The most likely causes are a bad door switch or a problem with the control panel assembly. You can find critical safety information plus our information file on checking and replacing door switches at our site, via our poisting here: http://tinyurl.com/yzjozk If you need control panel repair, we do that for $32.50 nationwide.
According to the manual this is how to set clock.
To set the clock, press "Clock" once or "Timer/Clock" twice (depending on your keypad).
The colon symbol (:) will flash.
Enter time of day. The time appears in the window; the colon continues to flash.
Press "Clock" or "Timer/Clock" again - colon stops flashing; time of day is set.
If you need the manual it is on link below.
http://service.us.panasonic.com/OPERMANPDF/NNH624-SET%20UP.PDF
Good Luck
Four of our number pads will not work. Cancel/Off button and our fan will also not work. We took the panel off but got confused with all the wiring
What is wrong? :(
