Question about Dell 0Y3740 Keyboard
The backspace button and all the arrow buttons will not move more than one space even when I hold them down.
  • bartonb1 Dec 10, 2008
    I realized that none of the keys would repeat, so I checked out Dell's community page and was able to find the way to fix it. Thanks for your assistance!
  • 3 Answers
Tried diff kybd? If same prob, then go into BIOS setup (F2) before XP boots, & check any kybd settings ie -repeat ON
If diff kybd works ok, then you prob have a bad kybd
Posted on Dec 09, 2008
How to Delete Text on a Computer?
i used to use white out but stuffs up the screen
curser and back space
you right click highlight or mouse left click delete or cut
Oct 18, 2016 | Computers & Internet
Space bar keeps going but not pressed
might be dirty, get a can of air, from like home depot, office max, etc. turn off laptop, take out battery, turn upside down and blow the air underneath the spacebar, this should fix your problem. If not you need a new space bar.
Chad
Apr 12, 2013 | Toshiba Satellite Computers & Internet
Back space enter key keeps locking
Try Alt+Right Arrow to go back to former page and put cursor where you were typing , left click ( mouse )
and now you can use backspace button , you must click all the time the left buttom before using the backspace if not you will have this problem again.
hope this helps
Sep 04, 2012 | Dell Computers & Internet
Instructions for brother p touch 1000
Instructions1 Turn on the device by pressing the power button. If this is the first time that the machine is being turned on, select a language with the arrow buttons and press the return button. Select a unit with the arrow buttons and press return. Set the date and time with the keypad and the return button.
2 Type in the text for the label using the keypad. Correct mistakes by pressing the "Backspace" key and retyping. Press the return button when the text is ready.
3 Select the appropriate styles and features for the label. The device will provide you with a wide range of choices for the size, style and width of the text. Simply select which feature you would like with the arrow buttons and press the return key to move on to the next option.
4 Print the label by pushing the "Print" button. Make sure there is paper in the device. It may be necessary to press the "Feed" button to align the label within the device. Print as many labels as necessary. To erase the text, simply press the backspace button until the text is gone.
5
Turn off the device by pressing the power button.
Mercedes Custom Parts
Jun 06, 2012 | Brother Office Equipment & Supplies
Hi, whenever I connect a USB cable (even charger) the E72 is locked
ITS A SOFTWARE PROBLEM. RESET YOUR PHONE . HOW TO RESET YOUR NOKIA E72
The way to button-press Hard Reset your E72 is the SAME as the N97.
Hold these buttons:
- Capslock
- Space
- Backspace
and Press the power on. As usual, keep the buttons pressed and voila!
NUMBER 2
Switch your phone off.
Then, lay it down on a flat surface
With 3 finger of one hand, keep pressed shift, space bar and back space all at the same time
With one finger of the other hand, press the power on button
Do not release neither the 3 keys nor the power key till you see the nokia shakehands animation
Feb 10, 2012 | Nokia E72 Smartphone
How do I re-set the margins?
using the space bar or backspace keys, move the carrier to where youwant the margin set, you may have to hold down the "ALT" button (2nd key from left on the bottom of the keyboard) and hit the "3" button (the one under wher it says "MAR REL") , to move past the margin. When the carrier is where you want the margin set, hold down the ALT key and then hit he key under where it says L MAR (for left margin) or R MAR (for right margin). the ALT key accesses all the function listed above the keyboard, the CODE key accesses all the functions listed on the keys themselves.
Feb 28, 2011 | Brother ML-300 Typewriter
How do you clear a tab someone preset. when I get to the far right of page and hit return it will on return to a tab. How do I clear all the preset margins or tabs.?? thanks
To clear margins, you have to hit the return button to find the left margin, then hit margin release and back space to move the margin left or spacebar to move to the right, then hit left margin button to set the new position. Right margin now. Hold spacebar down and find right margin position, hit margin rease and either spacebar to the right or backspace to the left to the new margin position then hit right margin button to set the new position. Tabs now. hit the tab key, when it goes to the first set tab, hit the tab clear key, then hit the tab key again, then tab clear again etc.
Dec 29, 2009 | Swintec 7040 Typewriter
Emachines Keyboard Model No. KB0511
Here you go:
Enter
The computer brings the cursor to the beginning of the next line. This key can also be pressed
to open a program after you have HILIGHTED* it. It will execute a command.
Shift ▲ Hold the shift key down and press the letter key you want to make a CAPITAL letter.
This key is also used to type the charters at the
top of some keys. Eg: Shift + 1 = ! or Shift + 2 = @
Caps Lock
Makes all letters CAPITAL letters. When the Caps Lock key is pushed, a light will
show up on the upper right corner of your keyboard
next to the capital “A”. When caps lock is turned on it remains on until you press the Caps Lock key
again. When you press the Shift key when
Caps Lock is on, a lower case letter will be produced.
Space This key places one space every time it is pressed. (The long, unlabeled key at the
bottom center of your keyboard).
←Backspace Deletes the character to the left of the cursor each time you press it. (If you hold it
down it will continue to delete so be careful).
Delete Deletes the character to the right of the cursor each time you press it.
Home Brings you to the beginning of the line the cursor is on.
End Brings you to the end of the line the cursor is on.
Esc Located in the upper right corner of your keyboard. Cancels an incomplete command;
it will also close an open menu.
Moves the cursor to the left one space each time it is pushed; does not delete the
character.
Moves the cursor up one line each time it is pushed; does not delete the character.
Moves the cursor to the right one space each time it is pushed; does not delete the
character.
Moves the cursor down one line each time it is pushed; does not delete the character.
Insert Deletes the character to the right of the cursor and replaces it with whatever is typed on
the keyboard.
↔Tab Moves the cursor to the tab marks and between columns.
Shift + print screen Prints what is on your computer screen.
Highlight (to select) To make the item stand out. To choose or select it.
? *When an icon is highlighted (left click the mouse button one time while the cursor is pointing at
the icon), the program has been chosen and the name of the icon will change color. When this has
happened, you may press the Enter key to open the program.
? *To highlight a character or characters, move the cursor, using your mouse or the arrow keys, to
the left of the item you wish to select. Press the left mouse button and hold it down while you
move the mouse to the right. Let go of the left mouse button and your item(s) should be
highlighted. Then you can choose what you want to do to the selected item(s) e.g. bold, underline,
delete, italicize, etc.
“Drag and drop” Move the cursor to the item, click the left mouse button and hold it down.
Move the mouse, while holding down the left
mouse button, to the location you want to move the item. Let go of the left
mouse button.
Cursor - The arrow on your screen. The mouse is used to move the cursor.
Let me know if this helped
Jan 02, 2009 | E-Machines eMachines Desktop PC
Cant find margin release
Generally, the way the margins work is, wherever the printhead is positioned, when you hit the right or left margin set, is where the margin is set. To reset the margin you must move the printhead to where you want the margin set, and hit the appropriate mar. set button. to move the printhead past where the margin is set, you must hit the "mar rel" button, and then backspace or space to where you want he printhead positioned. On machines without a "mar rel" button, you just use the "backspace" or "spacebar" to move past the margin. You can't release the margins permenantly, you can only move them, or move past them using the above mentioned processes.
Oct 05, 2008 | Office Equipment & Supplies
BIG PROBLEM: After hotsynch Palm resets over and over
You need to hold the "up arrow" while resetting, this will allow you to delete all info. That may not be what you want to do, if so, the only other option you really have is to do a soft reset, which is holding the up arrow and selecting "don't delete data". If the delete all data is STILL hanging after a hard reset, you can do a battery reset, which drains the battery, erases all data and goes back to "factory settings" There are two methods for this: While holding down the J & L keys, click the reset button on the back and hold it for 4 seconds. Or While holding down the K & backspace keys, click the reset button on the back and hold it for 4 seconds. Google "treo 600 battery reset" for more details
Sep 12, 2005 | Palm Treo 600 Handheld
Dell 0Y3740 Keyboard Logo
205 people viewed this question
Alun Cox
