Question about JVC FS-S77 Micro 5 Disc DVD Audio/Video System Home Theater Shelf Systems (FSS77, FSS-77, FS-77, FS7... Shelf System
CD player is locked
I cannot unlock my CD player. There are 5 cd's stuck in it. When I hit to open the drawer it says locked.
  • katiekroshus Apr 08, 2009
    I have the panasonic SA PT750 and it will not open it says LOCKED so I can not open the disc changer or anything what do I do......
Hell Yes!!!  Thanks my friend - I haven't been able to use this thing for about 6 months.... You da man!
Posted on Oct 31, 2007
^^^above is correct, except you do the Stop + Disc 1 thing in Standby mode. Strange thing: Stop + Disc 2 in Stby mode turns on the fan.
Posted on Aug 20, 2007
On the main unit, press [stop] [disk1] at the same time. The display should then show "UNLOCKED" If this doesn't work, you may need to first disable the "save on" mode by turning the unit off (standby) and pressing [display] on the remote.
Posted on Aug 15, 2007
The Cds get stuck in the unit; unit won't play and cd drawer won't open
HAVE YOU tried to open the tray by the pin hole on the front with a paper clip
Jul 07, 2015 | Sony RCD-W500C 5-Disc CD Recorder
The display flashes "closed" and I can't open the cd drawer when pressing the open/close button. Is there a reset please ?
Try removing power from the unit, let it set two minutes without power and power it up again. See if the problem continues.
Make sure the cd drawer is complete closed and flush with the front panel. If not, something could be stuck inside.
Turn off power and remove cord from wall for next step:
There is a small hole generally on the flat face of the cd drawer through which a bent straight paper clip can be pushed gently until you hit a mechanical stop. Pushing slightly harder at this point should cause the cd drawer to move open mechanically. Gently pull the cd drawer open until you can remove any CD still inside.
Gently push the drawer closed again and restore power to the unit and see if the problem returns.
Would be nice to have manufacturer and model number of the CD player.
Apr 08, 2015 | Audio Players & Recorders
How do I open the cd drawer?
Look for a small tiny hole right below the CD drawer, use a paper clip and insert. That hole if made for when a CD is stuck and the drawer will not open, its more like a manual lock and needs to be pushed in with a small metal wire to unlock the drawer, mind you that the computer has to be running.
Mar 05, 2015 | Dell XPS 8700 Desktop Computer; Intel Core...
How to open a stuck CD drawer
After removing the mech look for a pulley wheel underneath and turn it with your finger
May 22, 2014 | Marantz PMD325 CD Player
How to open the cd drawer when the open/close button won't
Remove the lid, you will probably have to remove the whole cd mech and turn the gear underneath with your finger
May 22, 2014 | Marantz SA8260 CD Player
How do I open manually as a cd is stuck?
Get a large paper clip and straighten it out. Then look on either side of the drawer, right above it or below and you will see a very small hole. Insert the paper clip into it and you will fel it push up against a manual switch. Slowly push and the drawer will unlock and you can pull it open.
Please rate this if it helps you. Thanks and have a great day
Jun 27, 2009 | Sony CDP-C545 CD Player
Five discs keep spinning; will not stop. Cannot open drawer
they button maybe stuck or the switch that open the cd player sticking try to push button to open then pull on drawer not to hard u brack then see if u can clean swith
Mar 22, 2009 | Sony CDP-C445 5-Disc CD Changer
CD drawer stuck, then won't close
1. Most of the player drawer fixed over the chasis for a rigid support
2. try to remove the drawer safely without damagind the chasis and drive mechanism
3. there might be some shaft jam.
4. Look for the thread. how does the player drawer moves in and out
5. there may be some sensors to sense the door close/open. if it is jammed then open/close function cannot be done. why because this problem occurs
6. unwear the mechanism read the mechanism moving technique. see which has got jammed.
7. if you feel too risky then
8.contact service centre... all the best
Dec 21, 2007 | NAD L40 CD Player
Cd player stuck
Hi..
It will have to have the coverr taken off and the drawer belt replaced.
Find a stereo repair place.
Nov 23, 2007 | Yamaha CDC-585 5-Disc CD Changer
JVC FS-S77 Micro 5 Disc DVD Audio/Video System Home Theater Shelf Systems (FSS77, FSS-77, FS-77, FS7... Shelf System Logo
494 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
shaun taylor
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
