Question about Kenmore 22313 Bagged Canister Vacuum
Cannot get belt cover off
Don't have owner's manual, want to change belt, cover will not release.
    Scholar:
  • 55 Answers
Yep, that's a tricky one.
There a part on the top of the nozzle that hides the screws. The best way to describe it is the light bulb housing. You have to squeeze the sides in to release it and pull it off. Then you will see two screws underneath it. When you remove those screws the whole to should come off.
Hope this helps good luck.
Posted on Nov 30, 2008
Kenmore vacuum cleaner model no. 116. 5861279 belt replace
Do you need the belt or the directions for changing the belt? Sears Parts Direct has the manual for the 116.58612790 here: http://www.searspartsdirect.com/partsdirect/part-model/Kenmore-Parts/Vacuum-Parts/user-manuals/manual-downloads/Model-11658612790/0582/0640500?modelNumber=11658612790&diagramPageId=&documentId= . The direct link to the manual is http://c.searspartsdirect.com/mmh/pd_download/lis_pdf/OWNM/L0802691.pdf . See pages 14-15 of the manual.
To replace the belt, you need to remove the light cover and then the light bulb. Press in the sides of the cover and lift to remove it. the bulb needs to be pushed in and then turned couter-clockwise. Remove the cover screws. Then flip over the Power Mate and use the flat blade screwdriver to release both tabs. Turn the Power Mate back to right side up and press on the handle quick release pedal and lower the swivel. Tilt the cover forward until it snaps free. Carefully, use your screwdriver to pop the brush supports free on both sides to remove the brush. Slide off the old belt. (If needed, slide off the brush supports and washers. Clean the brush before reassembling the unit. Then replace the brush supports and washers.) Push the belt on motor drive and then onto the brush sprocket. Push the brush supports back into place on the base. (Make sure that this isn't assembled upside down.) Then line up the front of the cover with the base and tilt the cover back into place. Press firmly until you hear both sides click into place. Replace the cover screws, light bulb and bulb cover.
The belt is available here: http://www.searspartsdirect.com/Kenmore-Vacuum-Parts/742024/0020/116/Model-11658612790/0582/0640500.html . This is part number 5285; it's the direct replacement for the original 742024 belt.
I hope this helps.
Jun 16, 2016 | Kenmore Vacuums
How can i change belt. model # 4235 az
I've posted the steps below, but I am also going to give you a link to the manual, as it includes pictures that might be helpful. Look for page 4.
http://www.eureka.com/service/manuals/81221.pdf
1) Use handle release to lower handle flat
onto floor (Fig. 1).
2) Remove 4 screws from brush roll cover.
(Fig. 2).
3) Lift off brush roll cover. (Fig. 3).
4) Remove brush roll and belt. Thread new
belt around motor shaft and brush roll
(Fig. 4).
5) Insert left end of brush roll first. Make
sure end cap fits into base. Pull right
side of brush roll to stretch belt and
insert right end cap into base (Fig. 5).
Make sure it slides into position.
6) Rotate brush roll 2 turns to center belt.
7) Replace brush roll cover (Fig. 3).
8) Replace 4 screws (Fig. 6).
May 05, 2011 | Eureka 4235AZ Upright Vacuum
I have a Eureka Altima and not sure how to change the belt?
flat onto floor
2) Remove 2 screws from the front side of
brush roll cover
3) Lift and remove brush roll cover .
new belt around motor shaft and
brush roll
sure square on brush roll cap is in
place. Pull right side of brush roll to
stretch belt. Secure right end cap into
base.
8) Replace 2 screws
And you can get the maual here.
http://www.eureka.com/service/manuals/80244.pdf
Good luck
Sep 27, 2009 | Eureka Altima Upright Vacuum Model 2996AVS...
Need to replace belt
turn it over on the bottom by the roller there is a cover with 5 screws take off cover theres the belt........hope this helps
Dec 17, 2008 | Eureka 5848AV Bagless Upright Vacuum
How to I replace the belt on a Bissell Cleanview?
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=708100
Generic problem for all Vacuums
How to I replace the (by 2 users)
Posted by bobklein on Jun 26, 2008
Have the same problem? Click Here X
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
OK
1 Other User Has the Same Problem Comment by cooks22, posted on Jun 26, 2008 The belt on Bissell ProHeat powersteamer is broken, I have a new one, how do I replace it? Hello,
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Most of the Bissell’s the belt is changed from the bottom or the top is removed and you service it from the top. There are usually screws, clips or levers to remove the bottom plate or top cover and once that is removed then the belt change. If the belt is a flat belt the recommended belt change is every 4 to 6 months and id it is a geared belt then you would change it once a year for the best cleaning. If you have questions, refer to the owner’s manual in the trouble shooting section, if you don’t have an owner’s manual then you can contact the Bissell Factory cust serv listed below. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.bissell.com/ Customer Service 1-800-237-7691
Hours of Operation Monday thru Friday 8:00 am to 10:00 pm EST
Saturday 9:00 am to 8:00 pm EST Mail To: Headquarters, Bissell Homecare Inc
P.O. Box 3606 Grand Rapids. MI 49501
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jun 26, 2008 | Vacuums
Replacing belt on bissell model 1694
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=707372 Generic problem for all Vacuums
Replacing belt on Bissell model
Posted by chi_agee on Jun 25, 2008
Replacing belt on Bissell model 1694
Go Ahead. Use Us.
Jun 25, 2008 | Vacuums
DONT KNOW HOW TO CHANGE MY BELT
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=698891
Posted by mommyhop1 on Jun 23, 2008
I LOST MY MANUAL TO SEE HOW TO CHANGE MY BELT. TRYING TO FIND THE USERS MANUAL FOR MY ELECTROLUX 3500 SR
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. The best way to get the owner’s manual is to contact the Electrolux factory and either download the owners manual from the website or call the customer service phone # and give them the model and serial # of the machine and they will send you out an owners manual for the product. Or you can contact your local vacuum cleaner dealer in your area and they would assist you in changing your belt. Usually there are screws in the bottom of the vacuum and either the bottom will come off or the top cover will lift off and then you can change the belt. The average and recommended belt change for a flat belt is every 4 to 6 months and if you have a geared belt it is once a year for the best cleaning. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://electrolux.com/ Customer Service 1-800-896-9756
Electrolux Home Care Products – North America
P.O. Box 3900 Peoria, IL 61612
Go Ahead. Use Us.
Jun 23, 2008 | Vacuums
I need to change the belt on the hoover preferred 16.0 how do I open it up?
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=683113
Posted by catch100681 on Jun 18, 2008
I need to change the belt on the Hoover preferred 16.0 how do I open it up?
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. There are only 2 ways in order to change the vacuum belt on a Hoover vacuum cleaner. There should be a couple of levers or screws on the bottom of the vacuum. Once you remove the screws and or the bottom plate the belt should be exposed –if not then the top cover of the vacuum will come off and then you can service it from the top of the vacuum. The average flat belt change is every 4 to 6 months for the best cleaning and to store the extra belts in a Ziploc bag in the refrigerator, for some reason if the belt is a geared belt then you would change it once year. If you have a question look inside your owners manual or to contact your local vacuum cleaner dealer in your area. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.hoover.com Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
Go Ahead. Use Us.
Jun 18, 2008 | Vacuums
I need to replace the belt on the power nozzle of my Hoover Dimension 1000 Model S3491. Unfortunately, I have no written instructions on how to do so. I purchased the vacuum cleaner in the mid-80s. Are the...
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=566792
posted by Deb in Iowa on May 03, 2008
I need to replace the belt on the power nozzle of my Hoover Dimension 1000 Model S3491. Unfortunately, I have no written instructions on how to do so. I purchased the vacuum cleaner in the mid-80s. Are the instructions still available? Thanks in advance.
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. I believe so, but you would have to contact the Hoover Factory and they would have to send out either the owner’s manual or a copy of the owner’s manual from the fische. I remember this vacuum cleaner well. In order to change the belt you need to remove the 4 screws in the bottom of the power nozzle and then the top cover will lift off from the back to the front and then you can get in to change the belt. Always use the Factory Genuine belts instead of the replacement belts, they last longer and the average belt change for a flat belt is every 4 to 6 months as a rule for the best cleaning. In order to change the belt, lift up the pulley side of the brushroll and slide off the old belt and then slide on the new belt and re-install the brushroll, then use a belt puller or screwdriver with a hook on the end and to pull or stretch the belt onto the motor pulley, once you have it on the vacuum track the belt in a straight line and then reinstall the top cover and screws in reverse. If you have questions please feel free to contact your local vacuum cleaner dealer in your area. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
8 a.m. - 7 p.m. EST
Go Ahead. Use Us.
May 03, 2008 | Vacuums
How do you replace the belt on the pro heat? My belt broke.
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=548843
Posted by gtoy on Apr 26, 2008
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. You may check your owner’s manual to see how to replace the belt, but normally the belt is replace under the top cover by removing 2 to 4 screws and the top cover will come off to replace the belt. As far as maintenance it is a good idea to replace a flat belt every 4 to 6 months for the best cleaning and if it is a v belt or geared belt then the belt change would be once a year. If you have other questions feel free to contact you local vacuum dealer in your area. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
Go Ahead. Use Us.
Apr 26, 2008 | Vacuums
Kenmore 22313 Bagged Canister Vacuum Logo
113 people viewed this question
Top Kenmore Vacuums Experts
Chris Nomland
Chris Nomland
Are you a Kenmore Vacuum Expert? Answer questions, earn points and help others
