Service Error 5100 is Displayed. There is no paper jam, but print head holder unable to move to center for me to replace ink cartridge. Harsh scraping noise heard. name and telephone number of nearest ASF
  • margaret806 Nov 30, 2008
    This service error 5100 problem is with Canon registration # H2000VR; purchase date 1/26/08 fromSTAPLESm 547 River Rd., Edgewater, NJ 07020
    If unable to assist, please provide name and telephone number of nearest ASF
    Thank you
  • 928 Answers
Since you did not indicate the model number of your unit nor the brand you may see the list below. You may contact the numbers below or access the link to get the information that you need.,
Canon = 1-800-OK-CANON
HP = http://h20465.www2.hp.com/GPL/search.aspx?language_code=en&country_code=us&SearchType=SSP
Brother = 1-877-276-8437
Epson = (562)276-4382
Posted on Nov 30, 2008
  • Thomas Lim
    Thomas Lim Nov 30, 2008
    You can call the number for canon and ask them for the nearest they have the updated list
    1-800-OK-CANON
    Sergeant:
  • 217 Answers
Unplug the printer from main power cord for two minutes then plug it in and ON.then check out it will move.
    Genius:
  • 1,142 Answers
This error means the fuser assembly need a replacement
    Genius:
  • 1,142 Answers
This error means fuser assembly needs a replacement
What is error 5101
When the message "5100 / 5101 Printer error has occurred. Turn off power then back on again. If problem persists, see the manual." is displayed, the behavior of the print head holder is interrupted.
Do you see a jammed paper or foreign material?
Did you install the print head properly?
Please see the following for detail.
If the problem persists, contact the service center for repair. Cause 1. Is there a securing material for the holder inside the printer? Summary There may be a securing material for the holder inside the printer.
(This material must be removed before using the printer.)
Open the Top Cover, then remove the securing material for the holder. See Also Cause Summary [ With the securing material ]
[ Remove the securing material ]
Then, close the cover, and turn ON the printer again. See Also Cause 2. Is there a jammed paper or foreign material inside the printer? Summary Stop printing, then push the power button of the printer to turn OFF the printer.
Open the Top Cover of the printer; then,
  • If there is a jammed paper or foreign material inside the printer, remove them.
See Also Cause Summary [ The printer with the Top Cover opened ]
( Paper jam )
After checking the above items, push the power button to turn ON the printer again.
CAUTION
When removing the jammed paper or foreign material, take extra care so that you do not touch the inner parts. Or, it may cause another printing problem.
See Also Cause 3. Is the ink tank properly installed? Summary If the ink tank is not properly installed, it interferes with the operation of the print head.
See the following images to get an idea of proper print head position. See Also Cause Summary [ When the ink tanks are not properly installed ]
The ink tank is not set firmly.
The ink lamp is not turned ON. See Also Cause Summary [ When the ink tanks are properly installed ]
The ink lamps are turned ON.
CAUTION
Always remember "Do not touch the Print Head Holder while it is moving."
Wait until the Print Head Holder automatically stops.
Do not even attempt to stop/move the Print Head Holder by holding it.
Canon PIXMA MX922
Apr 10, 2017 | Canon Pixma MX922
Error 5100
When the message "Printer error has occurred 5100" is displayed, the behavior of the FINE cartridge holder is interrupted.
Do you see a jammed paper or foreign material? Did you install the FINE cartridge holder properly?
Aug 15, 2013 | Office Equipment & Supplies
Last week i tried to print but it didn't work and appeared 5100 error. i have the pixma mp 170 printer... i don't know how i can fix it
Hello
The manual states that the error code 5100 is a result of:
Service error 5100 is displayed
Cause: Movement of the FINE Cartridge Holder is blocked.
Action: Clear the paper jam or foreign object that is preventing the FINE Cartridge Holder from moving, cancel printing from your computer, then turn OFF the machine and turn it back ON again.
You might see something blocking the printer head, check inside to see if there is a paper jam, staple, or some other object blocking the print head.
If this does not work, try resetting the device:
  1. Turn the printer off.
  2. Hold the button Resume / Cancel (red triangle in the circle), click POWER - indicator lights green.
  3. Release the button Resume / Cancel, keeping POWER.
  4. Click Resume / Cancel 2 times, keeping POWER, and then release all the buttons.
  5. When the indicator light Green - click Resume / Cancel 4 times!
  6. Turn the printer off button POWER.
Hope this can help you.
Best regards
Andrea
Oct 20, 2009 | Office Equipment & Supplies
What does error 5100 mean?
This means that the Movement of the Print Head Holder is blocked. To remedy this carefully check the printer and clear the paper jam or foreign object that is preventing the Print Head Holder from moving. With the power off the Head Holder should be able to be moved gently by hand. Cancel printing from your computer, then turn off the machine, and turn it back on again.
Oct 04, 2009 | Canon PIXMA MP600 all-In-One InkJet...
Canon PIXMA MP530 Error Code 5100
OK. It sounds like there's something on the carriage bar restricting the movement of the ink carrier. Perhaps some ink got on the bar.
Try taking a clean lintfree rag dampened with rubbing alcohol and clean the bar. This may have to be repeated a number of times to get the foreign matter off the bar and the ink carriage.
Let me know if this helps. iF it does not we can try something else.
Thanks.
May 05, 2009 | Canon PIXMA MP530 All-In-One InkJet...
Cannon MP830 Printer cartridge jam
So you cant get the ink tanks in place properly?
Have you tried this method to ensure they're properly seated? Is the printer on or off when you try to seat the tanks?
Refer to the following steps to verify the ink tanks are seated correctly:
  1. Confirm that the printer is powered on and press the Open button. (The paper output tray will open.)
  2. Lift the scanning unit (printer cover) completely. (The print head will move to the replacement position.)
  3. Open the inner cover.
    CAUTION:
    a. Do not try to manually move or stop the Print Head Holder.
    b. Do not touch any metal parts.
  4. Press down on the ink tank until a click is heard, thereby making sure the ink tank is seated properly.
    Note:
    Make sure that the ink tank is inserted in the slot that corresponds to the ink tank's color.
  5. Ensure that all the ink tanks are installed properly and the ink tank lamps light red.
    Note:
    Ink Tank Lamp
    You can check the status of each ink tank according to the way its lamp flashes.
    • - On: The printer is ready to print.
    • - Slow flashing (at about three second interval): Ink is low. Prepare a new ink tank.
    • - Fast flashing (at about one second interval): Ink tank is empty, or the printer is not ready due to an error.
    • - Off: An error has occurred and the printer is not ready to print.
  6. Close the inner cover and the scanning unit (printer cover).
    Note:
    1. When closing the scanning unit (printer cover), be careful not to jam your finger.
    2. When starting printing next time, the print head cleaning launches automatically.
Apr 04, 2009 | Office Equipment & Supplies
5100 ERROR
As per the manual...
Mar 27, 2009 | Canon PIXMA MP170 All-In-One InkJet...
Error 5100 canon mp470
Cause: Movement of the Cartridge Holder is blocked.
Action: Clear the paper jam or foreign object that is preventing the Cartridge Holder from moving, cancel printing from your computer, then turn OFF the machine and turn it back ON again.
With power off, move the cartridge holders manually
reseat the cartridges. Then power back on.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Jan 10, 2009 | Canon Office Equipment & Supplies
Cannon printer mp460error code 5100
Cause
Action
Nov 05, 2008 | Office Equipment & Supplies
Error 5100
Cause
Action
Sep 27, 2007 | Canon PIXMA MP170 All-In-One InkJet...
54 people viewed this question
jasbo
jasbo
