Server not found error in IE and FF - Computers & Internet
  • pklinuxguru
    pklinuxguru May 11, 2010
    Sounds like an internet connection problem. Do you have internet via cable, satellite, or DSL? They each have hardware that can cause that problem. Check to make sure all the parts of your network (DSL/Cable modem, router, network cables, network card, etc) are working and plugged into each other. There are normally lights showing status and such on the router and modem. Sometimes the network card will also have one (in the back of your computer). Lastly, have any electrical storms lately? That will sometimes mess up any piece of your system. Use a surge protector or a UPS if you can afford it.
    President:
  • 2,110 Answers
First check your network is connected or not..
Posted on Dec 01, 2008
How do you do a factory or hard reset?
Sounds like a faulty bluetooth card or main board.
May 22, 2014 | Datamax-ONeil microFlash 4te Direct...
Dear Sir; please give me soluion this problem. Locating HWK Upgrade server... HWK Upgrade server found! Preparing connection to server... Connecting to HWKUpgrade server... Server...
Dear Sir; please give me soluion this problem. Locating HWK Upgrade server... HWK Upgrade server found! Preparing connection to server... Connecting to HWKUpgrade server... Server connection successfully established. Authenticating on server... Authentication stage error: Error: Server returned unrecognized reply
Sep 01, 2011 | Lantronix CoBox-FL-IAP (COBOXFLIAP11)...
Upgrade log: ---------- HWK Update Client v 2.1.0.0 ---------- ---------- HWK upgrade started:6/11/2011 7:02:40 AM ---------- -- Target Id : 62 CF 1 10 -- UFSx Boot : UFxBoot V2.2 (c) SarasSoft...
Upgrade log:
---------- HWK Update Client v 2.2.0.0 ----------
---------- HWK upgrade started:8/1/2013 6:34:25 PM ----------
-- UFSx Boot : UFxBoot V2.2 (c) SarasSoft 2003.
-- UFSx Firmw.: UFS_USB V2.8 (c) SarasSoft 2007.
-- UFSx S/N : 56512
-- Features : 00000001
-- Licence 5 : True
-- UFSx Vendor: TORNADO
-- HWK ID : A1.04-PRO1-DA0064A542600069
-- HWK Status : 1, DL: 0
Jun 11, 2011 | Lantronix CoBox-FL-IAP (COBOXFLIAP11)...
My LG display is reading ER FF what does this mean and what can I do to fix it?
Error Code Er FF
This code is not to be confused with the O FF or demo mode error message. The "Er FF" error code indicates a problem with the unit's freezer fan. The freezer fan controls the temperature in the freezer. The source of this error is most likely ice buildup. As with the Er IF error, allowing the unit to thaw should resolve the issue. Contact customer service if the error code continues to be displayed after having thawed the unit.
Hope helps.
Apr 03, 2011 | Refrigerators
Not working YM and IE also
Open IE browser Click Tools> Internet Options> Connections> LAN Settings > check if there is any proxy or IP with port mentioned in the Box Proxy Server.....[Use proxy server for you LAN]...
Unselect the box.....If Firefox is working try open the web messy.... http://webmessenger.yahoo.com try here...if it doesn't work contact your network vendor or ISP....Good Luck
Sep 14, 2009 | Yahoo Messenger
16 bit error while using turbo c graphics...........
Try running Turbo C with administrative priviliges and running it as Windows XP SP2 if you have Vista. Seems to work for me.
Aug 04, 2009 | AMD Sempron LE-1300, 2.3 GHz...
Sound
the potential cause for this is that if you load up IE or FF with the headset plugged in, IE/FF will load up the sound via the USB, but if you remove the headset, IE/FF is still trying to relay your sound though the USB and not the speakers. This is not a design flaw with the headset but rather with windows. This happens to me with every program that uses sound. And also to note that even though you plug the headset back in, it has a good chance of loading onto a different address then what was used by IE/FF initially. You can see how this works also by leaving your headset plugged in, with IE or FF open (so that the sound is through the headset) then go into your control panel > sound options, and under the playback tab select your speakers rather then the headset. you will see that you lose your sound until you restart IE/FF.
May 20, 2009 | Logitech ClearChat Pro USB Headset
Computers & Internet Logo
158 people viewed this question
David Payne
David Payne
