Question about Ariston Technologies AWD120 13 lb. Washer / Dryer Combo
Ariston margherita 2000 advantage AWD10
I recently aquired an awd washer dryer, but not sure how the dryer on it works could any one help? it seems to just drain water, i have put it on the on the system dail on the sun symbol which i first presumed was the drying setting, not sure if this is right? maybe it is an theres a promblem??? thanks
Push the sun symbol button and set it on the time/or the function of the dryer. Thats it. I believe you were using the drying function without heating:)
Regards
Posted on Jan 21, 2008
My stackable unit quit filling with water. It still spins and drains. I have cleaned the screens out for the water hoses. I have unplugged it for a few. What else can I do to fix my washer?
Use a meter to test the water valve solenoid coils, make sure nobody turned the supply hoses off without you knowing. Did you recently replace the fill hoses or have work done on the machine? Maytag Washer Dryer Combo Water Inlet Valve WP22001274
Jul 29, 2016 | Maytag LSE7806A Top Load Stacked...
I can't stop the dryer from coming on Ariston AL128D, I just want to wash
Hi there, the F button on your washing machine (see manual http://www.gebruikershandleiding.com/Hotpoint-Ariston-al-128-d-margherita/preview-handleiding-431405.html?page=0004) is the clue. if pushed in it won't dry. don't know why, but by trial and error this seems to work
Sep 12, 2012 | Ariston Technologies AL128D Margherita...
Our Maytag stacking washer/dryer, MLE2000AYW, has generally worked well. Recently there is water in the washer after the clean clothes have been removed. The water can be removed by adding a spin cy
The intake valve may have debris under the plunger allowing the water to bypass the valve. If it fills up when not in use it is a sure sign of this. However, your issue sounds more like a clogged filter allowing drain water back in the drum after the cycle has ended
May 19, 2012 | Maytag Neptune MLG2000A Front Load Stacked...
I have a Kenmore 80 series washer it will not stop filling with water so it wont go into agitate cycle, help
Has your drain for your washer backed up recently? Or is the drain hose from the washer sealed into the drain pipe, meaning that you can't just lift the hose out anymore? There needs to be air around the drain hose or it will cause the washer to allow water to be siphened threw the drain by not closing the filling valve. This can also happen if your drain is backed up. Rooter the drain out and make sure that the drain hose is not sealed up to the drain pipe and see if that fixes your problem.
Feb 12, 2012 | Kenmore Washing Machines
I CAN'T FIND THE FILTER IN THE ARISTON MARGHERITA 2000 AB43 IN ORDER TO CLEAN IT
The filter is usually in the top tray or bottom in the little square.
Hope I helped
Dr Reed
Apr 06, 2010 | Ariston Technologies Ariston AWD12 Front...
Ariston - Margherita Washer -dryer model AWD
Check motor brushes for wear. Brush length is about 30mm new; 10mm or less is too short to do what they're meant to.
Feb 28, 2010 | Washing Machines
Ariston Margherita Washer Dryer 2000 dries when not supposed to.
I think I am right in saying that on this machine you have the facility to either incorporate the drying process as part of a program or you can use it as a stand alone dryer, is it possible that you have simply asked the machine to dry after wash by selecting a wrong program is there a another button that allows you to wash with out dry even on a wash dry program if there is such a button/switch and it does not seem to do much it could be that the switch contact have corroded and are not making proper electrical contact check manuel
NEVER OPEN MACHINE CASE WHILST STILL CONNECTED TO MAIN POWER SUPPLY
Jan 17, 2010 | Washing Machines
Washer not draining properly.
your pup is not working properly it may have somethig inside or draining house coud be that problem too good luck
Nov 05, 2009 | Maytag Neptune MLG2000A Front Load Stacked...
Washed load of towels wont work
try cleaning the drainage filter located under the front bottom panel.
Aug 14, 2009 | GE WSXH208A Front Load Washer
Washing Machines Logo
681 people viewed this question
Top Ariston Technologies Washing Machines Experts
Marvin
Marvin
shaun taylor
Håkan Sterner
Are you an Ariston Technologies Washing Machine Expert? Answer questions, earn points and help others
