Question about Audiovox FP1510 15 in. LCD Television
Auto Scanning My TV automatically changes channels, its might be on a scan mode. It is not on auto program and I cant figure it out. Sometimes it will stop for a few minutes and then just continue for no reason. I erased all the other channel options but it just keeps clicking on and off. I need it to just stay on one channel to use my satelite.
    President:
  • 1,284 Answers
Try unplugging it for 2 minutes then se what happens. Make sure that none of the buttons on the TV or remote contol are stuck (especialy if remote is near TV).
Posted on Feb 07, 2007
If there is no channels after scanning is it the outside antenna?
Do you see any channels [as a glimpse], during auto-tune. If you see them for a moment during channel auto scan, and do not store them in the TV memory, after the channel scan has been finished; the fault is with the TV itself. If you do not see that glimpse of programs during channel auto scan, there are two possibilities.
1. The tuner of the set is faulty.
2. The set do not get any signal to process [might be antenna].
Aug 14, 2016 | Televison & Video
Run channel auto scan
The auto scan feature scans the various channel frequencies looking for a signal. Weak signals may be picked up on one scan and missed on the next. Check your antenna or add a antenna power booster and try again.
Sep 18, 2013 | Sony BRAVIA Televison & Video
I have a Curtis 24 inch Full HD LCD TV 2425A never used Trying to set it up and their was no book in the box it says to run Channel Auto scan .it is hooked up to Dish satelite ant. .to run the auto...
Used the tv remote go into tv Menu goto SETUP go down Ch. enter pick CABLE and enter again.Tv now will go into auto scanning for CABLE channels.After the auto scan done for the CABLE channels are finish.After this u will able to go to channel 60 to used the dish remote.
Apr 24, 2011 | Curtis Televison & Video
How do I retune my Panasonic Viera TV?
Hello
To tune your Panasonic Plasma to on air TV channels do the following:
Connect the antenna connection to its antenna in at the back panel.
Automatically searches and adds available channels to the memory.
Select "ANT in"
Select Cable or Antenna Select "Auto"
Select a scanning mode
Auto channel setup
Select "Auto program"
Select "ANT in"
Select "Auto"
Select scanning mode (ALL channels/Analog only/Digital only
Start scanning the channels
Available channels (analog/digital) are automatically set.
All channels: Scans digital and analog channels
Analog only: Scans Analog channels only
Digital only: Scans Digital channels only
Confirm registered channels
If OK is not pressed after selecting "Apply", the channels will not be saved.
The channel will be saved when no operation is performed for 60 seconds and
the "Manual program" menu will also exit automatically.
If you perform scanning more than twice, previously saved channels are erased.
About broadcasting systems
Analog (NTSC): Conventional broadcasting
Digital (ATSC): New programming that allows you to view more channels
featuring high-quality video and sound
[Use "UP ' DOWN ' RIGHT ' LEFT] AND 'OK"] keys to selcet and proceed.
Mar 07, 2011 | Panasonic Viera TH-42PZ80U Plasma TV
We can't get any of the channels don't know where to start from menu area
Hello
You just do autotune to receive all channels. In this mode TV will tune through the entire channel band automatically, and finally will stop tuneing, and will show the first channel receved. You must be patient for these time. about two or three minutes, without disturbing is process. The tuning process follows.
Auto Tuner Setup
In Auto Tuner Setup, the TV automatically scans
t h rough all available channels, memorizing the active
ones and skipping over blank ones or channels with
weak signals. This means when you scan (using the
CH A N N E L +/- b u t t o n s ) you will receive only clear,
active channels
P ress the ME N U b u t t o n
Press UP or DOWN buttonTo AUTO TUNER SETUP
Press Right or Left button to operate
Press Vol+ or Vol (--) to choose CABLE or AIR
Press UP or DOWN button to move to START
Press Right or Left Button to start Auto Tuner Setup
Tv will show "NOW PROGAMMING" display.
Programming will take approximately 1 to 2 minutes.
After all it will show
PROGRAMMING OVER
Some cable systems experience interference from radio frequencies on cable Channel 95. You may delete this channel from
your scan by removing the "X" next to it on the Channel Summary screen.
Nov 29, 2010 | JVC AV-27120 27" TV
Can you scan photos on the Epson DX6000 and save the image to the computor? If possible how do I go about it?
Starting a Scan With EPSON Scan If you want to scan an image and save it directly to a file, you can start EPSON Scan as a “standalone” program.
step_1.gif Place your document or photo on the scanner. See Placing Documents or Photos for instructions.
step_2.gif Do one of the following to start EPSON Scan:
    Windows:
    Double-click the EPSON Scan icon on your desktop.
    Or select Start > All Programs or Programs > EPSON Scan > EPSON Scan.
    Mac OS X:
    Open the Applications folder and click the EPSON Scan icon.
    The EPSON Scan window appears.
step_3.gif If the Mode setting in the upper right corner of the window is set to Full Auto Mode, click the Scan button. For instructions on selecting optional settings, see Using Full Auto Mode.
01.gif mark_no.gif Note: 01.gif 01.gif To change scan modes, see Changing the Scan Mode.
step_4.gif The File Save Settings window appears. For instructions on selecting options, see Selecting File Save Settings.
cj35003e.gif step_5.gif When you are finished selecting File Save Settings, click OK. EPSON Scan starts scanning in Full Auto Mode.
step_6.gif The scanned image is automatically saved in the specified location.
    If the Open image folder after scanning checkbox is selected in the File Save Settings window, Windows Explorer or the Macintosh Finder automatically opens to the folder where the scanned image was saved.
Please follow this link for same manual with screenshots:
http://support.epson-europe.com/onlineguides/en/dx6000/html_s/scan1_1.htm
Hope it helped.
Nov 22, 2009 | Epson Stylus CX6000 All-In-One InkJet...
Cant turn the tv to channel 3
Go to the Menu setting, and do a auto channel scan, it will automatically program it to NOT skip 3.
Nov 25, 2008 | RCA Universal Remote 3 Device Remote...
Emerson 20 inch flat screen tv problem
i had the same problem with a 32 inch and i kept "clicking" the channel changer on the remote to force the tv to go to another channel (that had previously been selected during the initial auto scan) --- still trying to figure out why the tv locks onto the scanning for channel
Mar 26, 2008 | Televison & Video
Audiovox FP1510 15 in. LCD Television Logo
194 people viewed this question
Top Audiovox Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you an Audiovox Televison and Video Expert? Answer questions, earn points and help others
