Question about VisionMan VisionVault 4TB Smart NAS Appliance - Gigabit LAN, Hardware RAID 0, 5, Span, 128MB DDR, 4x (SSTE-2NAS30)
Cant connect to NAS via NFS
When i try to connect the log gives "refused mount request from 192.168.0.101 for /media_share (/): no export entry" even though in the NFS allow place i have 192.168.0.101 allowed access through NFS. Anyone know why this isnt working? Identical problem, tomorrow I am going to contact visionman. Maybe a firmware update fixes the issue...hmm....I might give that a shot.
dave
  • Anonymous Dec 11, 2008
    i have the same problem. did yo get a solution when you contacted them?
Invisible network hard disk
well, if you can Ping it, then the firewall is not likely going to be blocking it. Regardless, which product do you have ? The Silver Stone 2-drive NAS ? If yes, you should be using the FNS Assistant (FNSA)
The Freecom Network Storage Assistant helps you to locate your Freecom SilverStore 2-Drive NAS in your network. It can also be used to:
- quickly open the SilverStore 2-Drive NAS configuration website.
- configure the basic settings.
- mount shared network folders.
a) Start the FNS Assistant and select the device from the device list.
b) Go to "Web interface of your Freecom Network Storage device" for initial configuration
hope that helps.
Mar 31, 2014 | SMC Barricade g SMC2804WBRP-G Wireless...
Tip
Stream AVCHD videos to Xbox 360 via DLNA-AVCHD to Xbox Converter
Xbox DLNA-AVCHD MTS/M2TS to Xbox 360 support formats on Windows 7 <br /><br />Generally, I have my video to be kept in a D-Link NAS box, so that I can watch them on Xbox. The NAS is quite old, and I will buy a home server similar to the HP models one day. Xbox has a "Windows Media Center" window in the dashboard view, and <b><a href="http://dts-ac3-converter.com/2011/07/stream-avchd-videos-to-xbox-360-via-dlna-avchd-to-xbox-converter/">Xbox Streams videos from NAS via DLNA for HDTV</a></b>. <br /><br />However, the AVCHD files from my Sony DSC-TX100V could not read by Xbox. While looking for the solution to <b><a href="http://www.aunsoft.com/final-mate/">stream AVCHD videos to Xbox</a></b>, I find Aunsoft Final Mate as the recommended AVCHD video converter and joiner with best quality. After dealing the AVCHD files with Final Mate on Windows 7 Premium, I can share the videos using Windows Media Center software for streaming. <br /><br />Below is just a simple guide with AVCHD to Xbox supported format. <br /><br /><b>Step 1. Import AVCHD videos to Final Mate.</b> <br />Run Final Mate as the <b><a href="http://www.aunsoft.com/final-mate/">best AVCHD to Xbox converter</a></b>, and click the Add file path button on Resource tab to browse the folder with .mts or .m2ts files on PC hard drive. For videos from camera, just connect camera to PC via USB cable, and follow the pop-up wizard to import videos. <br /><br /><b>Step 2. Select and join AVCHD files for output.</b> <br />Select the clips on Resource tab or Camcorder tab, drag and drop to the Movies tab. You can create a movie for each file or a movie with several files with conversion. For another movie, just click the Create New Movie button. <br /> <br /><b>Step 3. Choose Xbox format.</b> <br />Click the icon next to the Movie name in the Movies tab, you will see the format options. Move to the Device group, find Zune/Xbox 360 Device and choose Zune Xbox 360 - Windows Media Video(*.wmv) as output format. <br /><br />Click Export button, and the conversion from <b><a href="http://www.aunsoft.com/final-mate/">AVCHD to Xbox 360 support format</a></b> will start right away. Wait for a while, and put the videos to the video folder for sharing. Xbox 360 then can stream videos from the NAS via DLNA.
on Jul 15, 2011 | Sony Alpha DSLR-A580 Body Only Digital...
Tip
DLNA Projector-Enjoy Vacation AVCHD videos on Projector with NAS sharing via...
Video Management for DLNA-Connect and Stream AVCHD Video to Projector via DLNA on NAS with Window 7 MTS/M2TS Joiner<br /> <br /> We have a happy summer in Hawaii. With our travel companion, the compact Panasonic Lumix FZ100, we shot videos in 1920x1080 60i. But we got a large amount of clips when we connect the camera to PC from our vacation. Our PC with Windows Media Player 12 can play the videos, but we generally put the videos to NAS, so that our devices can find and <b><a href="http://dts-ac3-converter.com/2011/07/enjoy-vacation-avchd-videos-on-projector-with-nas-sharing-via-dlna/">enjoy/play Vacation videos on Projector via DLNA</a></b>. I use the HD Writer AE, but could not join several clips in a quick and easy way. <br /><br />My friend recommends me to use Aunsoft Final Mate, and it really does a good job with the preview. There seems no quality loss while the files are joined into one large file. What is more important, the whole process is done in a blink second. <br /><br />It facilitates the <b><a href="http://www.aunsoft.com/final-mate/">Video Management for DLNA</a></b>, which would be stored in NAS. We can not only play the videos on PS3 hooked to my Samsung HDTV, but also watch them on LCD projector connected to the HTPC. Below are my simple steps using Final Mate to merge AVCHD clips on Windows 7. <br /><br />About <b>DLNA Projector</b> : <br /><br />How to <b><a href="http://canon-videoconverter.com/2011/07/video-management-for-dlna-connect-and-stream-avchd-videos-to-projector-via-dlna-on-nas-with-window-7-mtsm2ts-joiner/">Merge AVCHD Videos and Connect/Stream to Projector via DLNA</a></b>? <br /><br /><b>1. Import videos to Aunsoft Final Mate.</b> <br />For the videos on PC hard drive, run Aunsoft Final Mate as MTS/M2TS joiner <b><a href="http://www.aunsoft.com/final-mate/">NAS sharing via DLNA</a></b>, go to the Resource tab, and click the "Add file path" button to browse the folder with the .mts or .m2ts files. <br />For videos on camera, just use USB cable to connect camera to PC, and follow the pop-up message on Final Mate to import clips to Camcorder tab. <br /><br /><b>2. Merge AVCHD footage for lossless output.</b> <br />Click the Create New Movie button, and a new Movie ID for lossless output will be created on Movies tab. Drag and drop the clips with the same event to the Movie ID. For another event or other clips, just create another lossless movie. <br /> <br /><b>3. Get AVCHD file for DLNA sharing.</b> <br />Click the Export button under the volume settings, and click the OK button to start joining AVCHD files into one large file. <br /><br />So no matter you are using Popcorn Hour, PlayStation 3, NAS from Netgear, Synology, QNAS, LCD projectors like LG HS200 or other home projectors, you can easily <b>Stream and Play <a href="http://www.aunsoft.com/final-mate/">HD videos with projector via DLNA</a></b>.
on Jul 05, 2011 | Sony Alpha DSLR-A580 Body Only Digital...
Unable to copy the folder in window 7 Professional
You have this posted in the wrong category, please re-post.
Jun 12, 2012 | Cars & Trucks
I have a belkin N F5D8233-4v3 router with the latest software and I recently bought a black armor NAS 110 network storage and the NAS 110 cant pull an ip from the router when it is connected.
log on to the NAS device and see if it has a static IP embedded. If this doesnt help, try to replace the cable that connects the router and the NAS device. That could help
Thanks
Ranjit
Dec 09, 2009 | Computers & Internet
Tip
Stream AVCHD to VIERA TV via DLNA-Transfer MTS from Synology NAS to HDTV
HD Video Streaming from NAS to Plasma TV-Join MTS Clips without Re-encoding <br />How to Connect and Stream AVCHD MTS from NAS to HDTV via DLNA? <br /><br />I have Synology DS110+ NAS for storing and sharing movie collections, photos and music via home network. The Synology DiskStation Manager 2.3 was installed on Windows 7, and my Panasonic TC-P46S30 presents pretty good image quality. The 46" Class VIERA S30 Series 1080p Plasma TV supports AVCHD/MPEG2/JPEG/MP3 playback. While I try to do MTS <b><a href="http://www.aunsoft.com/final-mate/">Streaming MTS from NAS to Plasma TV</a></b>, I notice there is larger space between clips than the MP4 videos on NAS. <br /><br />I am not sure if it is because the decoding or streaming on HDTV that makes the differences. I would like to join the MTS clips into one large file, so that there could be less buffering notice for HD video playback. After google search, I find Aunsoft Final Mate as the fast <b>AVCHD joiner without re-encoding</b>. It keeps the native format without changing the file extension. Here I would like to share with you my experience with the Final Mate. <br /> <br /><b><a href="http://sony-mts-converter.com/2011/07/stream-avchd-to-viera-tv-via-dlna-transfer-mts-from-synology-nas-to-hdtv/">How to Connect and Stream AVCHD MTS from NAS to HDTV via DLNA</a></b> ? <br /><br />1. <b>Quickly import videos to Aunsoft Final Mate</b>. <br />Run Aunsoft Final Mate as the straightforward AVCHD merger. To <b>Import the videos from NAS</b>, just go to the Resource tab, and click the "Add file path" button to browse the folder with the AVCHD files on NAS. <br /><br />2. <b>Easy ways to join AVCHD files without re-encoding</b>. <br />For the first movie, just choose the clips from Resource tab, drag and drop to the timeline for lossless movie. To get another movie with different events, click the Create New Movie button to get new movie ID. Drag and drop clips to movie ID for a separate movie. You can also choose File &gt; Create A Movie for Lossless Output to get new movie ID. <br /> <br />3. <b>Get movie within seconds</b>. <br />Click the Export button under the volume settings, and click the OK button to start joining AVCHD files, removing the gap between clips. <br /><br />When the joining process is done, just <b>transfer the movies to NAS</b>, and use remote controller to <b><a href="http://www.aunsoft.com/final-mate/">Stream AVCHD to VIERA TV via DLNA</a></b>.
on Jul 04, 2011 | Sony Alpha DSLR-A580 Body Only Digital...
Tip
Set up a home office LAN which access internet through USB wireless gadget
The following networking job I have done in this Lab. It is enough for a small office to access or transfer file Printing and access of shared Internet in different type of operating system.
We have recently set up a home office (small laboratory) LAN. All the computers access the internet through a USB wireless (CMDA) dongle. The USB stick is Huawei EC168C and internet service provider is Reliance Infocom (India). But any USB internet dongle can be use to share internet in a LAN in the following way. And you don't need a router for that. In the areas where ISP cannot give wire line internet connection this type of USB wireless sticks are really helpful for home office.
Basic LAN Connection:
Here this lab has 4 PCs. One Windows XP, another Windows Vista starter and two RedHat Linux server systems. Here in this lab I have done the basic LAN connection using cat5 cable & RJ45 connector and an 8 port hub. I have connect the two windows based OS. Using cross cable I have connected two windows system with the hub. Then I put static IP address in Ipv4 of TCP/IP. After that I set workgroup name to join in a workgroup in windows PCs. Then I tried to ping the systems, and it was pinging. Then I have setup a home or small office network in both windows system. That I have enabled the Printer sharing. After that I can share file, data and printer through the system gateway.
Now I have to connect other two Linux PCs in this network. With same cross cable I have joined the both Linux system with the hub. Then to detect the Ethernet device I have put down "DEVICE=eth0" entry in /etc/sysconfig/network-scripts/ifcfg-eth0 file. Then I set IP address in Ethernet device in network configuration in graphical mode (or System-config-network in text mode).After doing this job I restart the network service with "service network restart" command. Then I am trying to ping the systems to one another, And It was pinging.
Now Linux system can access with each other and files also shared through SSH, Telnet,FTP using process and command.
Linux Configuration:
I have configured the Linux system in the following way. First I have set the host name in /etc/sysconfig/network file by VI editor. Next I have edit /etc/sysconfig/network-scripts/ifcfg-eth0 file with "Device=eth0" to detect the Ethernet device. After that I have put the IP add in network configuration file and Restart the network service. To keep the eth0 on permanently I also use the chkconfig command.
After doing this job File sharing can be possible through network file sharing (Nfs). I have install Nfs package & shared the nfs dir by editing exports file. Then I am trying to automount the NFS dir by automounting process. So that I put automounting entry of nfs file in fstab file. After that it's automounted in other system's mount location.
Windows & Linux Networking:
Through basic LAN both OS can only ping each other. To share file or data samba server (a client server in Linux) must be configured in Linux system. So I Install smb rpm package from yum repository. Then I have Configure the samba/smb.conf file. I put the Workgroup name on Workgroup column of samba/smb.conf file. Then I Set the network IP without host to route in network in Host allow column. At last I put down all details of Samba dir, users at the end of the configuration file set the samba password. After that I restart the samba demon to up the samba server. Now files can shared through samba server. In windows I Set the workgroup name pairs with samba server and also set username and password same as samba server. Now I trying to send or access file through samba in both OS and it happened.
USB Net Connect:
Here in this lab workers are use internet from an Usb net connect. So it must be shared in Network. It is too fast so shared internet can be access easily. In Windows XP system I connect the USB netconnect & share it in network. IF all the network setting is ok then all the systems can access shared internet through gateway. Here all users use this shared internet now.
Access of Another System:
VNC Server & Viewer is software through which we can access of another system easily. I just install the software & set the password. Then I run the vnc server. After that I Put the IP add of vncserver from vncviewer of another system and type the password & start access the vnc server system. It can be access form WAN also. I just Run the Vnc server and connect the internet and I got a Wan IP add provided by ISP.
on Jan 12, 2011 | Network Computing Devices (NSH800S/A)...
Compaq PE2160 with LINUX OS
Check to make sure all of your paths in the mount command are right. I had this issue a week ago and after putzing with it for a few days I noticed I was trying to mount a non-existent share. Fixed my ***** command and it worked right away. Other things to look at: Check your /etc/exports on the server and make sure the shares are in there. Also make sure that they are active by restarting nfs (/etc/init.d/nfsd restart (may be different now, that worked years ago)). Last, double check your mount command on the client. Make sure the share exists and the server is pingable. If this doesn't help, you may want to try searching on some linux specific forums. linuxquestions.org is good, or if you have ubuntu, ubuntuforums.com.
May 26, 2008 | Compaq Presario Desktop with Intel Pentium...
Can't Access Public Shares via NFS
You can mount the shares something like this:
mount -t cifs -o username=backup,password=YoUrPaSS //192.168.0.145/projects /mnt/nas/projects/
...where 192.168.0.145 is IP of SS4000-E and /projects is the shares folder
and /mnt/nas/projects/ is folder you have created on your Linux box
Hope this helps
Best Regards
ashley
Apr 11, 2008 | Intel SS4000-E (SS4000ENA)
Tip
Access to the NAS-T2 from Linux
Quick tip: when accessing the NAS-T2 from Linux, mount any NAS-T2 shares using smbfs, not cifs.
More detail: This tip presumes you're familiar with mounting filesystems in Linux and are trying to mount an NAS-T2 share in Linux. The older smbfs filesystem type for mounting Windows shares is deprecated in favor of the newer cifs filesystem type. However, the NAS-T2 is built on some older flavor of Windows and behaves very oddly when mounted as a cifs filesystem. Changing back to the older smbfs filesystem type solved all my problems.
on Jan 13, 2008 | Fastora 2 Bays Network Attach Storage...
VisionMan VisionVault 4TB Smart NAS Appliance - Gigabit LAN, Hardware RAID 0, 5, Span, 128MB DDR, 4x (SSTE-2NAS30) Logo
153 people viewed this question
Top VisionMan Computers & Internet Experts
Alun Cox
David Payne
David Payne
Are you a VisionMan Computer and Internet Expert? Answer questions, earn points and help others
