Hard disk issue , failure - Computers & Internet
  • pklinuxguru
    pklinuxguru May 11, 2010
    There's a lot of things that can go wrong. More details are needed to tell what's wrong. Do you see error codes? Does the computer beep at all when you turn it on? Do you see Windows start and then stop with an error? Do you see BIOS information when it's first turned on? Try getting into the BIOS with either the Del or F1 keys (depends on your system). The Basic setup in BIOS will show you your CD drive(s) and hard drive(s) if it can recognize them.
  • 153 Answers
Check the cable IDE cable to the HDD, check in the bios set up if the HDD is detected if not set it to auto detect. To enter bios set up, press delete on the during boot.
Posted on Dec 01, 2008
Hard disk failure
Purchase a new hdd NOW! and copy your data off while it is still there. You may be lucky and be able to use CloneZilla to clone the failing hdd saving you hours of uploading drivers etc.
Feb 09, 2016 | Lenovo G550 Laptop
How can I fix DELL Latitude C400 if the problem is hard disk failure..?
Hard disc failure is a permanent issue. Instal a new hard drive and OS, drivers and then with a USB adapter, try to recover your data from the old hard drive.
Feb 06, 2014 | Dell Latitude C400 Notebook
Hard disk failure imm
Hello
The hard drive is a mechanical device that WILL fail - it is only a matter of time. Since you are being prompted that yours is about to fail, you need to get a backup of your data as soon as possible.
Use a USB memory stick, USB hard drive, CD or DVD disk or network drive to copy your data from the hard drive immediately. Once your data is copied to a safe location, you can run CHKDSK /r /f from the CMD line to check the hard drive and possibly fix issues.
If the hard drive has "Bad Sectors", you will need to replace the hard drive.
Dec 15, 2011 | HEWLETT-PACKARD Computers & Internet
I have a w3622 and put in a new hard drive and tried to use the OS disk that came with the computer. what I get is PXE-E61: media test failure. check cable. Disk boot failure.insert system disk.
Sorry to hear about the trouble you are having. Try the following tips and lets see if we can get it up and running.
-Set the boot order in BIOS to boot from the disk drive first. In order to get to the BIOS, you will need to select BIOS option or Settings when the machine is booting up.
Most often, the above error is caused due to incorrect BIOS settings or a faulty hardware, such as hard disk. Sometimes, the error may also occur if the computer tries to boot from a device, on which it cannot find the required boot files. An improperly connected hard disk is also known to cause the same type of issue.
You should follow the below steps sequentially in order to isolate the cause and solve the issue:
  • Verify all the cable connections of the hard disk. An improper or loose connection is likely to be the reason, in case the hard disk has been recently installed or moved.
  • Check if no other storage device is connected to the computer. If it is, remove it.
  • Enter the BIOS setup when trying to start the computer and see if hard disk has been correctly setup and detected in BIOS. If the hard disk cannot be detected due to any reason, you should consider the next suggestion as it might be physical failure.
Regards,
G33k
May 09, 2011 | E-Machines eMachines Desktop PC
My compaq nx 6110 gives me a 1782 disk controller failure message and will not boot can anyone help?
A disk controller failure can occur because of a few things:
A.) IDE or SATA controller failure.
or
B.) Hard drive failure.
Since this is a laptop, your most inexpensive troubleshooting and fix for this would be to test another ATA 5 hard drive in the machine. If you can successfully re-install Windows on it, the ATA/IDE controller is most likely fine and the issue is just with your hard drive.
Hard drives are easily replaced... controllers are not and would require a new motherboard.
Please let me know if I can assist you further.
Regards,
KYTechnology
Mar 04, 2011 | HP Compaq nx6110 PC Laptop
I received the following error on my HP Pavilion laptop: SMART Failure Predicted on Hard Disk 4: WDC WD2500BEVS-60UST0-(S1) Warning: Immediately back-up your data and replace your hard disk drive. A...
SMART is used to measure your HDD health.It warns you of impending failure of your hard drive. If it goes down, it's a good idea to backup important stuff and prepare to replace the HDD.
S.M.A.R.T is an acronym for Self-Monitoring, Analysis and Reporting Technology systems (SMART) and it's usually built in to most modern ATA and SCSI hard disks.
If you need further assistance, feel free to ask. If this answers or solves your issue, please rate it. Thanks, Joe
Feb 09, 2011 | HP Computers & Internet
Smart failure hard disk 4 :wd1600bevt-222ct0-(si)
The error S.M.A.R.T. refers to Hard Drive hard drive that has detected damage to the disk and failure of the drive is imminent.
If the computer is booting to Windows after the SMART error, then back up all data on the disk immediately. The hard drive will need to be replaced to resolve this issue.
Also, I suggest that you start the Computer to BIOS and check whether the Hard Drive is detected in BIOS.
If the Hard Drive is detected in BIOS, then try to perform reinstalling Windows supplied in your computer once before getting the hard drive replaced.
Dec 20, 2010 | Toshiba Satellite A215-S5822 Laptop
Disk boot failure
Yes, this is have drive issue. May not be fixable with the restore disk. Test your hard drive to see if it's still in working order.
May 21, 2010 | Microsoft Windows XP Media Center Edition...
Booting issue
You have a hardware failure of the hard disk drive. Only way to resolve is to replace the hard drive that is failed.
Apr 28, 2008 | HP Compaq dc5700 Microtower - Free Flat...
When you turn the computer on it says SMART Failer predicted on hard disk 0: HTS54108G9SA00-(S1)
S.M.A.R.T. (Self-Monitoring Analysis and Reporting Technology) is a diagnostic method originally developed by IBM that at that time referred to as "Predictive Failure Analysis". This technology was developed for IBM mainframe drives to give advanced warning of drive failures. Based on this diagnostic, Compaq announced IntelliSafeTM, which was submitted to the ATA/IDE standards committees and the resulting standard was named S.M.A.R.T.
S.M.A.R.T. analyzes many of the mechanical attributes; over time, some failures can be predicted by detecting if the hard disk drive is moving out of tolerance. While the S.M.A.R.T. technology can detect upcoming issues, not all hard drive failures are predictable.
All this means on most modern drives is the hard drive is coming close to the maximum tolerances
I usually switch off in the bios smart monitoring.
This system is trying to predict a possible failure, which may or may not occur..
Mar 30, 2008 | Computers & Internet
Computers & Internet Logo
100 people viewed this question
David Payne
David Payne
