Question about Dell E173FP 17" LCD Monitor
Dell E173FP When I switch ON the monitor, It's screen goes blank after a few seconds.
  • 4 more comments
  • 12345cool Apr 27, 2008
    i have the exact same problem you could write a more detailed solution please
  • Nialldublin Apr 28, 2008
    My monitor will display for about 1 sec then blank out - I have to keep switching on & off to see anything.
  • Anonymous Apr 28, 2008
    I have had the same problem. I appreciate if anybody knows how to solve this problem. Thank you.
  • TOYOCITY May 02, 2008
    SAME PROBLEM. AFTER A FEW SECONDS, GOES BLACK AND HAVE TO TURN OFF AND THEN ON TO SEE SCREEN. THEN BLACKS OUT AGAIN....
  • uvzone25 Apr 27, 2009
    I have a dell E228WFP flat panel monitor that is just under a year old. In the past 4 days or so when I sign in, the monitor screen goes blank. Time intervals vary between 10 min to 2 sec before monitor goes blank. I did monitor diagnostic check disconnecting white cable..self test dialog box appeared for a few minutes..then that went blank too. One interesting note though...if you place a flashlight angled against the monitor screen, you can see a "faint display" of the current web page. Upon further researching, I came across a similar complaint with this response...."If monitor is LCD, place flashlight against screen and if you see a faint display,backlight or power module is kaput". Upon writing this, I did happen to swap out with a smaller/cheaper monitor that I had as a spare, and for about 1 hour now....problem seems to have disappeared...at least for now. Hopefully my new monitor is still under warrenty. Can anyone offer help or comments??
  • micromadrush May 23, 2009
    Can someone show how to open the back of the LCD E172FPb.
HI Jamil , I'm french technician and I solve this problem yesterday .
For your problem yo cans change capacitor C6 , C26 220uF 25V 105°(105° is important for longer life of you'r screen).see this vue
Posted on May 16, 2009
Yea I get the same problem. PLEASE HELP!
Posted on Apr 27, 2008
  • 9,098 Answers
The unit will probably require electronic troubleshooting in the power supply / inverter section internally.
Posted on Jan 25, 2007
2 Suggested Answers
budmrtn
  • 11361 Answers
SOURCE: I have a Dell E173FP
Look for bad caps, shorted transistors, fuse, cold solder joints.
If you are going to DIY and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed DELL monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Replacement board: http://www.lcdrepair.us
Posted on Sep 09, 2010
I have a Dell E173FP 17" monitor. The screen goes blank after a few seconds. When I press the on/off button to turn it back on, it comes back on for a few seconds and goes blank again.
Sep 08, 2010 | Dell E173FP 17" LCD Monitor
Dell E173FP LCD TFT 17" FLAT SCREEN Monitor
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed DELL monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
http://www.badcaps.net
Replacement boards: www.lcdrepair.us
May 16, 2010 | Dell E173FP 17" LCD Monitor
Monitor switches on then goes into stanby
No input from Video card, try to connect second video cards head to your monitor.
Apr 19, 2010 | Dell E173FP 17" LCD Monitor
Monitor screen goes blank at intervals. If I turn
You may have to open it up and look for bad soderling works, see my pictures to see what bad solderign joints look like. Also check fuses, connectors, etc.
See what goes wrong with Dell monitors here:
I assumed that it does the same with other PC also.
Apr 05, 2010 | Dell E173FP 17" LCD Flat Panel Monitor
Screen Goes Blank
Ive seen this on other monitors. Look for a 1 and 2. Some monitors do NOT auto detect a signal, and this one might not. Look for a way to set the monitor from Digital input to VGA input. Try that and see.
Jul 21, 2009 | Dell E173FP 17" LCD Monitor
Dell E153FPd Power stays on but video goes off after 2 seconds.
3 ideas here. bad connections on the coils inside. the inverter board has gone bad, or bad capacitors on the power board or inverter board. all of witch should be serviced by a qualified service center.
Final Answer to Dell E173FP blank screen problem?
Check out this link http://www.lcdrepair.us/Installation.html
They have help videos on that model and sell repair kits as well as the whole board.
Jun 12, 2008 | Dell E173FP 17" LCD Flat Panel Monitor
Dell F1703 17 in. Flat Panel... Problem
There may be problem of heating the inside components. see him to expert.
Mar 03, 2008 | Dell E173FP 17" LCD Flat Panel Monitor
Screen goes blank when I move the mouse
please be specific, your question is not understood properly??
Oct 26, 2007 | Dell E173FP 17" LCD Monitor
Dell E173FP - After sometime the screen switches off
Sorry not a solution - but I have started experiencing the exact same problem over the last month although sometimes, on switching on again, it will run for 10-15 minutes before the problem re-emerges. Initially I put it down to the v. hot weather in July but it still continues. So I would also appreciate any solutions!
Aug 06, 2006 | Dell E173FP 17" LCD Flat Panel Monitor
Dell E173FP 17" LCD Monitor Logo
719 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
