Question about Panasonic PV-GS2 Mini DV Digital Camcorder
Try to playback the tape and the screen is all blue
Initially, when I tried to playback the tape I had blue stripes on the screen. I used the head cleaner tape for 10 seconds according to the instructions and the blue stripes disappeared. I took the tape out to see another tape and now the screen is all blue. I used the head cleaner again for 10 seconds, tried the tape again and still blue. 10 more seconds with the head cleaner and still blue. In addition, on the bottom left side of the screen you see now only -- -- -- where before you could see the date and time. Please help! Thanks, Antonio
  • Anonymous Mar 19, 2014
    I head a picture with lines in it ,and sound that intermits. I tried the cleaner but I get a blue blank. Can you HELP?
  • 73 Answers
Your heads motor ( drum ) cable may have have come loose or is dirty - since the cleaning tape made some difference the heads were dirty or almost worn out ( cleaner tape is abrasive ) so now there isn ' t enough signal ; if your date and time display worked only in play ? ( still works for camera record video ) your guides were out of alignment - and the cleaning tape took your guides even further out of alignment ( alignment here starts at $ 50 + shipping )
Posted on Sep 05, 2007
SOURCE:
My Sony DCR-TRV740 camera I just purchased (used), has a playback problem with my 8mm's. When I got the unit I cleaned it well with chamois swaps and MG video cleaner(Recommended by all experts it see
You have a clogged video head. It happens. Do not use the chamois again. Instead, purchase an 8mm head cleaner and give that a try. Only use a brand name cleaner - no generics, and make sure it doesn't come from China!
Nov 07, 2014 | Sony Handycam DCR-TRV740 Digital Camcorder
Power turns off after about 10 secs of watching the video
First guess is the camera has dirty heads. Suggestion is to run a head cleaner in your video camera. Regardless of the instructions on the head cleaner, I usually run the head-cleaner tape on "Play" for about 10 to 15 seconds, and then on "Record" another 10 to 15 seconds. Wait for 10 minutes before loading your playback tape. Try playing your tape again.
Also, check to be sure the tape is loaded properly and that the hatch closes securely and properly. A hastily loaded tape or an ill-fitting closure could cause the play function to stop.
If this does not solve the issue, it may be something in the play switch or in the playback mechanism that requires repair services. If the problem continues, I would recommend calling the Panasonic Company and speak with Tech support or Video Camera Repair. They may be able to tell you and estimate of what it would cost for the repair.
May 16, 2011 | Panasonic NV-DS60 Mini DV Digital...
DCR-TRV530 Digital 8 . . . Problem started with tape being caught in heads. Got a 3121 error message afterward . That stopped but in video playback mode only blue screen with play arrow at top? In...
If video head got clogged then camcorder wont read tape in playback so result comes as blue screen.
Please use video head cleaning tape and clean video head of camcorder. This will solve your problem.
Video-8 head cleaning tape is available with amazon.com
Thanks.
Dec 03, 2010 | Sony Handycam DCR-TRV530 Digital Camcorder
Ag-dvc20p blue stripes in play back mode
Blue stripes in playback is an indication that you need to clean the heads. A Panasonic cleaning tape should work fine.
Jan 22, 2010 | Panasonic AG-DVC200 DV Digital Camcorder
Blue stripes when playback
first u put clean casset and try . again it coming then u chaing video head
Jul 21, 2009 | Panasonic PV-GS2 Mini DV Digital Camcorder
Blue screen on TRV 260 playback
tape head is damaged. sometimes the internals unwind on the head if not done properly.
Jun 01, 2009 | Sony Handycam DCR-TRV260 Digital Camcorder
Thick stripes on the recording on mini dv tapes
Stripes are either caused by -
Bad tape - try a new tape
Dirty tape head - can it be cleaned? Cotton wool bud and some metho?
Electronic fault.
Try a different tape first.
If that doesn't help, clean the head. Is it under warranty?
Apr 25, 2009 | Canon Elura 60 Mini DV Digital Camcorder
Gray horizontal lines in playback mode
Gray horizontal lines across the screen in playback is symptom of dirty / clogged video head and you need to use good quality mini-dv video head cleaning tape to clean video head.
Mar 16, 2009 | Sony Handycam DCR-TRV33 Mini DV Digital...
LCD shows stripes thus the picture is not complete
Mine was similar - with vertical black lines on playback. Visit Bristolcameras.co.uk, enter your make and model and ask for a head cleaner. They sent me one within 4 days and that was over the Christmas period. Reasonably priced too (£3.50 + p&p) and the whole head cleaner can be used up to twice once the tape has gone from beginning to end.
Jan 03, 2009 | JVC GR-D395 Mini DV Digital Camcorder
Wont record anything to MiniDV tape and A/D randomly working
Sorry about delayed reply as I just saw it.
Its known problem of ccd imager in Canon ZR85 camcorder and ccd imager needs to be replaced.
Canon will repair your camcorder free of cost as per announced scheme for ccd imager issue.
Click Canon CCD Advisory for details, how to get free repair.
Regarding can't see picture or time code in playback, it is problem of dirty / clogged video heads. Use good quality video head cleaning cassette to clean heads and hope camera will show playback picture.
Good luck.
Nov 19, 2008 | Canon ZR85 Mini DV Digital Camcorder
Panasonic PV-GS2 Mini DV Digital Camcorder Logo
414 people viewed this question
Top Panasonic Video Cameras Experts
Kenneth Walker
Pieter Vleeshouwers
Pieter Vleeshouwers
Marvin
Marvin
Are you a Panasonic Video Camera Expert? Answer questions, earn points and help others
