Question about HP Pavilion dv6000z Notebook
Plugged in not charging
I plug it in to the wall socket (known to be good) and my laptop says "plugged in not charging"
  • 21 Answers
The problem could also be the power cord. A friend of mine was complaining her HP CQ60 wouldn't charge unless she jiggled the plug connection at the laptop. She thought it was the battery and ordered another one but found it was still not charging correctly. I looked at it and confirmed that the cord had one loose connection at the barrel plug.
If it is the power cord you could purchase a new one or repair it like I did below:
The cord can be fixed by slicing a concentric circle around the plug about a 1/2 inch down from the rubber end and then peeling it off to expose the two wires. I found one wire broken from the solder joint and thus not getting a good connection. I drilled a small hole into the metal barrel to make a better contact and then re-soldered the wire into the hole. I then super glued the concentric section I sliced off and then put a piece of 1/2" 2:1 heat shrink tubing ($1.25 on eBay) around it and shrank it around the repair. It's fixed and due to the black heat shrink tubing, you can barely tell it was repaired. Hope this helps!
Posted on Nov 09, 2011
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 144 Answers
You have a messed up power supplybuy a new one. or try one of a relatives
if its not the supply it's your MOBO -motherboard.
If it doesnt work open your laptop and check your dc input connectors
Posted on Dec 01, 2008
Is there a way to charge my 930 T on a wall socket AC adapter
The trouble with cheap chargers ' Mobile Fun Blog
www.mobilefun.com/blog/the-trouble-with-cheap-chargers/
Jul 10, 2012 - The abbreviation for amp is A. There are also milliamps which have the abbreviation mA. ... The other way around isn't as much of a problem. If you try tocharge an iPhone (1.1A) using an iPad charger (2.1A), ... micro USB cables can't tell the difference between a wall socket (AC power) and a USB port.
How USB charging works, or how to avoid blowing up your ...
www.extremetech.com > Computing
ExtremeTechAug 26, 2015 - If you take a smartphone which came with a 900mA wall charger, and plug it ... It turns out there's a method to all this madness - but first we have to ... A regular USB 1.0 or 2.0 socket has four pins, and a USB cable has four wires. ..... Last week I couldn't find my phone charger (wall plug), so I tried using ...
What wall plug chargers can be used to charge PS3 ...
gaming.stackexchange.com/.../what-wall-plug-chargers-can-be-used-to-c...
Jun 19, 2012 - I want to charge my PS3 controllers (SIXAXIS) without having the PS3... I have noticed there are (expensive) third party PS3 controller charger ... Why can'tthe normal wall plug chargers, that are able to charge way ... The PS3 controller won't charge when connected to any usb outlet (where only ...
Amazon.com: AC Adapter Wall Charger w/6'FT Power Cable ...
www.amazon.com/Adapter-ChargerCity-Manufacture...
Amazon.com, Inc.
Rating: 5 - ‎5 reviews
ChargerCity GPS AC Wall GPS USB Power Adapter Cable Accessories for ... XXL 550 540 535 530 GO 920 930 720 730 740 630 640 TOM TOM LIVE Traffic GPS ... I don't really have any need for the Micro SD Memory Card Writer so can't ... I now cancharge my TOMTOM from a wall socket instead of leaving it in my car.
Charging your Lumia 930 ' MyUCS
Jan 03, 2016 | Computers & Internet
Battery Icon reads. Plugged in but not charging. What's the fix?
Confirm that the charger is plugged into the electrical wall socket and the light on the charging unit is on. Ensura all connections are secure and not loose.
  1. If all is in order and the laptop is still not charging, the battery OR the charger may be defective.
  2. Shut off the computer.
  3. Remove the battery for 10 seconds
  4. Reinstall it.
  5. Try charging it with the charger again. If that works, good. If not, call customer support.
Aug 25, 2014 | Computers & Internet
My hp mini 1000 will not turn on. When I plug it in the light on the side will not say it is charging. It will not charge.
Here are some steps that can help you resolve the issue.
First, try removing the ac adapater and the battery and press and hold the power button for about 10-15 secs to remove the flea power. Then try to deattached the power cable and the power brick and attach it again properly, plug it to the computer without the battery and try to turn on the computer. If still the same problem try a good known power socket, if your using power strip try to plug it directly to the wall socket. If nothing works, try a good known ac adapter, or try you ac adapter to a good known working computer. If a good known ac adapter didnt work, contact HP as this is a power supply issue on the computer (power supply are mostly attached to motherboard for portables) contact HP to check your warranty and have it serviced. If the good known ac adapter works, contact HP to check the warranty and have the AC adapater replace or simply replace the ac adapter.
I hope this will be able to help you.
Thank you for choosing Fixya.
Mar 10, 2011 | HP Mini 1000 Netbook
My hp 6735s laptop battery not charging says pluged in but not charging only 1 year 6month old
r u getting the message when on AC power that the "smart AC adapter is not providing enough power" ?? If yes then remove the battery and c if the laptop works fine with just the adapter plugged in ...
if yes then take power cord out of the adapter from the end that goes to the wall socket .. that side is removeable ..then plug it back in and flip the way its plugged into the wall socket .. c if this helps ..
Oct 22, 2010 | HP Computers & Internet
Why would the plug melt on an Acer 5315?
Plugs melt when the connections 'short circuit'.
This means the positive and negative energy paths are touching.
Even the smallest AAA or 9V battery will get really warm if your connect the terminals together, and the power supply of a laptop computer pushes more more power (amps) than a little battery.
If it is indeed the power connection of your laptop has some melting damage, I must recommend you have your laptop and its power supply serviced or replaced, and to not plug it into the wall until you do. Fires have started by malfunctioning/damaged cameras and computers.
I hope that helps.
Aug 21, 2010 | Acer Aspire 5315 Notebook
I have a new e627 used only once before today. Battery connection was partially out and screen indicated low battery. After five minutes screen went black and now I cannot power up.
Maybe your battery is totally drained.
Try to connect the AC adaptor of your laptop and plug it to the wall outlet and let it charge for 3 hours or more. When you plug it on the wall socket, it won't show the laptop's led blinking since it was totally drained. But after 3 minutes or more, it will start to show the blinking led to indicate charging. When blinking stops led light disappears, it is fully charged and ready to use.
Remember: Do not use your laptop while it is plugged in to save your battery life. When at home, remove the battery while it is fully charged and plug the AC adaptor directly to the wall outlet. It will still work without the battery as long as it is plugged directly to the wall socket.
Feb 23, 2010 | Computers & Internet
Acer aspire 3680 laptop will not charge while plugged in wall
It appears that you have faulty laptop power connector socket.
This is why it appears to work sometimes when you plug the connector into the laptop in some direction.
To confirm this, wriggle the connector while you look at the charge light on the laptop, if it blinks as you wriggle it then the power socket is either faulty or just needs resoldering so it will make proper electrical contact.
You can get a compute techo to do this or you can do it yourself but it requires dismantling the laptop completely to get at this power socket.
Jun 01, 2009 | Acer Aspire 3680 Laptop
Want stay charged
Sounds like a bad battery cause its not keeping a charge. Try a new or known good battery and see if it will charge and then unplug the ac adaptor to see if the laptop stays on.
If the laptop stays on with a different battery charged then your old battery is bad. If your laptop doesn't stay on with a known good or new charged battery without the ac adaptor hooked up then its a bad motherboard.
Feb 14, 2009 | Toshiba Satellite A100-S8111TD Notebook
Acer laptop won't boot up
Try booting the laptop with the battery removed while the laptop is plugged into the wall outlet. Acer has a weird problem sometimes with the battery preventing it from booting. Sometimes it will get as far as logging into windows and then act crazy, slow down, and freeze.
Jul 14, 2008 | Computers & Internet
HP Pavilion dv6000z Notebook Logo
117 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
