Question about Toshiba MW27F51 27 in. TV/VCR/DVD Combo
Toshiba CX32G60 1/2" vertical inward bow center of video
The unit was made in 1997, the picture is great except for black bowing on each side of the video. The picture starts off fine at the bottom and top, but in the middle of there is a 1/2 black bow. Is there an ajustment or is it a voltage problem?
Thanks!
    Sergeant:
    Champion:
  • 346 Answers
Change the electrolytic capacitors in the vertical section of tv. you do need a qualified tv tech to do this repair for sure
Posted on Jan 12, 2009
When the bow is pulled across the strings there is no sound just a quiet muffled noise?
These are noted for NOT being prroperly setup!
Check the following:
The bridge should be centered within the length of the "f" holes... usually there is a slight "v" in the middle of the "f" holes.
The Back (side toward the tailpiece) should be perfectely vertical relative to the top surface.
Look into the "f" hole on the treble side. The sound post should be about 1/4 inch toward the tailpiece from where the bridge is located. The post should be vertical between the top and bottom inside.
The rest depends on the quality of the strings and the bow. The bow needs to be rosined.
Luthiers often don't want to work on low end vilins as they can't charge much...
Use google to find stuff about setting up a violin. There is a mass amount if information on the web, and probably some help on you tube as well.
Sep 07, 2010 | Maxam Violin
Center bow on picture top and bottom with 1" black showing
Projection TV2_bing.gif sets have several common problems listed below.
Problem #1) Convergence
Symptoms:
  • Screen Looks 3D
  • Colors wont align
  • Screen may look distorted
  • No Audio/Video - TV2_bing.gif makes a chirping sound.
Problem #2 CRT Fluid has clouded over. Symtoms
  • Dull looking video
  • White looking video
  • Halos around objects
  • Red/Orange looking video
You can see some examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Mar 06, 2010 | Toshiba TN55X81 55" Rear Projection...
Pitney bowe 9920, incoming faxes have black vertical columns on each side, with white or normal print in center.
Have you changed the toner cartridge? Often the disposal part of the image unit gets full and leaks out when the cartridge is reaching the end of its toner supply. This will leave black messy streaks on paper, and also make a mess inside the machine. Look inside the machine, if there is a mess, it is the cartridge.
Jan 13, 2010 | Pitney Bowes Office Equipment & Supplies
Sony trinitron picture bowed
YOU MAY A PINCUSHION PROBLEM...SEE A TECH....CUSTOMER CONTROLS WILL NOT CORRECT THIS !
Dec 21, 2009 | Sony FD Trinitron WEGA KV-36XBR800 36" TV
Borders bowed inward,blurred red,blue, & green
the next time it is not working go into the customer menu with remote and call up the convergence grid and look---there---if convergence is way off and or comes and goes---this set uses 2 Stk-392-570 ic's and it is quite common to see them become intermittant.
Aug 03, 2009 | Mitsubishi WS-65809 65" Rear Projection...
I have a Toshiba CX32D60 with sides of screen bowed inwards ( narrow in the middle). Sound bar raises and lowers - sound audible only, close to the plus (+). Any help will be appreciated. Thank You.
You need to adjust the Horizontal Pincushion adjustment of your TV. That will fix the "bowing" which is actually Pinning.
Check the audio source to your set.
Mar 06, 2009 | Toshiba Televison & Video
TV Turning on and off, left side of picture is not lining up, bowed in center
Most likely you had a power surge issue that caused the tubes in your crt projection to malfunction. I would recommend having a service call done to find out the issue
Apr 22, 2008 | RCA P61960 61" Rear Projection Television
Weird problem not convergence
Mine is doing the exact same thing! have you found a fix yet?
Apr 23, 2007 | JVC AV-48WP74 48" Rear Projection...
Toshiba MW27F51 27 in. TV/VCR/DVD Combo Logo
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
