Question about Polaroid FLM-3225 32 in. LCD Television
No Signal I hit a button on the remote and now when I turn on my tv, it's shows a blue screen and says, "No signal" in the upper right hand corner. I don't know what button was hit by mistake. I've tried all the buttons on the remote and still no luck. How can I get my picture back?
  • 2 more comments
  • Andrea66 May 18, 2008
    When I turn on the TV it has a blue screen and says "No Signal" it comes on more than 10 minutes later. It has been getting worse, taking longer and longer to finally "tune in". The settings seem to be corect.
  • davidkarlweb Aug 24, 2008
    tv has lost signil. cant get the imput menue to come up using the remote. using buttons on the tv i dont know how to get into select
  • Anonymous Mar 14, 2014
    I was watching a movie on direct tv and then I was trying to plug in my ps3 and tried the side and rear input didn't work showed a blue screen, then I tried to turn on my direct tv again then it wouldn't turn on same thing happened but on a black screen and saying no signal. any help would be very grateful.
  • Anonymous Mar 24, 2014
    its a soniq flat screen tv, it normally workjs fine, but i just turned it on today and this problem came up.... i tried pressing all the buttons on the remote, but no change.
    President:
  • 2,961 Answers
You will have changed the video/audio input, on your tv, it should be an input button on remote. The signal will either be on AV1, AV2, AV3 Component or HDMI.
Posted on Jan 24, 2007
How do I get Amazon Fire TV resolution set so I get more than a blue screen?
Select the input channel for your Fire TV - Turn on your TV and select the input channel for the HDMI port you used to connect your Fire TV. You should then see a loading screen with the Amazon Fire TV logo 4.
Jul 04, 2017 | TV Box Televison & Video
We accidentally hit something and now the TV is stuck with a #1 in upper right hand corner and "no signal" in the middle of the screen.
Hi Andrew:
I tend to think of my TV and all of the other electronics as if they have personalities, and they want to do things their own way.
It sounds as if the tv is working and thinks that it needs to receive a signal, so the input device is probably not turned on.
If you're using one remote, and it's anything like mine, it can control the tv and the input separately or simultaneously. The button on the top left switches this, and the indicator in the top centre tells me which mode it is in.
There's a possibility that you can restore your intended function by using the top left button.
Jun 29, 2015 | Televison & Video
I hit the wrong button on the remote, and the tv now saids no signal. How do I get back to the channel the tv was on
hit the source button again that is for your scat press down to 1 HD should get you back on.
Jan 10, 2015 | Televison & Video
My philips flat screen shows no signal and #3 in right hand upper corner just happened when cat knocked over remote no sound
To which model television are you referring? It sounds like you either need to change the input method for the TV or just change to a different channel (2 or 4).
Dec 10, 2012 | Philips Televison & Video
My sony kv-36FV300 will not respond. won't turn off .....or turn stations. The picture is snow...and has a "7" in the upper right hand corner. ....and has "no signal" in lower left corner.
Just wondering if thesmiths860 found a solution to their issue w/ their Sony TV. My tv is doing the same thing i.e. snow, won't change channels and says "NO SIGNAL".
Does anyone have a solution? I don't have the original remote so I can't do a factory reset.
May 04, 2010 | Sony FD Trinitron WEGA KV-36FV300 36" TV
My misubishi VS-50603 just shows a blue screen
Press the AV button on the remote, it will alter the interface with your receicevr. It will automatically pick your receiver if it is sending signal properly. If this doesnt work try another tv on your signal box to see if you get the same problem. Bet its the AV button though. Best of luck dave.
Aug 02, 2009 | Mitsubishi WS-48311 48" Rear Projection...
Olevia 540-B11
damm i have the same issue except the left side of the screen is far darker than the right. It still works but is very noticable. If you get this resolved please reply back!
Aug 19, 2008 | Olevia LT42HVi 42 in. LCD Television
Green box keeps popping up in upper right corner
You should be watching your dvd's on an input and not on tv analog 3. Every time the tv "senses" a signal change in the audio that screen will pop up. Connect the DVD player to the tv by using either the red, white and yellow (composite) connections or using the green, blue, red, white and red (component). Once you are on an actual input that box will stop popping up.
Dec 27, 2007 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Wont get signal
You are on the tv's component input. If the button of the remote that says video won't show you the other sources on the tv do it by the buttons on the side or top of the tv that say source. Go to analog or digital depending on the broadcast you are receiving.
May 22, 2007 | iLO 2600 Television
Polaroid FLM-3225 32 in. LCD Television Logo
494 people viewed this question
Top Polaroid Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
