Question about Microsoft Xbox 360 Console
Accidently changed video settings from 1080i to 1080p.
I have no picture. Is there a reset button? What is the best way to fix this?
    Genius:
  • 1,019 Answers
Sure Try This:-
Remove any disks from the tray.
Turn the Console Off, Then turn The Console On.
As the console Starts, Press And Hold The Y Button, And pull the right trigger at the same Time.
This will cause the 360 to restore the system defaults, it may reboot the console.
And return to the Original Configuration.
If this solves your problem, please rate as Fixya.
thankyou for Using Fixyas Free Forums.
Mike @ Compurepair.
Posted on Nov 30, 2008
I have a 47" Visio 1080p. Tv is always set at hdmi
AV inputs are for standard analog video which is 480i. HDMI and Component inputs are the high definition inputs that run at either 1080i or 1080p You won't ever get 1080i or p through AV inputs.
Oct 22, 2012 | Televison & Video
Ps3 only displays in 1080i
I have similar problem , ps3 320gb + 5 years old sony bravia 1080p = everything OK
but when i connect ps3 to new samsung ue46d7000 1080p = doesn't work (only 1080i)
I am using same HDMI cable
Jun 19, 2012 | Sony Playstation 3 (PS3) Console
What is the picture quality setting for a panasonic 1080i HDTV
Adjust the video output settings on the devices connected to your Panasonic HDTV. To view 1080p programming, enter into the service menu on your external device and change "Video Output" to the appropriate resolution. By default, the Panasonic TV is always displaying content in the resolution provided for it by the external device. If your cable box is set to output in "1080i," for example, your TV will display content in 1080i.
Let me know if this fixes the issue.
Regards,Suhail
May 11, 2012 | Vizio VO37LHDTV10A 37 in. LCD TV
How do I get my 52inch rca scenium to show 1080 using my ps3
Video Output Settings Adjust the system's video output settings. Select the best output settings for the TV in use.
1.
Check the resolution supported by your TV.
Resolution (video mode) varies depending on the TV type. For details, refer to the instructions supplied with the TV.
2.
Select in_setting.gif (Settings) > in_dispset.gif (Display Settings).
3.
Select [Video Output Settings].
4.
Select the connector type on your TV.
Resolution (video mode) varies depending on the type of connector used.
videooutput001.jpg Input connector on the TV Supported video modes (NTSC region) *1 Supported video modes (PAL region) *1 HDMI 1080p / 1080i / 720p / 480p 1080p / 1080i / 720p / 576p Component / D-Terminal *2 1080p / 1080i / 720p / 480p / 480i 1080p / 1080i / 720p / 576p / 576i Composite / S Video *3 480i 576i AV MULTI / SCART *4 480p / 480i 576p / 576i *1 The video mode options vary depending on the region where the PS3™ system was purchased. In North America, Asia and other NTSC regions, 480i video mode is displayed as [Standard (NTSC)]. In Europe and other PAL regions, 576i video mode is displayed as [Standard (PAL)]. For details, refer to the instructions supplied with the product.
*2 D-terminal is a connector type used mainly in Japan. The resolutions supported by D1-D5 are as follows:
D5: 1080p / 720p / 1080i / 480p / 480i
D4: 1080i / 720p / 480p / 480i
D3: 1080i / 480p / 480i
D2: 480p / 480i
D1: 480i
*3 Composite is the connector used to connect the AV cable that is supplied with the PS3™ system. S VIDEO is a format mainly used in Japan.
*4 AV MULTI is a format mainly used in Japan. SCART is a format mainly used in Europe. If [AV MULTI / SCART] is selected, the screen allowing you to select the type of output signal will be displayed.
5.
Change video output settings.
Change the resolution for the video output. Depending on the connector type selected in step 4, this screen may not be displayed.
videooutput003.jpg 6.
Set the resolution.
Select all resolutions supported by the TV in use. Video will automatically be output at the highest resolution possible for the content you are playing from among the selected resolutions.*
* The video resolution is selected in order of priority as follows: 1080p > 1080i > 720p > 480p/576p > Standard (NTSC:480i/PAL:576i).
If [Composite / S Video] is selected in step 4, the screen for selecting resolutions will not be displayed.
If [HDMI] is selected, you can also select to automatically adjust the resolution (the HDMI device must be turned on). In this case, the screen for selecting resolutions will not be displayed.
videooutput004.jpg 7.
Set the TV type.
Select the type of TV in use. Set when only SD resolution (NTSC:480p / 480i, PAL: 576p / 576i) is to be output such as when [Composite / S Video] or [AV MULTI / SCART] is selected in step 4.
videooutput005.jpg 8.
Check your settings.
Confirm that the image displayed is at the correct resolution for the TV. You can go back to a previous screen and revise the settings by pressing the in_left_key.gif button.
videooutput002.jpg 9.
Save your settings.
The video output settings are saved on the PS3™ system. You can continue on to set audio output settings. For details on audio output, see in_setting.gif (Settings) > in_soundset.gif (Sound Settings) > [Audio Output Settings] in this guide.
Source: http://manuals.playstation.net/document/en/ps3/current/settings/videooutput.html
Feb 28, 2011 | RCA Televison & Video
What is diferent betwin 1920*1080p and 1920*1080I
Television pictures are a series of still pictures that are presented quickly to give the illusion of continuous movement.
1080p and 1080i indicate how these pictures are formed.
1080p is progressive scan. It is a format that "paints" the picture left to right, top to bottom. On older tube type screens, this would cause the top of the picture to be dimmer than the bottom, as the phosphers would fade before the next picture was painted.
1080i is interlaced scan. This format paints every other line from top to bottom, and then paints the lines it missed before moving to the next picture. This evens out the brightness.
If your TV is capable of 1080p, it is considered to be the best picture (but you probably won't see the difference).
Feb 04, 2011 | Audio Players & Recorders
So i was messing with the display resolution, it was working fine before i started messing with it... i changed the resolution from 1080i with component cables... to 1080p. I lost the picture unti i...
1080i only works with component cables and wont go to 1080p but your hdmi will set it back to 1080i and then switch back to the component cables.
Jan 03, 2011 | Microsoft Xbox 360 Console
"Invalid format" how do I change from 1080p to 1080i or 720i?
I had a second playstation hooked to another tv in my home and took a controller from the non-LG-TV-displaying ps3 and one from a working ps3 on a seperate TV. And used the working ps3 to guide me to the settings menu on the ps3 that was not displaying video. Anyways, if you cannot see the tv screen because it is set on 1080p and your LG will not display it (Only displays up to 1080i). Start The PS3 and press the D-pad buttons in this order.
Left 10+ times. (This Takes you to the far left icon in the XMB)
Right Once. (This is the settings icon)
Down 20+ times. (To reach the bottom of the settings)
Then Up 4 times (This is Display Settings)
Press "X" Once. (This enters Display Settings)
Press Up 5 times (This Makes Sure you are at the top of the sub-menu at Video Output Settings)
Press "X" Once (This Enters Video Output Settings)
Before pressing any more buttons, Know what cables you have pluged into your TV.
For HDMI Just Press "X" and it will auto adjust to for the new TV.
For Component / D-Terminal Output Press Down Once Then "X", and X Again (This changed my ps3 from the 1080p-Invalid Format back to 1080i and fixed my problem.
For Composite Video Output Press Down Twice, Then "X" and X again.
For AV MULTI / SCART Output Press Down Three Times, Then "X"and X again.
Apr 26, 2009 | Televison & Video
I Have A Vizio 32LCD and my problem is i am trying to get the PS3 to play with the HDMI I have a HDMI cabel hooked up to the hdmi input on the back of the set and it is hooked up to to the HDMI input on...
1. Check the resolution supported by your TV.
2. Select (Display Settings) under (Settings) in the home menu.
3. Select [Video Output Settings].
4. Select the connector type on your TV.
D2: 480p / 480i
D1: 480i
5. Change video output settings.
6. Set the resolution.
7. Set the TV type.
8. Check your settings.
Confirm that the image displayed is at the correct resolution for the TV. You can go back to a previous screen and revise the settings by pressing the button.
9. Save your settings.
The video output settings are saved on the PS3™ system. You can continue on to set audio output settings. For details on audio output, see (Settings) > (Sound Settings) > [Audio Output Settings] in this guide.
Apr 06, 2009 | Vizio L32 32 in. LCD HDTV
Upscale from 480p Signal via HDMI
ok the problem might not be with your receiver it is with your direct tv settings. Double check to make sure you go to the format and set it up to be fixed or 1080i whichever will give you the highest resolution. Check your manual for the direct tv receiver. If this is all correct for the DTV then you must go into the setup on the receiver and at hardware icon toward bottom check on that box, now goto the hdmi settings and make sure it is set to through. this will allow the best picture with no upscaling which will degregade picture for blu ray. so your direct tv will be only 1080i but very impressive. if you still want to upscale you can then you have to change the hdmi settings from before to upscale 1080p . I just hope that your dtv can output 1080i it will give a better picture than 480p even if both are upscaled to 1080p
Oh i forgot to ask if you are connected through hdmi to the tv. Hdmi is the only option for upscaling
Feb 21, 2009 | Onkyo TX-SR606 Receiver
Ps3 reset
turn the PS3 off. hold the power button for at least 5 seconds or until you hear another beep.
This should reset all your ps3's settings.  If you have an HDMI connection, wait for a couple of seconds so that the PS3 recognizes and negotiates the right video output for your TV.
Sep 07, 2008 | Sony Playstation 3 (PS3) Console
Microsoft Xbox 360 Console Logo
90 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Tre Elkins
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
