Question about Sony KDF-E55A20 55 in. LCD Television
Power Led Flashing red 6 times....
The manual shows nothing for the led flashing 6 times. It shows that three flashes indicated the lamp cover is loose. My T.V. is off, will not turn on. When power button is pressed it flashes green and then back to 6 red flashes. Any help? thanks
  • 3 more comments
  • Stephen Madrid Jan 26, 2007
    Hey thanks for your tips.....after posting this I did more investigating online and found other people with the problem also stated it was the thermofuse.
    Called "sony support" HA.....think it was some dude in his moms basement with a manual like mine. It's out of factory warranty so it's a good think I had 3 years left from bestbuy. Repair guy came out and said 3 weeks to get the fuse. Hopefully it will be sooner sigh
  • Anonymous Dec 06, 2008
    I have the same problem... Sears said that the earliest they could get here was Dec 24.... I said great, just dont get in the way of Santa
  • thatda Dec 25, 2008
    Is there a permanent fix to this problem? I had this problem now twice in just over 2 years (every 14 months on the dot pretty much). I want this problem fixed for good, not just for another 14 months.
  • seses Jan 03, 2009
    no picture no sound hit power flashes green then red 6 times and loops
  • Anonymous Mar 16, 2014
    disconnected all connections, disconnected completely from power, restarts but powers down after some time repeats.
The thermocoupler fuse is what it is called by the way. i also saw that it could be the "power board" which could or could not be synonymous with the thermocoupler. anyway, again it is a common problem with these models. Scott Jackson, MS
Posted on Jan 26, 2007
I had this problem with my e55a20 and the same light sequence. the problem is simple. the fuse blew. it turns out the a20 and a10 models all have too simple a factory fuse and something about the placement of it being too close to the lamp which contributes to its overheating. if its still under warranty or not, call sony to get you in touch with the nearest repair facility for them to come housecall and replace it. the replacement is more advanced and will not go out again. that's what i was told. mine's worked fine ever since. the only bad thing was the waiting game in my case. sony support is a b**** to deal with mainly because they don't know anything about the sony products, obviously some outsourced phone support, but they CAN give you the number for your nearest service and repair facility. 1st i had to get the housecall to diagnose the problem, and my nearest facility is an hour away, my serviceman verified, the part was backordered, so i had to wait 3 more weeks or so and then schedule him back to my house. maybe you'll be luckier on the waiting game. when you finally do get the replacement fuse part, its only about 10 minutes for the repairman to replace it. good luck, Scott Jackson, MS
My 73" mitsubishi dlp WD-73827 turns off and has a red status light blinking. I have replaced the bulb and the heat sensor... any answer to what else could be the problem?
It is helpful to have the sequence of the blinking red light. This may help:
MODELS: WD-52627 / 52628 / 62627 / 62628 / 62827 / 62927 / 73727 / 73827 / 73927
Page 43
3. Error Code Operational Check
Note: The TV must be in "Shut Down" and not have been switched Off, to perform the Error Code Operational
Check. When the TV is switched Off, the code automatically resets to "12" No Error.
Pressing the front panel "DEVICE" and "MENU" buttons at the same time, and holding for 5 seconds,
activates the Error Code Mode. The LED flashes denoting a two digit Error Code, or indicating no problem
has occured since the last Initalization.
Note: The front panel buttons must be used, NOT those on the Remote Control.
• The number of flashes indicates the value of the MSD (tens digit) of the Error Code.
• The flashing then pauses for approximately 1/2 second.
• The LED then flashes indicating the value of the LSD (ones digit) of the Error Code.
• The Error Code is repeated a total of 5 times.
Example: If the Error Code is "23", the LED will flash two times, pause, and then flash three times.
4. Error Codes
The Error Code designations indicating malfunction, or no malfunction, are listed below:
POWER
LED
STATUS
LED
LAMP
LED
Power
Status Condition
Off Yellow Off Low
Power Excess heat. Check Lamp Filter
Off or On Off Yellow No
change
120w usage time over 7000 Hrs.
150W usage time over 3500 Hrs.
Off Off Blinks
Yellow
Low
Power Lamp Cover open
Off Blinks
Yellow Off " Filter Cover Open
Off Off Red Stby Lamp did not turn On
Off Blinks
Red Off Low
Power Fan Stopped
Off Red Off " Circuit failure (short or DVI
connector unplugged)
Abnormal LED Indications
Error Codes "DEVICE" & "MENU"
Error Codes Description
12 No error detected
22 Recovery from Reset
32 Lamp cover is Open
34 Lamp abnormality
35 DM Fan failed (Chassis Fan)
36 Exhaust or Lamp Ballast Fan failed
37 DMD Engine Fan failed
38 Lamp temperature abnormally high. Remove Lamp to check filter.
39 DMD temperature abnormally high
41 Short is detected (Standby Power Supplies)
42 Lamp Fan failed
44 DVI cable between Format and Engine disconnected
46 DMD Temp. Sensor not detected (check DT connector))
47 DM Temperature too high
48 Engine power supply short detected
51 Speaker Drive circuit short detected
52 HDD excess temperature (V30+ & V31 only)
55 HDD Fan Stopped (V30+ & V31 onlyt)
Jul 18, 2014 | Mitsubishi WD Televison & Video
Kdf-e42a10 i have no power ,only red led 3 time flashing
3 times red light flashing indicates that lamp cover has not been fixed correctly in tv after lamp replacement. Please make sure lamp cover is fixed securely after lamp replacement.
Thanks.
Feb 05, 2011 | Sony KDF-E42A10 42 in. LCD Television
Tv desn't turn on,power light just flashes ten times and then stops and then again
Error Indication Information
Error No. Error Information ERROR DESCRIPTION LAMP LED OSD LAMP OFF
(Note 3) (Note 4)
POWER LED TEMP LED
Note:
1.When any of the above errors has occurred, the LED will flash as shown above every 5 seconds.
2.When two or more errors have occurred at the same time, the LED will light up or flash as shown above, and then
change to another every 5 seconds in turn.
3.Warning OSD appears when the Air Filter is clogged 90%, accumulated operation time of the Lamp reaches 5000 hours,
or accumulated operation time of the Air Filter reaches 400 hours.
4.LAMP OFF: The LED will flash right after the Lamp goes off.
5.IC2301 is mounted on LCD Main C.B.A. which is included in the Projection Unit.
6.IC6001 is mounted on TV Main C.B.A.
Clogged air filter
more than 90%
15)
16)
17)
18)
1)
2)
3)
4)
5)
6)
7)
11)
8)
9)
10)
12)
13)
14)
- flashes 5 times -
every 5 seconds
IC2301(pin82) detects the clogged air filter, then indicates the
error when the air filter is clogged 90%.
Front Fan stop or
Lamp Fan stop
flashes orange
once every
5 seconds
IC2301(pin12) detects the Front FAN stop or Lamp
FAN stop, then indicates the error when the Front FAN
or Lamp FAN is stopped.
Lamp Cover open
Temperature Sensor
short or open
flashes orange
twice every
5 seconds
flashes orange
3 times every
5 seconds
flashes green for
140 seconds.
flashing red for
60 seconds.
light up red.
flashes once
every 5 seconds
flashes once
every 5 seconds
flashes red for
10 minutes
flashes once
every 5 seconds
Abnormal
Temperature
flashes twice
every 5 seconds
flashes twice
every 5 seconds
Request for Lamp
Replacement - - lights up
Power Ballast Error
(abnormal
Lamp voltage)
flashes 3 times
every 5 seconds
Power Ballast Error
(abnormal
temperature)
flashes 4 times
every 5 seconds
Power Ballast Error
(other causes) - -
Request for Filter
Cleaning -
Abnormal Voltage
on 16 V line of
LCD Main C.B.A.
flashes twice
every 5 seconds
flashes twice
every 5 seconds
Abnormal Voltage
on 14 V line of
LCD Main C.B.A.
flashes 3 times
every 5 seconds
flashes 3 times
every 5 seconds
Abnormal Voltage
on 7 V line of
LCD Main C.B.A.
flashes 4 times
every 5 seconds
flashes 4 times
every 5 seconds
IC2301(pin76) detects the Lamp Cover Unit condition
(open or close), then indicates the error when the
Lamp Cover Unit is open.
IC6001(pin85) detects the Duct FAN stop, then
indicates the error when the Duct FAN is stopped.
IC2301(pin74 and 75) detects open or short of the Temperature
Sensor (R2911) on Front Thermistor C.B.A., then indicates the
error when Temperature Sensor is open or shorted.
(The error is not detected for 1 minute after Lamp ON.)
IC2301(pin74 and 75) detects the temperature attached near
the Front FAN by the Temperature Sensor (R2911) on Front
Thermistor C.B.A., then indicates the error when the
temperature becomes more than 43 C (109 F).
IC6001(pin86 and 87) detects open or short of the
Temperature Sensor (R2901) on Lamp Thermistor C.B.A.,
then indicates the error when Temperature Sensor is open or
shorted.
(The error is not detected for 4 minutes after Lamp ON.)
the Lamp by the Temperature Sensor (R2901) on Lamp
temperature becomes more than 60 C (140 F).
IC2301(pin11) detects the error of LCD Power C.B.A.,
then indicates the error when the temperature fuse
(117 C)(243 F) in LCD Power C.B.A. is open.
IC2301(pin11) detects the error of LCD Power C.B.A. and Lamp,
then indicates the error when an inner malfunction of LCD Power
C.B.A. occurs, the Lamp voltage becomes more than 130V or
less than 30V, Lamp current becomes more than 5A, or the Lamp
is cracked.
IC2301(pin11) detects the error of the Lamp, then indicates the
error when the Lamp is short-circuit.
IC2301(pin48) detects +16V line voltage on LCD Main
C.B.A., then indicates the error when the voltage
becomes less than +13V.
IC2301(pin47) detects +14V line voltage on LCD Main
becomes less than +11V.
IC2301(pin45) detects +7V line voltage on LCD Main
becomes less than +5.7V.
IC2301(pin44) detects +3.3V line voltage on LCD Main
becomes less than +2.5V.
flashes 3 times
every 5 seconds
flashes 4 times
every 5 seconds
Abnormal Voltage
on 3.3 V line of
LCD Main C.B.A.
- flashes 5 times
every 5 seconds
Forced cooling
The failure of Lamp
light up
Temperature Sensor
short or open
Abnormal
Temperature
Duct Fan stop -
When accumulated operation time of the the Lamp reaches
5000 hours, OSD (replacing the Lamp) appears on the screen.
Note: The Lamp time is stored in EEPROM (IC2305).
When accumulated operation time of the Air Filter reaches 400
hours, OSD (cleaning the Air Filter) appears on the screen.
Note: The Filter time is stored in EEPROM (IC2305).
During forced cooling, this indication is indicated.
IC2301 (pin11) detects the failure of light up processing of
the Lamp, then the POWER LED is changed as follows.
1) POWER LED flashes green for 140 seconds (while turning on).
2) POWER LED flashes red for 60 seconds (while cooling).
3) POWER LED lights up red (standby).
Note: If the Lamp will not light after attempting turning on the
power 2 or 3 times, the Lamp, the LCD Power C.B.A. or the
LCD Main C.B.A. may be defective.
Error Symptom Problem Possible Solutio
May 30, 2010 | Panasonic Viera TH-50PX80U Plasma TV
My Panasonic PT-60Dl54J tv shut itself off and the power button is now flashing red 6 times. What has happened, how do I fix it?
This is straight from the service manual (I'm not sure what the problem is but it sounds serious):
8.2. Power LED Flashing timing table
When an abnormality has occurred, the protection circuit operate and cuts the power supply. At this time, the defective line can be
identified by the number of flashes (red) of the power led indication at the front of the unit.
NUMBER OF FLASHES CIRCUIT MICRO PIN
1 LOAD SHORTAGE 92
2 OVER VOLAGE 93
3 FAN SOS 94
4 MAIN 3.3V 88
5 LAMP DISABLE 61
6 GC3FM-IIC IIC
7 GC3FS-IIC IIC
8 GC3I-IIC IIC
9 COLOR WHEEL STOP 110
Dec 06, 2009 | Panasonic PT-50LC13 50" Rear Projection...
No sound or picture, 2004 pt50dl54j
remove back panel. blow out all the dust from all the components except the fan on the right.
Vacuum out all the dust.
Have you replaced the lamp? that would help too.
There are 2 small red lamp. One indicates HEAT problem. The other one is the LAMP indicator.
Jun 13, 2009 | Panasonic PT-50DL54 50" Rear Projection...
Tv went off while watching a program power standby red light blinks 6 times then pauses then repeats tried unplugging unit waiting a few minutes then replugged same results nothing. can anyone help me ?...
Here's an excerpt from the Sony Manual online. And the link - http://esupport.sony.com/US/perl/webtree.pl?template=EN&mdl=KDF55XS955&content_id=68&category_id=11&problem_id=52
The POWER/STANDBY (red) indicator flashes three times
If your power/standby indicator is flashing in a pattern of three flashes, this may indicates that the lamp cover is not attached securely. Follow the directions in the Operating Manual under changing your lamp that related to closing and securing the Lamp Cover. Ensure that the Lamp Cover Door is securely fastened by tightening each screw.
The POWER/STANDBY (red) indicator flashes continously
If your power/standby indicator is flashing continuously, and the lamp cover has been secured, your TV may be in need of service.
The POWER/STANDBY indicator is lit up green (not flashing)
A sustained green light indicates your TV is on.
The POWER/STANDBY indicator is lit up red (not flashing)
A sustained red light from your power/standby indicator simply indicates that your TV is in standby mode. This shows you that your TV is ready to be turned on with the remote.
Is it the power light and not the lamp light? If the lamp light is flashing then replace the lamp.
Apr 07, 2009 | Sony Grand WEGA KDF-55XS955 55" Rear...
BenQ MP612c projector has three orange flashing lights
you can go to the BenQ website and download a manual for your particular projector. It should tell you what the lights indicate.
Feb 01, 2009 | BenQ (200NSH-LAMP) Projector Lamp for...
KDS-60A3000 new bulb gets 6 flashes of red led
Please put back lamp (bulb) cover properly and check as lamp cover is open/ not fixed or improper fix is also cause of LED flashing.
Jan 08, 2009 | Sony KDS-60A3000 60" HDTV
SONY 62 LCD GRAND VEGA HD TV
A three flash means you have not seated the lamp cover correctly. Try recolsing and relatching the lamp cover
Dec 21, 2008 | Sony KDF-42WE655 Television
Projector will not project light (Mitsubishi LVP-X80U) LCD Proje.
Hello toma_leonard,
First check your lamp to make sure it is seated properly in the socket.
Then check all of your interlocks (see your manual for locations), these are usually located on any hatches or doors that allow access to the lamp and or fan area. Once you check your interlocks make sure the filter and fan area is clear of dust, (some projectors have air flow sensors), and the recheck the interlocks. Once this is done , If the interlocks are not broken, or the lamp fuse blown, the projector should be working. If not it is the lamp that needs changing.
I know this may be expensive, however these lamps do go bad, as much as we wish they would not.
If you still feel it is not the lamp, have a technician check the voltage levels to the lamp and the levels of the control board circuitry.
I hope this helps,
Thank you,
Shuttle83
Nov 20, 2008 | Mitsubishi LVP-X80U Multimedia Projector
Sony KDF-E55A20 55 in. LCD Television Logo
505 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
