Question about Dryers
I have DE06 Fisher Paykel Dryer, tured on it makes a hum
Was working fine, got a load out and closed door and pushed start, it makes a hum but does not start.
    Sergeant:
  • 217 Answers
Dryer won't run, but hot air blow and humming when turned on
Belt is off, idler is off or broken. Replace the belt and idler. Make sure it is installed correctly with tension on the belt.It has stretched to the point it no longer can carry the load. Should consider replacing the idler at the same time.
 It will take care of your problem
Posted on Nov 30, 2008
  • 163 Answers
Have you checked the lint trap? some models have a fire safety feature that wont allow operation iif trap is full
  • Dryers Master
  • 19,396 Answers
TRY FIRST UNPLUGGING THE POWER CABLE FOR TEN MINUTES.
iF THERE IS HUMMING NOISE IT CAN BE A STUCK PUMP OR A FAULTY CONTROL PANEL.
  • Ginko
    Ginko Nov 30, 2008
    Try first unplugging the power cable for ten minutes, so to reset the appliance.
    Check inside if the drain hose is blocked or there is water inside the machine, in this case free the drain system from dirt.
    Check also that there is water coming from the power supply.
    Restart the machine, and see if you get the noise again, in this case let me know, it can be a faulty control assembly, or a problem with the motor or drain pump.
  • Ginko
    Ginko Nov 30, 2008
    Sorry I posted here the solution for a washing machine problem that was opened elsewere.
    In your case , do the unplug , as suggested by boscia, check the lint trap, as suggested already, and clean the lint filter.
    If you still get humming noise and the machine does not spin, a technician should take it apart and check the belt and the motor, if they are fine, then it is a faukty control assembly.
Machine stopped while running i fear an unbalanced load, no power ,this is an elba top load.
Electric dryer no start does nothing
Check dryer Terminal block prongs both outside prongs should give combined 220, and 110 each if u check 1 outside & 1 center (ground) prong. Also check house electrical outlet for full voltage.
CHECK THERMAL SHUT OFF THERMOSTAT USUALLY LOCATED ON THE BLOWER. for OHMS or resistance with a meter. Should show a closed circuit. Ohms WHEN THIS FUSE BLOWS IT WILL SHUT DOWN EVERYTHING.
NEXT Test the PUSH start switch with meter for OHMS. Should show OHMS when pushed in or on start, and no ohms or infinity when in off position.
If you hear a humming/clicking sound from motor area you more than likely have a bad motor.
Try this test out to see if u have weak windings or relay/capacitor on motor.
Open the dryer door and turn by hand the drum while machine is on ON position. And you or someone else presses the door engagement switch in. If it starts up then u have bad windings
Another thing to check is the belt safety switch. With a multi meter.
Especially if u just replaced the belt. The belt safety switch is attached to the Tensioner and motor. IT LOOKS LIKE A DOOR SWITCH SOMEWHAT a little black pc of plastic with 2 prongs going into it. Sits at bottom of motor. Under the Tensioner. Attach meter clips to the 2 prongs on switch, Then when the little white push button is pressed in it should show continuity and none when released.
Lastly check ur DOOR SWITCH for continuity with a meter when the button is pushed in the (on/Door closed position,) it may have gone bad.
https://www.youtube.com/watch?v=sTRP6kHqAFs
Nov 16, 2014 | Fisher Paykel Fisher & Paykel Elba 3.7 cu...
How do you get the front panel off a fisher paykel dryer to replace the felt seal
my F&P front load dryer would not start - it would hum when I pushed the start button. After trial and error taking the top off, then the front panel with the door I found the lint exhaust was completely blocked. After doing a thorough cleaning of the dryer and putting it back together it worked! (note: DE60 Elba dryer)
Jul 14, 2014 | Fisher and Paykel DE09 Dryer
Dryer will come on then click off, if you hold the button it will run and heat up model DE06
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Jun 25, 2011 | Fisher and Paykel DE06 Electric Dryer
Dryer starts then clicks off will continue to run and heat up if button is held model DE06
heatman101
My fisher and paykel dryer ( mod# ED56 ) wont start, power is on
I had this same problem with my Dryer. It is making the few quick beeps because it thinks the door is still open. Near the bottom of the opening to the dryer there is a sensor switch that gets pushed in when you shut the door. Try holding the switch in with a knife or something and then start the dryer with the door open to check if that is the problem.
After i did this, i closed the door and my dryer started as normal.
Aug 11, 2009 | Fisher and Paykel DEGX1 Electric Dryer
Fisher&Paykel dryer, ball bearings in the dryer!!
have a service tech replace bearing or do it yourself.
Jun 03, 2009 | Fisher and Paykel DE06 Electric Dryer
Squealing Fisher Paykel Dryer DE05-US2
dryer's have a long belt that runs around the drum. a common culprit is an idler pulley on the belt tensioner. you can take off the front of the dryer and oil it for a temp fix. it will probably need to be replaced
Dec 16, 2008 | Fisher and Paykel DE06 Electric Dryer
When I turn on our Fisher Paykel DE06 dryer it just hums.
You most likely have a broken belt. If not it is the main motor.
Dec 03, 2008 | Fisher and Paykel DE06 Electric Dryer
How to replace belt on Fisher Paykel Electric Dryer
Yes hello, I just wanted to know what belt a fisher and paykel dry model# DGO5-USO take? Thanx!
May 18, 2008 | Fisher and Paykel DE06 Electric Dryer
Dryers Logo
71 people viewed this question
Top Dryers Experts
Marvin
Marvin
