Question about GE Spacemaker JVM1640SJ Microwave Oven
GE Spacemaker appears to be sparking inside/top
Round disk on ceiling of microwave appears to be sparking. Can see flashing through plastic.
  • 78 Answers
1.Needs to remove that disk and clean the grease under it.
2. With sand paper clean dark burn spots.
3. Apply touch paint on open metal spots.
4.Put everything back.
I’m happy to help further over the phone at https://www.6ya.com/expert/vitaliy_f406165329c75ede
Posted on Dec 01, 2008
Why did it catch on fire?
Any flaws in the painted surface on the inside of the unit will cause a spark and that generates heat. Examine the surfacecor any exposed metal. You have to use special paint to resurface the inside.
Nov 15, 2015 | Microwave Ovens
Microwace noise coming from top and flashing
dont use the microwave until you retrieve what dropped inside when you removed the port. The grinding is most likely a foreign object that is hitting the moving parts of the microwave and causing sparking. It can catch fire
Mar 09, 2014 | GE JVM1650 1000 Watts Microwave Oven
GE Spacemaker XL1800 sparking from behind wave stirrer cover
Microwaves use a magnetron to generate microwave energy and direct it a rotating blade wheel to spread them around the inside of the oven. If there is any metal in the area to be heated, or any of the blades are bent, even a bit, the microwave energy can be reflected back up to the magnetron area. In this area there is now too much power and it sparks away, so it does not heat the item in the oven.
Because it is sparking it is now a safety hazard the sparks may melt and set fire to plastic parts in it. This is serious it could burn your house down. Bin this microwave and cut the cable off it to make sure no one else ever uses it.
Dec 20, 2013 | GE Profile Spacemaker JVM1871 Microwave...
How to remove the round disk from ceiling of the ge profile spacemaker xl1800 microwave?
mine had a small round plastic push in pry out retaining button on the frount side of the disc once that was removed the disc turned out of its locked position & droped out
Oct 16, 2012 | GE Spacemaker JVM1640SJ Microwave Oven
GE Profie JE1860SH 04 microwave sparks
Our JE1860SH was also sparking after a few seconds. The GE tech pulled the upper round disk and found the problem. The plastic was burned and the round metal which is behind the plastic dome was arching with the frame. Lasted seven years expected more especially from a GE product. So my suggestion is to remove the dome and check it out.
Jan 03, 2010 | GE Profile Spacemaker Over-the-Range...
Sparks inside the microwave
remove the round button(s) and remove the cover..clean thoroughly and replace anything thats burnt, if metal clean and paint touchup
Jun 22, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Inside ceiling of white microwave is brown What to use.
Try Lysol non abrasive kitchen cleaner. Also try vinegar.
Apr 30, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Plastic melted inside oven, dripping from ceiling Kenmore 721
The round peice in top of unit is a cover for the stirrer wich moves waves around for even cooking. The reason for it melting is almost certainly there is not enough paint in cavity and waves are shorting out to metal.CALL the manufacturer and depending on age of unit they may replace it free
Apr 21, 2009 | Microwave Ovens
Microwave does not heat
un plug remove cover find red lead to magnetron with thick long plastic round blob this contains a long glass metal ended fuse that has probably blown due to running when empty long fuse is necessary to stop hi voltage flashing over airgap when fuse blows when fuse blown no output from magnetron as hi volts missing steve t
Dec 03, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacemaker JVM1640SJ Microwave Oven Logo
602 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
