Question about Aprilaire 700 Humidifier
Wiring an Aprilaire 700 M humidifier.
I need detailed wiring diagram so that a novice can do it.
  • Anonymous Dec 05, 2008
    need a diagram!
  • bernbry Dec 05, 2008
    I wired my Aprilaire correctly (I thought) and now the humidifier runs until the heat comes on and then it turns off. It is hooked into an electric Rheem furnace. Any suggestions!
3 Suggested Answers
  • 3 Answers
SOURCE: Aprilaire 550 humidifier
Did you clean the orfice ? It is located on bottom of solenoid. It is plastic with a very small hole.The hole gets plugged and you can clean it or buy a nw one for 50 cents.
Posted on Nov 12, 2008
SOURCE: What should my humidifier be set at for the winter?
Hi, Jennifer:
I'm no expert, but those who are seem to agree that the first thing to check is your evaporator panel. Aprilaire recommends replacing it annually--so if you haven't replaced it recently, that would be the first step to take. Next, check the power supply to your Aprilaire unit. Turn the humidistat to 0%, and then turn it slowly back toward 35% until you hear a click at the unit. If you don't hear a click, you'll want to check that the unit is in fact getting electric power (you may want to get an electrician or furnace tech to do this). If you do hear the click, the next thing to check is whether you have sufficient water flow to your Aprilaire unit. On mine, I had to adjust my water supply saddle valve, as well as the inline valve on the discharge side of the solenoid (see prior post from this morning)--and this seemed to clear the lines and restore water flow. Once you achieve proper water flow, you will probably want to set your humidistat at 35% for winter temps of around 20 degrees F--but be sure to adjust it downward for colder weather. Comments, anyone?
Posted on Dec 15, 2008
No "C" on furnace power strip for humidifier power "C"
Hello, since this humidifier has a transformer installed with it, you bring one wire from humidifier to Humidistat and then a wire from humidistat to Transformer. You will need a current sensing relay to turn the humidifier on and off with the Furnace cycle. I will attach a link for a wiring diagram for your Humidifier
Nov 15, 2012 | Aprilaire 700 Humidifier
Aprilaire 700. It works on fan on mode but not otherwise. It's never on and the humidity reading is always way below the setting. It should turn on automatically to bring the humidity up, right?
It appears your Aprilaire model 700 is wired to only operate when your HVAC fan is operated by your thermostat. Your HVAC installer can wire the humidifier control to operate the humidifier during a heat call, fan call or to turn on the fan when there is a need for humidification. Please contact your HVAC installer to have them change the wiring.
Thank you for giving us the opportunity to be of service
Brad Uselmann
Technical Support
Research Products Corporation
Nov 01, 2010 | Aprilaire 700 Humidifier
Aprilaire 700 only works in test mode.
connect two wires at humidifier without any wirng connected if works problem is in wiring or humidistat
Oct 28, 2009 | Aprilaire 700 Humidifier
Water is leaking out of it
purchase a maintenance kit from aprilaire. this needs to be done annually.
Oct 13, 2009 | Aprilaire 700 Humidifier
Aprilaire 700 Humidifier not working. Can it be repaired?
turn the humidistat back up, aand make sure if is still wired up.
Jan 18, 2009 | Aprilaire 700 Humidifier
Aprilaire 700 Humidifier Doesn't work
check this website for a wiring diaghram Aprilaire 700 Repair Parts & Supplies
Dec 07, 2008 | Aprilaire 700 Humidifier
Model 760 Humidifier - need wireing diagram please....
I logged on to the April Aire website and found the wire diagram i needed.
they have really good information on all their units.
Aug 18, 2008 | Aprilaire 700 Humidifier
Humidifier control .
if humidifier was wired into thermostat circuit for power instead of seperate transformer , this can happen. you need to see if you voltage going to the solenoid valve. if you do , and it isn't opening, the valve is bad . this is assuming that it is using a # 50 relay to come on only when the fan runs . . make sure the water valve is open
Dec 24, 2007 | Aprilaire 700 Humidifier
Aprilaire 700
white wire on fan motor ( neutral ) is placed under clamp on relay , one yellow wire on relay goes to one wire on the solenoid valve , other yellow wire goes to the humidistat
Dec 13, 2007 | Aprilaire 700 Humidifier
Aprilaire 700 Humidifier Logo
1,115 people viewed this question
Top Aprilaire Humidifiers Experts
Paul Carew
Mack Baxter
Are you an Aprilaire Humidifier Expert? Answer questions, earn points and help others
