Question about Bosch SHU9915UC Dishwasher
Bosch shu 9915uc drain pump removal
How do I get the drain pump out? I have released the plastic tabs holding it in, and pulled onit. It comes half-way out, but not much further. Am I just not applying enough strentgh or does it turn somehow.
My sense is the impeller felt on the inside of the bottom of the basis should pull out somehow witht he pump. Am I wrong? Don't want to break this.
Thanks
First you have to unbolted the base part from the tank(4 bolt on the bottom part)....then you gonna be abble to flip the tank whit the door forward and the base part gonna stay on the ground ,showing you all the component you want to get to and have the space to work your way out .. ....after the pump and the tubulure part connect togetter by turning and pulling all that whit the impeller and the motor assembly staying togetter but release from the tubulure drain parts ....and thats it ! you have your motor pump in your hand and you can now proceed to a test whit 120 volt to see if its realy the pump that grounded ...hope this is gonna help you ! mikey mecano
Posted on Mar 01, 2009
My LG is a few years old, Model WM1832CW and seems to work in all modes except rinse. It just started this morning and sounds like its slipping and grinding and won't pump the water out. any suggestions....
Replace the pump motor. On your model, it can be done without removing the front panel. Open access door at bottom left of front panel. drain water out small hose. remove screw from plastic recess and use putty knife at side of recess to remove plastic recess. remove screw holding pump. pull machine out 2 feet from wall and tilt it back to rest back edge against wall. depress plastic tab in base to release pump. remove hoses and unplug electrical connection to pump. remove 3 screws holding pump motor to pump housing. install new pump motor and re-assemble.
Nov 27, 2010 | LG WM-1832C Front Load Washer
Impeller is going bad. What will cost to fix on a Bosch shu 9990
Hello there
Normally you will want to get the impeller kit for this it will include the seal for the impeller
Drain & Wash Impeller Kit - Comes with drain & wash impeller, pump seal, chopper, gaskets, screw and instruction sheet.
Part Number: AP3115180
Our Price: $29.00
this is a quote from parts select.com
and is usually a fairly normal price
ok hope this is very helpful for you
Best regards Mike
Jan 06, 2010 | Bosch 23 in. SHU 8805 Built-in Dishwasher
Siemens hydro sensor dishwasher not draining
sounds like a drain pump ... you may have a damaged drain pump or something stuck in it.. turn off the power the the dishwasher... .remove toe panel and you can see the drain pump on the left ..you can remove plastic hose on the left to drain the dishwasher ...be sure to catch the water will come out ... you can remove drain pump press release tab and turning drain pump ...hope it helps
Sep 19, 2009 | Siemens 24 in. SE53200 Built-In Dishwasher
Our Bosch SHU 4300 dishwasher does not drain fully
There is a recall on the control board of many of these models, butyour problem is likely not related. A sticking impeller indicates that the pump may be failing, but you are welcome to try my guide to help. It is here. Thanks!
Jun 15, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
What is an OE error
I would guess that the impeller has come off the pump motor shaft. You can disassemble and push it back on, but it will come off again. I don't know if some type of adhesive would work, but I just replace the pump motor.
Drain water from small drain hose (or by removing filter) Remove the screw in the plastic recess by the filter, then use a putty knife on the left or right side to pop out the recess. Remove two more screws holding pump body to front frame of washer. Pull washer about 18 inches away from wall and tilt it back to lean against wall. You can reach through the large hole in the bottom of the washer base to access the pump. There is a plastic locking tab holding the pump body to the plastic washer base, but don't worry if you break that, as the screws (removed earlier) will hold the pump back on just fine. Pump motor is held onto pump body with three more screws. Replace pump motor with a new one and reassemble. On a difficulty scale of 1 -10, this one might rate a 5.5 or a 6.
Apr 16, 2009 | LG WM-1832C Front Load Washer
DE error code
Drain water from small drain hose (or by removing filter) Remove the screw in the plastic recess by the filter, then use a putty knife on the left or right side to pop out the recess. Remove two more screws holding pump body to front frame of washer. Pull washer about 18 inches away from wall and tilt it back to lean against wall. There is a plastic locking tab holding the pump body to the plastic washer base, but don't worry if you break that, as the screws (removed earlier) will hold the pump back on just fine. Pump motor is held onto pump body with three more screws. Replace pump motor with a new one and reassemble. On a difficulty scale of 1 -10, this one might rate a 4.5 or a 5. Not too bad.
Mar 28, 2009 | LG WM2277HBW XL Front Load Stackable...
Wont drain
Drain water from small drain hose (or by removing filter) Remove the screw in the plastic recess by the filter, then use a putty knife on the left or right side to pop out the recess. Remove two more screws holding pump body to front frame of washer. Pull washer about 18 inches away from wall and tilt it back to lean against wall. There is a plastic locking tab holding the pump body to the plastic washer base, but don't worry if you break that, as the screws (removed earlier) will hold the pump back on just fine. Pump motor is held onto pump body with three more screws. Replace pump motor with a new one and reassemble. On a difficulty scale of 1 -10, this one might rate a 3.5 or a 4. Not too bad.
Mar 16, 2009 | LG WM2496H Front Load
Bosch SHU9925UC Dishwasher Stuck in Initial Drain Cycle
OK Bosch Dw fans.........here is the fix if your SHX dishwasher is stuck on the drain cycle. This may save you a couple hundred bucks.......so listen up. There is a tendency for the very small float switch to STICK in the ON position, which will cause the drain motor to continuously run......and DISallow any other function to work. DISCONNECT POWER. Did I mention to disconnect power? Take off the front base cover....2 torx screws. Remove the other 2 torx screws in the metal clips that fasten the top of the DW to the underside of your countertop. NOW...carefull slide your DW out. You may have to disconnect your water and elec supply if you do not have enough slack to pull it out. Once the DW is out of the cabinet, remove the shiny metal cover on the LEFT side by removing a single torx screw. You will now see a small plastic assembly with a red plastic piece that moves up and down as it rides on a small red styrofoam float. This up and down movement engages a small white plastic switch visible with 3 wires coming out of it. You can carefully UNSNAP this switch out of its mount, and pull the 3 wire plug off of it. THere is a small square blue plastic tab that is supposed to easily slide in and out of the switch. If it is stuck IN, you can sometimes tap the switch and the blue tab will pop out, which is what it is supposed to do without tapping it. You can carefully with a knife blade separate the case on this switch and note the way it comes apart. Clean out any micro debris out of the small channels that the blue tab ride up and down in. Then set it in the channel while holding up the small switch tab that rides on it and see if it slides up and down without sticking! I like to take a piece of wax paper and rub in on the channel and blue tap to provide some lube for the switch to slide easily on. Now, put the switch back on and manually move the red plastic assembly up and down while you are watching the blue tab. The tab should ride up and down with the red assy. If not, buy a new switch. Google the # on the switch and order one. If the tab slides up and down, put things together in reverse order and give it a try. Hope it works for you. This should take you an hour give or take. Take the $200 you just saved and have a night out on me. ........so even though these German Appliances have a good name because of past reliability, the american tendency to value engineer them with plastic parts to reduce costs and increase profit.........just cost you an hour of your time. Will we ever learn.? ......if it ain't broke, value engineer it until it only lasts through the warranty period so you can then collect service and parts blood money from your fellow american.
Apr 09, 2008 | Bosch 23 in. SHU 8805 Built-in Dishwasher
Bosch shu9905
Check the drain pump. First, manually initiate drain by pressing the second and fourth buttons on the keypad at the same time. If it pumps out, disregard the rest. If it doesn't at least hum, check for power at the motor.
Remove lower rack, lower spray arm, and screens in bottom, remove all water inside. Check for debris under pump cover in bottom of sump. The drain pump suction is through the hole on the left.
Behind the toe panel on the left is the drain motor, If no debris was found inside, the drain pump may have failed. Remove outer door panel (you may need to remove the two screws on the sides of the control panel.) Remove the metal panel across the top of the motor area , disconnect hose in front of pump, disconnect wires to pump, press tab at top of pump and rotate clockwise to remove pump. The impeller could be loose on the motor shaft, or the motor windings failed.
Mar 10, 2008 | Bosch 23 in. SHU 8805 Built-in Dishwasher
Bosch dishwaher shu 4322 uc/u12
remove outer door skin and kick plate at base pump will be on view turn off power look carefully at pump you will see a lever you have to cut away a small section of plastic on lever to be able to push it inwards pump then twists off anticlockwise is a bayonet fitting like a light bulb.
hope this helps
Jan 13, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Bosch SHU9915UC Dishwasher Logo
181 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
