Question about Frigidaire Refrigerators
My ice maker quit in my refrig. - Frigidaire Refrigerators
    Sergeant:
    Champion:
  • 311 Answers
Replace it if fill spout is not frozen up. Please contact me if you need further help and leave feedback. Thanks for letting me help you!
Posted on Dec 01, 2008
Samsung refrig, side by side, won't eject ice. How do I turn off the left hand light to quit ice?
How to Repair a Refrigerator Ice Maker ' HomeTips
www.hometips.com/repair-fix/freezer-ice-maker.html
If your ice maker doesn't make ice, check out these expert do-it-yourself ice maker repair ... W. Branner Side by side GE fridge, stopped dispensing ice both cubed and crushed. ... But now that it's cleared the motor won't run to dispense any ice (water .... Our Samsung French door ice maker is not working & is making noise.
Jan 01, 2016 | Samsung Refrigerators
Service manual LG french door refrig. LFX25950
at the front of the Ice Maker (IM) under the bottom the is a square button. push it. the IM should cycle. if it does not replace the IM
Sep 04, 2012 | Refrigerators
Ice maker quit
if ice maker is cycleing then it is either water frozen at the tube where water comes in. if it is then shut off refrig. remove icemaker and thaw tube out with a hair dryer. makeing sure not to melt plastic in the back panel of freezer. if it is plastic. if it is not plugged then it is either a bad water valve or the watervalve switch in the icemaker.
May 26, 2012 | KitchenAid Refrigerators
My GE side by side ice maker quit making ice, no water sees to be entering the unit.what do i check for?
Pour 2 / 3 cup of water into the ice maker .
If it dumps the cubes , but does not refill with water , replace the dual water valve behind the refrig . This is the piece , the wall water line connects to , on the refrig .
If it does not dump the cubes , replace the ice maker .
Oct 12, 2009 | GE Profile PSW26P Stainless Steel Side by...
Me GE Profile PSC23M Side by side ice maker quit making ice and water was on floor behind refrig. Is a water line frozen or clogged or do I have to replace ice maker?
It sounds like you just have a leak at the back. Try swapping the wires on the dual water inlet valve. Then try the water dispenser and watch on the back for where the water may be leaking before it gets up to the ice maker.
Oct 04, 2009 | GE Profile PSW26P Stainless Steel Side by...
Icemaker quit making ice; water works
is there ice in the maker but will not droup out?
Jul 23, 2009 | Whirlpool GS6NBEXR Side by Side...
Purchased a water filter for my estate refrigator and the ice maker stop working.
when you replaced the filter did you check the flow before installing. I have had filters actually clogged right out of the package. Also most filters have a flow direction indicated with an arrow on the filter
Apr 15, 2009 | Refrigerators
U-Line icemaker is undependable
to make ice the thermo in the ice maker must be below 5 F...make sure there is a clear flow between the evaporator and the ice make also make sure you have a good seal between the freezer and the refrig areas..
1) put a cup of water in the refrig.
2)start with the coolest setting and move 1 setting every 24 hrs.
until it up until it freezing the water.
3) coolest you can get but not freezing the refrig...
hope is help
Aug 30, 2008 | U-Line Refrigerator Ice Maker
Ice maker on G E refrigator
If you have low water pressure to the ice maker it can cause the unit to stick. If the water fill is ok then the ice maker is going out or the freezer is not staying cold enough. Icemaker has to reach about 12 degrees to cycle.
Apr 24, 2008 | Refrigerators
Refrigerators Logo
55 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
