Question about Trendware TE100-MP1U Print Server
Trendnet print server problem
Laptop running Vista Basic, HP PSC-1350v USB printer, TrendNet TE100MP-1U print server.
I got this a couple of days ago and set it up. Worked fine, except when I turned off the laptop, I had to reconnect the printer when I turned the laptop back on. Today, I turned on the laptop and went to the TrendNet Control Center to connect the printer... the printserver icon and description that I would normally select to autoconnect is blinking! 2 sec on, 2 off. I cant see the printer icon and description at all. I have checked the user manual, trendnet knowledge base and other online forums, but none mention an intermittent icon. I don't even know how else to describe it. It's got to be some kind of error message. I uninstalled and reinstalled the whole thing, same as the first time, same outcome.
Btw, my HP is on TN's list of approved printers and it worked for two days just fine. Any ideas?
Thanks for your tiime,
Spence
  • Anonymous Feb 26, 2009
    exactly the same problem... but i'm running win XP
smeago1
  • 136 Answers
SOURCE: New Vista laptop and problems setting up wireless
Chances are the wireless portion of the trendnet software is not compatible with vista. I would uninstall the trendnet software or let windows control the wireless portion of it.
Check to see if you are using any encryption ie. wep or wpa or wpa-tsk. If you are then you will need to enter the network key in windows.
good luck
smeags.
Posted on Jan 08, 2008
  • 3 Answers
SOURCE: Trendnet TE100-P1U won't print
open the print server utility and the doc can be cancelled or deleted from there. (this is the server utility inthe toolbar at the bottom of a windows screen. failing this go to the printer shortcut and from control panel>printers> select printer and faxes>select the printer (open) >select "printer" from menu bar, pause printing,then cancel all documents. Afterthis you can delete printers that are excessivly created, or delete all of them and start again with only the one or two printers you need. even if one is for network use and the ther is direct connect. You canuse direct connect to verify proper printer operation until te100 is working properly
Posted on May 10, 2008
rahul26485
  • 611 Answers
SOURCE: I've connected my trendnet on a LAN via a switch.
you have to give ip adress in the print server and configure it and one more thing is that ip address shougt be in the lan network
Posted on Mar 14, 2009
  • 10 Answers
SOURCE: I cant connect my new laptop to my Tew 432 brp trendnet router
Sounds like you may be having an issue with software already installed on the laptop to control the wireless connection. Many laptops have preinstalled software for their internal wireless devices. You should consult your manual about configuring and saving passwords for a network for that particular device. Typically you will need to enter the WEP key in the software itself.
Posted on Aug 23, 2009
Testimonial: "He put me on the right track to solving my problem, thanks"
whlyon42373
  • 71 Answers
SOURCE: TRENDnet TFM-560U dialup modem disconnects after 15-20 minutes?
Make sure you don't have you modem properties in control panel set to auto time out or you mail set to disconnect after download.
Posted on Dec 16, 2009
Why would my Trendnet Print server TE100-P1U not be seen by all computers on the network even though it can be pinged. I can't install it on these computers even though it can be pinged
May requires software loaded on every computer - software that will create the non-std print server "port".
More expensive print servers like the HP jetdirect print server use std tcp/ip ports.
Nov 13, 2013 | Trendnet 1-Port Print Server TE100-P1U...
Trendnet te100 HP P2035 not printing
1. What is the exact error message or error code?
2. Have you made any changes to the computer prior to this issue?
I would suggest you to refer the following Microsoft article and check if it helps.
Printer problems in Windows:
for more help visit CBR Tech Solutions
Apr 17, 2012 | Trendware TRENDnet TE100-P1U Print Server
TRENDnet TE100-P11 shows print online but won't print
You have to create an LPR port for it to print successfully.
Download the User's Guide from the following link http://www.trendnet.com/downloads/list_subcategory.asp?SUBTYPE_ID=1316
and then follow the instructions from Page 22 to 24
Jun 24, 2010 | Trendware TRENDnet TE100-P11 Print Server...
Attempting to connect with trendnet TE100-p11 print server doesn't work. Trendnet infers it is not compatible with CAPT (Canon Advanced Printing Technology) type printer
Make sure the Print Server has the same IP address as your network. The run the PS-Wizard which is available on the disk. This PS-Wizard will install the printer driver as a network printer. This will let you print without any issues
Feb 08, 2010 | Canon ImageCLASS MF4350d Laser All-in-One ...
Printer is connected via USB to a Win XP PC and prints fine. However will only print test print from networked Vista laptop?
I take it you the Win XP PC is on the same network that your Vista Laptop is on and that some how you must be able to share the printer through your XP PC?
I think you are experiencing the many issue that Vista has to offer.
Maybe think of actually seeing about placing the printer on a Network print server. This would solve your issue. I did this with my Brother Laser printer and it works great. I believe the print servers are coming down in price I am using a TRENDnet TP100 and it works great with my two wired network desktop PCs and the two wireless notbooks that both have Vista on them.
Blessings,
A/V Media Guy
Nov 22, 2009 | HP LaserJet CP1215 Color Printer
TrendNet PrintServer TE100-P1P does not print
I get the same error connecting to an OfficeJet K60. Have been successful with my Macs, but not with XP.
Jul 08, 2009 | Parallel TRENDnet TE100-P1P 1 Port Print...
HP 1018 printer
try this: right click printer, go to tab Ports and check Enable bidirectional support it works for me .
Aug 10, 2008 | Trendware TRENDnet TE100-P1U Print Server
Mar 31, 2008 | Trendware TRENDnet TE100-P1U Print Server
Trendware TE100-MP1U Print Server Logo
605 people viewed this question
Top Trendware Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Trendware Computer and Internet Expert? Answer questions, earn points and help others
