Question about Toshiba 43H71 43" Rear Projection Television
TV turns off then on again every 5-15 minutes..help please!
My Toshiba 43h71 turns off and then back on again every 5-15 minutes. I took it to a licensed Toshiba repair shop and they replaced the convergence IC and then when that did not fix the problem gave up and gave me my money back and said they cannot fix it. I am frustrated and saw that others that own rear projection TV's have had the same issue. One Samsung owner with a similar problem said a repair guy came and flipped some sort of safety switch on his TV that stopped the problem. I am so frustrated I am looking for a soultion so my TV life can be normal again. Thanks!
I seem to have a similar problem with my Toshiba, except I will lose my picture shortly after turning it on. It does not power down, I just lose both picture and sound. The power indicator flashes. I opened it up and vacuumed out the set and it seemed to work for a brief period. I have also noticed too, that if I jar the set it will come back on...any suggestions?
Posted on Feb 08, 2007
    Sergeant:
  • 308 Answers
It sure sounds like a solder connection opening up after the set warms up enough. If that was the problem you should be able to get it to ace up by jarring it with the palm of your hand. (Don't get carried away and hurt yourself or the set). If jarring the set gets it to cut off, I can't imagine why the repair shop couldn't find the problem. If another shop is nearby, authorized or not, you may want to give them a try. If no amount of jarring the set will get it to act up, then it could very well be not worth repair due to the amount of time that would be needed to localize the circuit that is intermittent.
Posted on Jan 28, 2007
My Toshiba 32wlt58 cuts out every ten minutes.
I have just had that problem. Repairer said it was a chip in the power supply. Just got the set back this morning, ok for about 6 hours then cut out. Felt quite hot on LHS Will switch on again after a while, then cut out again. Suspect overheating problem took out PSU chip. Chip replaced but original fault still present
Oct 04, 2009 | Toshiba 32WLT58 32 in. LCD Television
Toshiba tv screen goes black every 5 minutes with sound still on
Is it ok when you watch regular TV thru the cable or sat?
Jun 16, 2009 | Toshiba 46HM95 46" HDTV
Blue Shadow
A qualified tech should replace both STK392-110 convergence IC's with Toshiba or Sanyo brand.............T.
Jul 24, 2008 | Toshiba 43H71 43" Rear Projection...
Picture blurry
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
try doing a magic focus
Dec 10, 2007 | Toshiba 43H71 43" Rear Projection...
43H71
If you're talking about the STK392-100 convergence amps, the repair manual is not a great deal of help.
Here are two websites I found helpful:
http://www.repairhelper.com/tv_board_detail.asp?identity=3809
Good luck.
Nov 18, 2007 | Toshiba 43H71 43" Rear Projection...
43H71 43 in
Look up and read about the convergence amplifiers on this website. I just helped a friend repair his 53H71. We replaced the STK392-110 IC's on the signal board. The shop quoted him $400 for the repair. We replaced them for $35. If you're not comfortable soldering then this might not be a good repair for you to try. Good luck.
Turns on, sound comes out, turns off, no picture
You have a short in the tv.
I would recommend calling a repair man.
You may be able to find someone at this website.
Jul 30, 2007 | Toshiba 50HM66 52" Television
Tv will not turn on
it is a symtpom of vertical failure in circuit..its either loose connected part or blown up ic in vertical section but most of the time its just a dried up capacitors 100uf/50v 1000uf/25 and 2 2.2uf/50v
Mar 18, 2007 | Toshiba 43H71 43" Rear Projection...
Toshiba 43H71 43" Rear Projection Television Logo
59 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
