Dvd audio player volume too erratic
We have a low end magnavox dvd player MWD220F connected to a Maxent 42'' plasma monitor. The sound between the voice and the music on a dvd movie is overwhelming. to hear the voice we have to turn the TV volume way up, but when there is music it blasts us out. Is it the DVD player or what?
Agent Jon
  • 100 Answers
SOURCE: emerson dvd player - background sound lauder than dialogue
Greetings surfjax,
If you will allow me to make an assumption, you do not have a 5.1 surround system connected to your DVD player. This is a common experience with users of a standard TV or stereo receiver if a movie is being presented in 5.1.
In a surround sound system the center channel speaker provides almost all the vocal tracks while the side channels will provide music and some background noises. You'll still be able to hear the voices in your side speakers, but it will be muted and over powered by music or sound effects.
Some DVD players allow you to "Downmix" the surround signal to stereo. You might want to look around your sound setup on the DVD player or check your owners manual.
Hope this helps.
Jon
Go Ahead. Use Us.
Posted on May 22, 2008
SOURCE: no sound thru dvd player, but fine for tv and vcr
Just had the same problem and it is fixed for me. With NO DISC in the player go to the System Menu. Next Navigate to Preferences on the top of the screen.
You will set an option titled "Default". Select that and it seems to reset the player to default settings and fixes the sound.|
Posted on Jan 16, 2008
SOURCE: Can't hear the voices when I play a DVD, only the music
WE'VE HAD THE SAME PROBLEM SINCE WE MOVED AND DISCONNNED THE SPEAKERS?
IS IT POSSIBLE THAT THE SURROUND SOUND WAS NOT HOOKED UP? AND THIS COU\LD CAUSE THE PROBLEM?
Posted on Jan 19, 2009
ThaMp3Doctor
  • 8596 Answers
SOURCE: Can't hear sound on Windows Mediaplayer from DVD I recorded
I've been pondering this one for a day or so - at least two possibilities:
1) There is a mute/audio-off hotbutton inside Windows Media Player itself - click on it and see if the audio works. Alternatively, you can try playing a music file in Windows Media Player to see if THAT file has sound.
2) You need a better Codec - the free version of the K-Lite Codec has limited audio support. There are no easy answers to this problem. I frequently use my computer for converting VHS's to DVD, so I finally plunked down the $50 to purchase Nero 9 and all of its codecs. Before that, however, I used VLC Media Player (free) - it has DVD/VOB audio support.
As a side note, if you wanted to use your computer to convert the VHS's to DVD, you would need a plain-old VCR, a red/white/yellow cable, a DVD burner, and a product called the Dazzle DVD Recorder from Pinnacle. You can hook the VCR straight to your computer and burn away. To get the best experience however, I would also get a program like Nero, Roxio, etc. to do the actual DVD burning (although the Dazzle's native software is perfectly capable of doing the job).
-Tha Mp3 Doctor
Posted on Feb 15, 2009
bala31328
  • 71 Answers
SOURCE: Audio volume is low.
check out the wire connections or check out any problems in the battery.
Posted on Jul 25, 2009
HOW PUT CABLE IN MY MAXENT TV WITH OUT CABLE BOX
Is there anyway that i can connect my galaxyTab on to my Maxent Plasma Flat Screen monitor
Aug 26, 2012 | Maxent MX42X3 42 in. HD-Ready Plasma...
No sound with dvd connection
Check connections for loose contacts, and whether the audio in has been selected to connect the RC cables, and whether the output selected at DVD end is correct. Check for jammed buttons of volume or mute on remotes of both.
Aug 04, 2012 | Dell W4201C 42 in. Plasma HDTV
I how a 42 in maxent monitor. How do I hook up tv tuner?
the tuner or a set top box etc would have to be connected to one of the sets of audio/video inputs and that input selected.
Jul 17, 2012 | Maxent MX-42HPM20 42 in. Plasma HDTV
No sound on maxent plasma 42
Check its speakers, and audio output section circuits.
Jul 10, 2012 | Maxent MX-42EPM20 42 in. Plasma EDTV
Maxent MX42X3 42" plasma Monitor..
Are you sure that its the main A/Vboard coz it sounds like the main power supply issue to me. Anyways the mainboard is the large board usually located at the center of the tv. If you can remove the back cover of the tv and get me a high res picture of the tv I can mark the board for you.
Jun 03, 2011 | Maxent MX42X3 42 in. HD-Ready Plasma...
Maxent plasma tv mx-42hpt52 when switch on everything works well for about 5min then volume goes to max on its own and other fuctions stops working.
You need to have your main board replaced. It's unfortunate but even low voltage boards go bad. Try locating a Maxent website and email them to see where you can get parts from.
Mar 10, 2010 | Maxent MX-42HPM20 42 in. Plasma HDTV
What is Monitor Out on 42'' Hitachi plasma TV (42HDT50)
Monitor Out connects audio and video signals to an external monitor with corresponding inputs as noted in the document.
Mar 07, 2017 | Hitachi 42HDT50 42 in. HD-Ready Plasma...
Is there any way to connect basic cable to the tv without using a converter box or anything else
Recently, I dropped HBO with my cable company and there dont have a box. Since the Maxent 42 is only a monitor and doesnot have a tuner...there is no where to plug cable from the wall to the tv.
Solution...plug cable from wall to VCR/DVD and then use RCA cables (Red,White and Yellow cables) from output from VCR/DVD. works great.
Nov 22, 2009 | Maxent MX-42HPM20 42 in. Plasma HDTV
Magnavox dvix player to ilo 42
what are the modelnumbers on your divx player and your tv? if you are using svideo inputs do you have your audio cables hooked up? have you checked the volume on the player to make sure it is not muted?
once you supply more info i can help you further, until then, check your cables and audio settings on your divx player. and make sure all connections are in the right place
hope this helps
trin
Nov 16, 2007 | Televison & Video
Televison & Video Logo
32 people viewed this question
Top Televison & Video Experts
