Question about Samsung RS2630SH Side by Side Refrigerator
Refrig side won't cool past 55 degrees
It was blinking yesterday, we did the unplug thing and now it won't cool, just stays between 54 and 57 degrees.
  • Anonymous Dec 02, 2008
    freezer is defrosting and freezer temperature light continues to blink. Tried unplugging and didn't work. Help.
  • mimimartinez Dec 28, 2008
    any ideas
  • 23 Answers
I am an authorized Samsung service center, and I have dealt with this ongoing design problem for years. The problem occurs when the unit comes out of the defrost cycle, not all of the frost has been removed by the defrost element and an ice bridge occurs at the top and bottom evaporator coil. There are sensors that send readings back to the main PCB during and after this cycle, They have to be replaced along with adding heat transfer clips for better frost meltage and air circulation.
Order the following parts through Samsung:: Fixer # DA61-03585A, Plate # DA61-03502A, Thermal Bi-metal # DA47-10160H, Sensor # DA32-00006W. Have these parts installed by a professional appliance repair company.
I hope this will fix your dilemma, Ward Appliance Repair.
Posted on Dec 29, 2008
My Hotpoint HSS25IFMD fridge quit cooling on the refrig side. It stays at 55 degrees. The freezer works just fine. Any thoughts?
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
Dec 27, 2010 | Refrigerators
I have a 3 yr old ge Profile side by side refridgerator model #psc23sgrdss with the following problem. on 3 occasions in the last 3 wks I've found the temp. in the refrig section very high ( 56 degrees and...
I had same issue this past week. Refrigerator up to 45 freezer up to 15. Ice would melt and then everything would get cold again. Ice formed on everything. Next thing you know it was warming up again. I knew the rubber seal on door flap that opens to let ice out warped during summer months because I keep it 78 in summer. Had that replaced today. Temperatures have gone back to normal and stayed ALL DAY (knock on wood). Check door flap seal sticking your hand up making sure you don't push in the water tab. You should be able to feel if it is warped/wavy like an old LP or not. Good Luck.
May 20, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Not cooling proberly. Unpluged unit for 5
return air ducts are frozen and need to be defrosted. unplug unit and with doors open , introduce warm air from a blowdryer for a couple of hours , the ducts that are frozen are behind the rear panel on the rear wall of the freezer
Oct 28, 2009 | KitchenAid Superba Architect KSCS25INSS...
Refrigerator not working, freezer works great
Yes, only one compressor. The refrigeration system actually only cools the freezer. Then there is a vent from the freezer to the refrigerator that allows the cold air to circulate to the refrigerator side. That little dial you turn to set the refrigerator temperature is actually only open or closing that vent. The dial for the freezer temperature is an actual thermostat that operates the compressor.
The temperature of the freezer should be between 0 and -10 degrees Fahrenheit. If it is in or near this range and the refrigerator is only at 55 degrees (the refrig should be at 38 to 45 degrees) then check for blockage or icing where the air from the freezer circulates into the refrigerator.
If the freezer is not in or near the 0 to -10 degrees then you have a refrigeration problem. First thing to do is clean the condenser coil on the bottom of the unit using rags and a shop-vac. Be careful of the wiring and tubing down there plus the sharp metal.
Unplug the unit before cleaning.
Otherwise, you'll need to call a refrigerator service technician to repair the refrigeration system for you.
If this helps you, please select YES to one of the first two ratings questions. Thank you, and Good Luck.
Oct 13, 2009 | Kenmore 52282 / 52284 Side by Side...
Cold but not frozen
23 years old ? That thing was costing you more than a new unit would cost for the past 5 years!
Assuming your airflows are good, Its time for a new refrigerator.
Aug 29, 2009 | Refrigerators
check to see if the fan by the compressor is working when the compressor is running if not you have the problem control board .....replace board
Jun 30, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Freezer and refrig not cooling right
The first thing you want to check is the defrost bi-metal switch and the defrost heater. Both of these parts are located behind the rear panel in the freezer. You will need to check continuity on the bi-metal
switch when it is cold. This is the nost common praoblem. If you get no continuity, replace the switch. You can also test the defrost heater the same way but, it does not have to be cold.
If both the switch and heater have continuity, you will need to replace the defrost timer.
May 21, 2009 | Refrigerators
Haier Wine Refrig runs to cold
change your temperature sensor, it's broken and it's going to down temperature
Aug 22, 2008 | Haier HVF042 Wine Cooler
Kenmore top freezer unit-refrig not cooling past 50degrees
check freezer for frost build up and if fan blowing, check condenser make sure clean, and fan blowing, check vents in refrig. make sure no blockage, freezer control should be in the middle setting, you can try turning that to Warmer freezer allowing MORE air to refrigertor side.
Sep 03, 2007 | Kenmore 64802 Top Freezer Refrigerator
Dose not get cold enough?
Does the compressor run or shut off when it gets to 55 &57? Leave unplugged over night and try again.. Let me know.
May 30, 2007 | Danby DWC283BLS Wine Cooler
Samsung RS2630SH Side by Side Refrigerator Logo
349 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
