Question about Gateway 831GM PC Desktop
Gateway 831GM Video card
Hi, I was thinking about upgrading my Gateway 831 GM desktop by adding 2 gigs of memory and getting a better power supply to get a new video card. I was wondering if it would be possible to fit a Nvidia GeForce 9800GTX in it. I saw that the 4 memories slots would maybe be in the way of fitting it or it would beat least tight. I was wondering is any of you guys had done it or would know an answer.
  • 55 Answers
The 831 only supports 2 gigs of ram any more and it wont start. You can probably fit a 9800 in it but would be a very tight fit.
Posted on Nov 30, 2008
Ram speed-what does it do
Your PC support up to 4 gig of memory in 4 slots.
DDR 333/400 ram memory of 1 gig each.
So you need to know how much memory your system had.
Probably 2 gig.So the more memory the better will be the speed for run apps in your system.
Read more at http://en.wikipedia.org/wiki/Random-access_memory
Dec 13, 2011 | Gateway GT4010 (RBGT4010) PC Desktop
I had a fan making a clicking sound & a Friend cleaned it & now it turns on but nothing on the screen, what is messed up? where can I find parts to fix it? This is on my Gateway 831 Gm it has a...
Hi jdr_dlr519!
Pardon me.... but did your friend connected the monitor cable correctly on the system unit? Cleaning the fan will not break your computer... however, if he forgot to disconnect the power cables before opening the unit, it may do a damage.
Jul 20, 2011 | Gateway 831GM PC Desktop
I have a gateway desktop gt5468 and i lost the onboard ethernet port and onboard display. also it has 2gig of ram but it only sees 1 gig.i would like to upgrade the ram but this is not upgradeble.what...
if the graphics or Ethernet is not working you can use an ad don card to make them work insert the graphics card in the prescribed slot and watch out which all slots you have graphics card are available in pciexp and agp for Ethernet card the slot is pci fix them and install the drivers as for the 2 GB showing GB it means the memory is sharing with the graphics card
Jun 28, 2011 | Gateway GT5468 Desktop PC
Gateway desktop fx 7026 memory issue, has 4 slots came with( 2 )2 gb sticks = 4 gigs it came with. when i add 2 extra gig it doesnt recognize.
the specs i read says 8 gig is the max. here is what it says for RAM
RAM
  • Installed Size 4.0 GB / 8.0 GB (max)
  • Technology DDR2 SDRAM
  • Memory Speed 667.0 MHz
  • Form Factor DIMM 240-pin
  • Features Dual channel memory architecture
  • Configuration Features 2 x 2 GB
check to make sure you have added the right type of memory. also look at your user manual. it should tell you where and how to place the added sticks. sometimes they have to be added in pairs or have to be in specific slots. also if you dont have the manual it is on the gateway site. you should type in your model and serial number and get all the info you need.
Feb 12, 2011 | Gateway FX7026 PC Desktop
I have an Aspire S80. I need to upgrade my Graphics Card to Enable Winows 7 Installation. Motherboard is ACER E661 GXM
As far as I have been able to find out, the motherboard has an 8X AGP slot available for a new video card. Companies like TigerDirect and Newegg have several to choose from. There are many other vendors as well; I just do lots of business with those two.
In most basic consumer desktops, the power supply is just barely adequate for the supplied hardware. If you're adding a new video card, you should think about replacing your power supply as well. The new card will need more power than was originally required, and the current supply might not be able to deliver. A new supply in the 500-watt range would be a reasonable choice.
This would also be a good time to add more memory unless you already have. Windows 7 won't be happy with under 1GB, and your motherboard allows for up to 2GB. The board has 2 memory slots for DDR RAM. I think Acer uses PC3200 (400-Mhz) memory.
Good luck with your upgrade, and thanks for using Fixya!
Nov 19, 2010 | Acer Aspire SA80 (ASA80UC4603) PC Desktop
HI I AM HAVING SOME TROBLE I BOUGHT SIMS 3 AND CANT PLAY
Get a video card as was recommended by EA. You have a PCI-E slot (also known as PCI-X or PCI-Express). You should be able to find one in the $80 range at any Best Buy or Fry's that will work.
Jun 29, 2009 | Gateway 831GM PC Desktop
Need to upgrade HP3087F3 to a more powerful power
depends on what your going to do....bigger video card? I would max it out
Jun 23, 2009 | Gateway (ATX-300-12EB3) (ATX30012EB3)...
Gateway 831 GM
if the power supply was not the issue try memory,cpu and the motherboard..
Apr 22, 2009 | Computers & Internet
Gateway831GM-What memory is suitiable. I now have 4 256's
You need some 184-pin DDR SDRAM memory. Althrought, i think you have 4 slots with 2 Gigs max, so I suggest buying 4x512mb
Aug 14, 2008 | Gateway 831GM PC Desktop
Gateway 831GM PC Desktop Logo
339 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
