1. Go to Bootdisk.com & download a DOS bootdisk. 2. Go into your BIOS and set the floppy disk as the first boot device 3.Restart your computer with the boot disk in the drive. 4.Choose to boot your computer using CD ROM support. 5. Type the following command "fdisk". 6. Select "Y" to enable large disk support 7. Use this program to create a partition and set the partition to active. 8. When formatting is done reboot with the boot disk again. 9. Type in the following command "Format c:" where c is the letter of your hard drive. 10. Type "y" to accept.
Congrtats!!! You are now done formatting the drive.
Before you can copy files to a CD or DVD, the disc must first be prepared using a process called formatting.
There are several ways to format a CD or DVD disc. Your choice of
format determines which computers and other devices will be able to read
the disc.
Insert a disc into your computer's CD or DVD drive.
In the dialog box that appears, click Burn files to disc.
In the Burn a disc dialog box, type a name for your new disc.
Click Show formatting options, and then click one of the following formatting options:
Live File System
Mastered
Click Next to prepare the disc.
Now you can copy files to your disc using whichever method you selected.
