Question about Tally T6218 Matrix Printer
Paper motion fault
My tally T6218 dot matrix printer displays a 'paper motion fault' each time i try to print. i used to have a similar problem on my old T691 which i would simply disable the 'paper motion fault'.this one wont let me.help.
    Scholar:
  • 34 Answers
This info is from the Maint. Manual for T6212/T6215/T6218.
paper motion fault - gp+3ytmzowxemaaaaaelftksuqmcc
Sensor is located below the upper left tractor item 99 below. Clean it and make sure the V is facing your holes in the paper. If that isn't the problem? see below how to meter sensors procedures...
imeb+a4pe3uaaaaasuvork5cyii=
Posted on Oct 15, 2011
    Problem Solver:
  • 3 Answers
Paper motion fault, what can cuse it are as follows
1. motion belt
2. hammer bank belt
3. check the hammer assy.
Posted on Jul 25, 2008
Resynce the the sensors through the teck on optin s in the maint setup using the sensor calibration procedure in the tec access diag option for the tractor sensor option paper out and paper motion user/maint calibration procedure
Posted on May 01, 2007
SOURCE:
Error message PAPER OUT and PLATEN CAL required Tally 6218. Please help me. Esli mojno po ****** otvet daite. subat@mail.ru
You will need to calibrate the paper and platen.To do that,you will need to enter technical access and disable disable four fault error by pressing LF and enter button simultaneously until tech access appear on control panel display,then press tof + enter to override four fault.Now you can clear the fault message.,then go to calibration procedures.
Oct 11, 2011 | Tally T6218 Matrix Printer
All my tractors are okay but my printer still giving me a paper motion error?
you need to clean paper motion sensor first,
check its connection on logic board
clean the connector of sensor,
if you can then please post u r problems with printer model then i can explain it more.
Mar 21, 2011 | Tally T6218 Matrix Printer
Problem for lipi 6312 tally genicom line printer my printer shows an error (hammer voltage 1)
problem for lipi 6312 tally genicom line printer my printer shows an error (hammer voltage 1)
Apr 20, 2010 | Tally T6218 Matrix Printer
Tally Printer the error is some times Hammer
In the T6215 Maintenance Manual the fault message: Hammer Voltage has been replaced, in the T6218, with:
Hammer Voltage 1
There is a new fault message for the T6218. It is:
Hammer Voltage 2
Explanation: A high resistance coil fault has likely occurred in one or more of the hammer coils
Note: This fault message will have been preceded by printing slow-down attempts associated with On-The-Fly thermal monitoring of hammer bank temperature.
Corrective Action:
Check the hammer bank for defective hammer coils.
Confirm that hammer drive board is functioning properly.
Apr 05, 2010 | Tally T6218 Matrix Printer
Platen open error message on tally t6218 line printer
there are two reason behind the problem . 1 .the problem may come from the logic board.
2.and the platen sensor. change the platen sensor. if not solved change the board.
Sep 16, 2008 | Tally T6218 Matrix Printer
Error in eject page
dont use LF use FF to forward a form. if you use LF then set the topper form again.
Feb 03, 2008 | Tally T6218 Matrix Printer
Print stops after 2 pages !
Hi my tally printer 6218 giving Ribbon motion fault, what could be done to remedy this error message ?
Jan 19, 2008 | Tally T6218 Matrix Printer
Hammer voltage 2
it prints for about two minutes then starts slowing down and then stops printing showing an error of : hammer voltage 2
Sep 05, 2007 | Tally T6218 Matrix Printer
Tally T6218 Matrix Printer Logo
1,035 people viewed this question
Top Tally Office Equipment & Supplies Experts
Thomas F. Schneider
Alexey Krenvalk
Alexey Krenvalk
Clive
Clive
Are you a Tally Office Equipment and Supply Expert? Answer questions, earn points and help others
