This board is in a PC that I built a year or more ago, and which was working fine until recently.
Now the PC shuts down while just beginning to boot. It seems likely that the board is bad, but I'm wondering if there is anything I should try before giving up on the board?
What you are describing sounds to me that your BIOS on the MB is failing to POST. POST stands for Power On Self Test. The BIOS runs a set of rutines burned into itself or eprom that performs a series of tests before it goes to the HD to look for the OS. If the testing fails at any point the system will stop and the machine will power off. There beep codes associated with each of the major test such as the video card and the keyboard. Both of these devices must be attached and functioning to allow the MB to POST. If you hear beeps just before shutdown, try and listen and determine it code by telling if it gives a short beep followed by a long one etc... These codes can then be used to determine what is not passing the tests. Your MB factory or the BIOS Mfg will have a list with these codes to help you find out what's wrong. If you get no beeps, try reinstalling your memory or remove one stick and see if you can boot then. This is a common area of failure (memory) also the CPU itself could be the culprit. If you cant resolve by changing the memory orchecking out the CPU, I recommend you take the machine to a repair shop and see if they can run a POST analysis
on the machine before just dumping the MB. Also check ALL connections to the MB and be sure they are tight and secure and making contact. Hope this helps.
Ive just looked at the specs for two motherboards 1,Asus P6T Deluxe V2 2,Asus M4A785TD-V EVO. WHATS...
(More)
Ive just looked at the specs for two motherboards 1,Asus P6T Deluxe V2 2,Asus M4A785TD-V EVO. WHATS your views on these boards as to building your own computer etc?
k8n-dl mb does not post. only action that comes is beep/beep off/beep/and on and on. This is with...
(More)
k8n-dl mb does not post. only action that comes is beep/beep off/beep/and on and on. This is with only one processor in and no ram. put pciexpress video card in and screen is blank. put second processor in and nothing happens, no beep, no video. reset works, voltages on the board after the connector are good; power ok nominal,
plug at interner exployer doesn't make contact front plug on inspiron 530 i purchased 06/2009 i...
(More)
PLUG AT INTERNER EXPLOYER DOESN'T MAKE CONTACT FRONT PLUG ON INSPIRON 530 I PURCHASED 06/2009 I THINK THE DOOR SWITCH ON LOWER CD DRAWER IS BAD THERE IS TENSION ON SWITCH . TOP DRAWER WORKS JUST FINE.
I installed 4gb ram on my ASUS P5GC-MX/1333 Motherboard but why only 3.37gb of ram is usable? i'm a...
(More)
I installed 4gb ram on my ASUS P5GC-MX/1333 Motherboard but why only 3.37gb of ram is usable? i'm a newbie in computer i need to get all the assist i need >.< Cheers Matthew Low
