Question about Astar LTV-2701 27 in. HD-Ready LCD Television
Tv not working at all
Tv not working after we moved to another place
  • Shuggy O'Donnell
    Shuggy O'Donnell Dec 05, 2008
    I have same tv.Noticed in the last few months that it took a while to heat up to get a picture,now we don't get picture at all-and no sound.It is 2 years old.Can a repair man fix this?
    Problem Solver:
  • 28 Answers
Yes, your tv can be fix as long the power board is not burned. other than that anything can fix. any question call 323-767-6030.
Posted on Dec 09, 2008
BOSE LIFESTYLE TV SENSOR PROBLEM
Usually on any equipment with a remote---if you hold remote real close and it works you have either a dirty lens for the receiver or a defective infrared receiver in the unit-----odd that moving things would cause this.
If it is only the on/off function having a issue--that would rule out both of the possible solutions I suggested.
Be sure batteries are new/good and no indirect light is hitting front of unit where receiver is located.
May 18, 2012 | Audio Players & Recorders
What to do? help!
I would like to be of more service, But might only be able to help a little. on the TV's motherboard(if you will) there are dry joints, when ever these over heat the TV will turn off, usually hitting it will make it work for a while because the dry joint moved back in to place, then over heats again and joint moves out of place. Not shore if this is the problem with yours but you can take it in to consideration...
Feb 15, 2012 | Cell Phones
I have a 65H84 model TV and plan on moving it to a different room. This TV was in place when we bought the house from previous owners. Does the unit come a part in two sections for easier moving? Thank...
No,this thing come in as a whole tv unit,dosen't come aparts.U check the tv,see if it work,before going all the troubles moving it to another room.These DLP tvs design are notorious for it tv convergence problems and DM power supply board intermittently shutdowns alots.It bulky design and not work for free DTV over the air.
Feb 08, 2011 | Toshiba 65H84 65" Rear Projection HDTV
Why wont my digital tv work now?
External antenna is not adequate. Need more and bigger antennas for digital TVs. Also, several BAD problems with digital TVs - including weaker signal, picky signal, inability to use in a moving vehicle (kids can no longer watch TV while moving from place to place). More expensive receivers, not normally useable in remote places (like you could with analogue).
Rarely, two or 3 antennas on a vehicle will allow for some reception in a slow-moving vehicle - otherwise, portable digital TVs are useless.
Oct 20, 2009 | Jensen VM9510 Car DVD Player
Big screen tv turns on and off on its own!
Your TV is being overheated by the location it is placed. try moving it in an airy area and see if the problem still occurs. The turning on and off is a response to overheating sensors in the TV housing and if not rectified it could malfunction and may cause burnout, a possible risk of fire.
Sep 18, 2009 | Proton MM2701VT 27" TV
There is a discoloration on the sides of the tv. there is like a color of purple and green and makes the picture blurr looking- Guest
This is most likely because you have an unguarded speaker too close to the T.V. If you have a speaker close to the television, try moving it around a little to see if the discoloration goes away. If that doesn't work, you can try moving a large magnet around the edge of the screen to move the CRT guns back into place. Best of luck.
Aug 10, 2009 | Sony KP-46WT500 46" Rear Projection...
Tv remote control does not work with tv
some zenith ha tiney slide sw on back apron. in linecord area.
Dec 02, 2008 | Zenith B32A34Z 32" TV
My tv the bolbs have moved out of place
I am assuming you mean bulbs. Typically the bulbs do not just move out of place on there own. Did the tv take a sharp impact or did some one hit the tv hard enough to move it. The bulbs are held in place with plastic sleeves that are typically held in place with 6 to 10 screws depending on the model. Your local repair shop may be able to assist you in renting the allignment tools for your bulbs. Typically the convergence chip goes and it gives the TV the appearance of the bulbs slipping and makes the tv look like the colors have seperated. One of the colors seems to have shifted to one side and doesn't line up with the rest of the picture. So check with your local dealer or write to the company and see ig your convergence chip is available and if you can rent the allignment tool.
Oct 23, 2008 | Televison & Video
Ps2 wont play
did you guys try moving the ting in the back like this try moving it in and out or around 86696c4.gifand if that doesnt work then try getting it checked out by sony or getting a tecnition to see it.
May 25, 2008 | Sony PlayStation 2 (PS2) Console
Astar LTV-2701 27 in. HD-Ready LCD Television Logo
44 people viewed this question
Top Astar Televison & Video Experts
Jaime Hernandez
ted dux
Are you an Astar Televison and Video Expert? Answer questions, earn points and help others
