Question about Speed Queen AES28AWF Electric Dryer
Where do you find the thermostat or the fuse on dryer?
This is a older dryer it is a speed queen marathon heavy duty dryer model number NE6313W
  • Anonymous Mar 23, 2014
    belt replacement
  • Speed Queen Master
  • 3,361 Answers
Unplug the dryer.
Remove the front panel. Two screws on the bottom left and right about 3 inches from the floor and 3 inches in from the sides.
Lift the panel off.
Remove the 2 screws on the bottom right and left of the door. Pull forward and raise it up to disengage lock tabs. Remove the door switch wires.
Under the top lid you will see 2 screws right and left holding the top on. Remove these and lift the top to the rear of the dryer.
From the floor position, reach in and remove the drum belt from the pulley and tension roller.
Remove the drum from the dryer.
On the bottom left rear of the inside cabinet you will see the heater,fuses and thermostats.
With a volt/ohm meter (vom) set for continuity you can remove at least one wire from each part. Then check for continuity through each part.
If you get no reading the part is bad.
Look for burned/separated wires also.
Reverse the above order to re-install parts.
Good luck.
Posted on Feb 20, 2009
Looking for a filter on a very old Speed Queen Marathon.
If you wish to get some details; check the site linked here. Pull up older posts. ..
Jun 09, 2016 | Speed Queen Washing Machines
Kleensmaid heavy duty washer by speed queen, washes but shuts down on what seems to be overspeed on the spin cycle Customer Reviews: Speed Queen 3.3 Cu. Ft ..., Inc.Find helpful customer reviews and review ratings for Speed Queen 3.3 Cu. ... If you need more water in the tub you can hold down the reset switch until the machine ... I tried the delicate wash and spin cycle, but the clothes retain too much water and ..... It takes time to correlate the number of turns and the direction to turn it.Missing: overspeed
Commercial Washer and Dryer Problems
The water should shut off once it reaches wash level, if it doesn't, and water level hasn't... (these are the glass type fuses) be sure to turn power off before checking them. ... If you have the voltage in, but not out, it's the contactor. .... We repair: Speed Queenwasher, IPSO washer, Milnor washer, UniMac washing machines.Missing: overspeed
[PDF]View document in PDF
Dec 19, 2015 | Speed Queen Washing Machines
How do i remover the exterior cover from the dryer, i have marathon heavyduty machine
well if its standerd front loader filter on top u take the filter screen out remove the two screws then with a flat screwdriver push along the front top seem pull it up it should give way and pop up the newer model's and some older take back off.
Apr 09, 2011 | Speed Queen Dryers
I have a Mcgraw-Edison speed queen Heavy Duty dryer. We used it last night and it worked fine except there was alot of condensation inside the dryer with a little water coming out the door. Now this...
You may have a venting problem. Check outside to make sure vent is blowing good. It is possible that the motor may have went bad with all of the problems associated with a clogged vent.
Dec 02, 2009 | Speed Queen AES28AWF Electric Dryer
No... I work speed queen all day long and I know they can be loud. Just double check and make sure the washer is sitting level. But other than that speed queen washers and dryers are just very heavy duty work horses.
Apr 08, 2009 | Washing Machines
I am looking for a model number on a Speed Queen Marathon washer
  • Behind the door
  • Behind or on top of the control panel
  • On the side of the unit near the front
You will rate me pl....................
Mar 06, 2009 | Washing Machines
Spots on white clothes
This is from not enough HOT loads.
Fatty deposits gather between the basket and tub during COLD washes.
Then they are being released in large numbers when you do your whites on HOT.
It is recommended to do 1 HOT load per week.
Do an empty load with some degreaser added (like Goo-Gone) on the fullest/hottest setting you have.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jan 29, 2009 | Washing Machines
Marathon Compucare Dryer
Could be a touchpad problem
Dec 09, 2017 | Dryers
Speed Queen AES28AWF Electric Dryer Logo
275 people viewed this question
Top Speed Queen Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Speed Queen Dryer Expert? Answer questions, earn points and help others
