Question about JVC Silver/brown Compact Component System - EXD5 Shelf System
CD's are locked in stereo
I cannot unlock my cd player - all five cd's are stuck in it. When I hit to open them the screen says locked.
2 Suggested Answers
SOURCE: CD player is locked
^^^above is correct, except you do the Stop + Disc 1 thing in Standby mode. Strange thing: Stop + Disc 2 in Stby mode turns on the fan.
Posted on Aug 20, 2007
Hell Yes!!!  Thanks my friend - I haven't been able to use this thing for about 6 months.... You da man!
Posted on Oct 31, 2007
0 characters
1 Points
My CD Player Draw Will Not Open
If there is a co in it then it probably fell out and is stuck... especially if it was shaken.... unplug the unit.... remove the screws holding the case together and open it up
Oct 16, 2014 | Electro Brand Nostalgic Stereo CD Music...
The stereo works fine but i cannot eject the cd's
I just had the same problem with the same model. Disc five was saying no disc and would not play any other discs. I opened the radio and found the the CD tray was missing a piece for disc five. You have to put the disc tray back into the holder to fix it. Make sure it locks in place and you should be able to get the rest to work.
Feb 11, 2010 | JVC HX-D77 Shelf System
My rca rs 2657 cd changer is stuck. door will not open. any ideas how to correct?
If you hit the open button and you hear a sound like a motor running than it is most likely a belt or connection that physically opens the tray. You'll have to take it apart, locate the cd player and check from there. If no sound of a motor running when the button is pushed then the motor is probably bad.
Oct 17, 2009 | RCA 100-Watt Stereo System With 5-CD...
Our cd player won't unlock.
try to open that or go to th repair with u check the power box
May 21, 2009 | JVC MX-GT88 CD Shelf System
Buzzing sound and can't open stereo
Again RCA stereos **** for this factor, cheap transformers, replace the transformer and see if that helps as it seems to be the most problem with most RCA systems I've repaired in the past.
May 09, 2008 | RCA RS2656 Shelf System
Turn on the system and enter CD mode. While pressing the stop button on the unit (the small round button with the dark square), press the CD Open/Close button on the unit. 'UNLOCKED' appears on the display.
Jan 08, 2008 | JVC HXC6 500-Watt Stereo System with 5-CD...
RCA 2656 bookshelf music system cd door
I have a similar stereo system and accidentally put two CD's in one tray and it got stuck and could not open. What I did was unplug everything from the unit and took off the side panel. After some careful fiddling I got it to open. You could try something like that.
Dec 30, 2007 | RCA RS2531 CD Shelf System
Jvc mini system cd bay will not open
Does your stereo have a childs lock? If it does; why? Anyway the cd open button could be defected. Possibily a loose connection on the cd open switch on the inside of the unit. Also dose the remote have this function? Check the battery. Clean the remote sensor on the front of the remote and on the stereo.
Hope this helps.
Dec 27, 2007 | JVC FS-G5 CD Shelf System
Well. you may have got a cd jammed or stuck in there. it happened to me. but i didnt know the cd fell into the stereo until one day when i closed the cd tray. it got stuck. so i took it apart and there was a cd in there!
Aug 05, 2007 | RCA RS2635 CD Shelf System
CD player is locked
Feb 07, 2007 | JVC FS-S77 Micro 5 Disc DVD Audio/Video...
JVC Silver/brown Compact Component System - EXD5 Shelf System Logo
19 people viewed this question
Top JVC Audio Shelf Systems Experts
Are you a JVC Audio Shelf System Expert? Answer questions, earn points and help others
