Question about Kenmore 63942 Dryer
I have a kenmore Ellite Dryer that works but is not heating. Could it be the heating coil or something diffrent.
Posted on Jan 21, 2009
Everything works except it will not put out any heat for drying.It is an electric dryer model LEQ9508PW1
Two diffrent solutions; if you have old electric(glass fuses)it will be one of the fuses blown. If u have breakers then its the heating coils in the back of the dryer
Jan 13, 2011 | Dryers
Gas Dryer drying clothes cold, no heat...
if it heats for a while and then no heat you have bad gas coils,when the coils are on there way out they work until they heat up then they cut out,see if you have heat when the dryer is cold,if it is change out the gas coils
Jan 25, 2010 | Kenmore 63942 Dryer
I have a Kenmore 80 series dryer(118.72812101).
You may have something inside the workings of the dryer which has shorted out the heater coil. this could be the source of the noise as well. you need to remove the cabinet to access this, yet be careful as the drum will fall out on you in process. You can get a new coil from an appliance part store in your area. Take the dryer apart before buying this tho, so you don't waste your money on the off chance that this isn't the trouble. you will need make model and serial number from unit so they can match up the proper coil for you. Make note of how the belt is placed and routed for proper replacement when reassembling. Also make note of 'drum rollers' condition, as this could be some of the noise also.
Best to you, hope it works out
Joe
Aug 26, 2009 | Kenmore Dryers
Kenmore 80 series gas dryer has not heat
most of these dryers have a little plastic plug on the front, left side. pop that plug out and look inside after turning it on. you should see a red glow. if not, then your ignitor has broken. if you see a glow, then the problem is probably one of the two little coils on the gas valve. these coils will sense if there is something to light the gas [the red glow] and open the valve - if the coils are bad, they won't open the valve
Aug 17, 2009 | Kenmore Dryers
Is this a gas or electirc dryer?
If it's an electrical dryer it's probably the heating element.
Pull the dryer out, remove the back panel and look to see if the heating element is heating up (turns red). If not it's the heating element which is pretty easy to change.
Call an appliance parts store with the make and model number before you pull it out to make sure one's available and always take the old one with you to verify it's the same.
Hope this was helpful.
Good Luck!
Jan 21, 2009 | Kenmore 63942 Dryer
Kenmore Elite Elec Dryer Model # 110 62032100
Kenmore Ellite Dryer - Model 110.73952102 Type DDOT - NAT 1206006 - EH22
The Heat does not turn on! It spins and spins but no Heat? Any suggestions and how to fix intructions would be greatly appreciated. Thank you!
Oct 14, 2008 | Kenmore Elite HE4 Electric Dryer
Kenmore dryer 90 series model 66901692
heating element is located at the back of the dryer. if you can see a big coil of wires like a long spring laid back and fort to a duct , that is the heating element.
Feb 19, 2008 | Kenmore 62602 Electric Dryer
Kenmore Gas Dryer not heating. (74602)
i have a kenmore dryer the outside air vnet was cloged real bad , ive since cleaned it out but the only resone i found out was becoues my dryer will not heat up , is there a over heat swich ? can any one help .
Sep 24, 2007 | Kenmore 74602 Gas Dryer
Kenmore 63942 Dryer Logo
66 people viewed this question
Top Kenmore Dryers Experts
Sal De
Tim Whalen
Marvin
Marvin
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
