the channels>and use channel 11>1 and check with antena weather its straight looking the roof>and if its not works down grade or upgrade firm ware or use with out any security like wap or wep rate me solved if its help full thx
Oct 31, 2007 | SMC (SMC7004AWBR) Router
SMC EZ Connect g SMC2862W-G 802.11g/b Wireless Adapter Logo
282 people viewed this question
Top SMC Computers & Internet Experts
Prashant M
Prashant M
J John
Mark Gough
Are you a SMC Computer and Internet Expert? Answer questions, earn points and help others
