Question about HP PSC 2510 All-In-One InkJet Printer
Hp psc 2510
When I try to print, the printer just gets stuck. No error message on the LCD, it just says "printing" and never prints. I've reset the printer numerous times. This fixes the problem short term. I can generally only print one document before i have to reset again. it doesn't make sense that the printer should be malfunctioning every day and that I should have to do all these resets over and over. Can anyone provide any guidance?
I dont know
i whant reset for printer all in one hp 2510
Posted on Mar 07, 2008
  • wasim222 Mar 07, 2008
    please please i am wasim ineed reset for all in one hp 2510
    the praplem the scaneer it's not move i dont know way please healp me healp please
Remove check print cartridges
Are you sure you are using genuine HP print cartridges - I know my hp printer will not print with refilled cartridges. I have also checked this site - it may help you
HP PSC 2510XI All-In-One InkJet Printer - "Remove check cartridge" issues ... Remove and Check Print Cartridges . The printer will not print. The message does ... www.fixya.com/search/p378796-hp_psc_2510xi_all_in_one_inkjet_printer/remove_check_cartridge www.fixya.com/search/p378796-hp_psc_2510xi_all_in_one_inkjet_printer/remove_check_cartridge
Feb 02, 2012 | HP PSC 2510 All-In-One InkJet Printer
My hp psc 2510 photosmart doesnt stop prnting. i have turned off power few times but as soon as it turns on start printing constantly.
This isn't the printer. You have to stop the print jobs from your computer. On the lower right of your computer screen there should be some icons, one of them will be a printer. Right click and select open, then you will be able to see what it is trying to print. Cancel the print jobs and your problem is solved.
Aug 10, 2010 | HP PSC 2510 All-In-One InkJet Printer
Align page not detected error on HP PSC 750 printer
Need to replace all print head with error or nozzles block
and try for alignment
once the page is printed it needs to be scanned to save alignment
if still get same message need to check for scanner functionality
Nov 08, 2009 | HP PSC 750 All-In-One InkJet Printer
HP psc 1310 - gave paper jam and print cartridge error. There was not paper jam and paper jam message went off. My son changed one of the print cartridges, although it still had ink in it. The error...
clean the rubber rollers of the printer and try to print. if it is still having the same problem. reset the printer by unplugging the power cord of the printer while its turn on. then plug the power cord back in. once the printer is on press and hold the power/on button and the size button. when the on button is flashing then release the buttons and try to print again
Oct 28, 2009 | HP PSC 2410 All-In-One InkJet Printer
Getting extra 1 inch margin on ''normal'' or ''best'' print
Hi - have you checked the settings for both the document(s) you are trying to print and the defaults for the printer? It could be that there is a default setting that is trying to override what you want to do. I can't think of a reason for it to act differently with different quality of print, unless the ink is running low - that can affect a document printing or not, but again, I would not think to this effect.
Some things to check on -
- Go to the control panel, open the Printers and Faxes folder, and right click on your printer.
Choose PROPERTIES. Make sure everything is set like you want it to be.
(If you are on a network of some kind, someone else's settings could be overriding yours. If you are not on a network, make sure "Do not share this printer" is checked on the sharing tab.)
-try to update the driver. Here is a good place to look -
http://preview.tinyurl.com/6bwuk8
I am assuming you have already actually checked for little scraplettes of paper that might be stuck near a sensor or an ink cartridge. I'd even pop the ink cartridges out and put them back in. Sometimes dust can build up on them if a printer isn't used often, or has been sitting for a long time.
Also, make sure you don't have a setting on your own computer to print out a blank sheet before a printing job. If your printer is actually run through an I/T department at work, they could have it set up by default to kick out a separator sheet to help keep orders separated.
I hope one of these things might work for you! : )
Nov 20, 2008 | HP PSC 2510 All-In-One InkJet Printer
The printer won't print.
problem with the pick up clean the pick up rubbers and something sucking in side can you tell me any folding end of the paper
let me know
Nov 09, 2017 | HP PSC 2510 All-In-One InkJet Printer
Samsung ML-2510 doesn't respond....
I solved this problem with windows xp but have yet to solve it with windows 7. what worked for me is hooking up the hp print server to my network switch and to the 2510. Then I installed the 2510 driver using the samsung exe and choosing NO when it asked about installing the driver without the the printer attached. The NO choice continues and installs the driver. Then run the HP printer wizard choose drivers on this computer when you get to that spot. Then choose the 2510 driver and finish up. You may now have 2 2510 installations and may need to delete the default one under printers and set the other as default. This worked on 3 different xp machines for me
Sep 24, 2008 | HP JetDirect EX Plus Print Server
Hp psc 2410 photosmart
marglet, Turn-off and unplug the printer for a couple of minutes...there may be improper setting stuck in the printer memory. then plug it in and try to print the envelopes..if that doesn't work...Make sure there aren't any custom print settings causing this. Lastly...Try updating the drivers. Download the latest drivers from the site. http://www.shopping.hp.com/webapp/shopping/search/search_request.do?pageName=HP+printers_land Good Luck, Tim
Feb 03, 2007 | HP PSC 2410 All-In-One InkJet Printer
HP PSC 2510 All-In-One InkJet Printer Logo
606 people viewed this question
Clive
Clive
