Can not get the computer to boot up. I can get the windows xp home loading screen then flashes a blue screen and back to trying to boot
What error message are you receiving on the blue screen? if it resets to fast start typing f8 at boot and in the advanced menu, toggle down to do not restart on system failure. write down the hex code (0x00XXXXX) and report back. What version of windows are you running? have you tried to press f2 or f1 or whatever key it is to enter setup on your laptop @ boot and disable network boot?
If you need further help, reach me via phone at https://www.6ya.com/expert/joel_63c670a84e9f6a97
SOURCE: Trying to start my computer
http://www.hitachigst.com/hdd/support/download.htm has a Disc Fitness Test programme. It produces a floppy to boot from DOS into Windows. My Satellite 1110 has the same error message, PXE-E61. The BIOS shows "no HDD". The DTF found no fault on the HDD. (full test took 45minutes) Give it a try. I know, you need a working computer to down load it-- and DOS and a floppy drive on the faulty one. There are USB adaptors for floppy drives. Tomorrow I prise the 1110 apart and will clean all the cable and connectors. Good luck. Bryan
SOURCE: toshiba satellite p20, pxe-e61, pxe-mof
cable plug possible defective, if possible plug into another computer and see if error occurs. since you did not state OS go into the Device Manager and insure 'network adapter' has driver installed and working. Is there an external media hooked up?
SOURCE: Computer gives option for F2 for setup or F12 Boot Selection
Hit F12 and select last known good configuration
SOURCE: Pxe-e61: Media test Failure check
in order to load the Operating
system I request you to disable the SATA Native Mode in BIOS and then
load the Operating system. 1. Please perform the below steps for the same:
a. Restart your computer.
b. When
the F10 setup message appears in the lower left corner of the screen,
press the F10 key.
c. Locate ‘System Configuration’ and then select
‘Device Configurations’.
d. Under ‘Device Configurations’, select
‘SATA Native Mode’ and disable the same.
e. Save the settings and
exit.
Once the SATA
Mode is disabled, please install the Operating System in the normal
fashion using the Recovery CDs or the Operating System CDs that you
have. Before installing the same, you need have the SATA Controller
driver. Please follow the ’Installation Instructions’ in the SATA
controller driver link given below.
2. Download the latest “Intel SATA AHCI
Controller Driver” driver from the below mentioned link:
http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareDescription.jsp?lang=en&cc=us&prodTypeId
=321957&prodSeriesId=3356620&prodNameId=3356622&swEnvOID=1093&swLang=13&mode=2&taskId=135&swItem=ob-54270-1
Upon installing the same, please get
back into the BIOS and enable the SATA Native
Mode.
Note: The third-party information
provided is to help you find the support you need. This information is
subject to change without notice. HP in no way guarantees the accuracy
of this third-party information. The software manufacturer will provide
support for this software.
Please update your observation for us to
serve you better.
I
have also given you the link below for the XP Professional Drivers:
http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareIndex.jsp?lang=en&cc=us&prodNameId
=3356622&prodTypeId=321957&prodSeriesId=3356620&swLang=13&taskId=135&swEnvOID=1093
The above given information are
pertaining to HP 6710b Notebook PC. If you do not have the same, please
update the serial number for us to given you more information.
SOURCE: For Realtek RTL8101E/8102E PCI-E Ethernet
The error PXE-E61: Media test failure usually means the hard diskhas failed or the hard disk needs re-seating or the disk controller is faulty. First - re-seat the harddisk and reboot the computer. If this does not work then reboot and go to theBIOS configuration to see if the BIOS detects the hard drive. If it doesn'tdetect the hard drive then it could be faulty. Next - to determine if thehard drive is faulty, remove the hard drive and insert it into an USB hard drive adapter and connect it to a workingcomputer's USB port. If this computer cannot see itas an external hard drive and you cannot open the various folders and files,this confirms the hard drive is faulty. Then the hard drive needsto be replaced in the computer/laptop, Windows installed and the computer orlaptop's device drivers plus your programs etc. to get a functioningcomputer/laptop again.
