Question about Dell Inspiron 530 Desktop Computer (ddcwda1_7) IntelPentium dual-core processor E2140 (1MB L2,1.60GH
Tower will not power up
Led light is orange
  • 2 more comments
  • Anonymous Jan 23, 2009
    My tower will not power up, blue LED come on alright but then there is just a beeping sound and that's it.
  • Dick
    Dick May 11, 2010
    The beeping is a code telling you what the problem is. Can you determine a beep sequence? A beep code is a REPETITIVE sequence of beeps from one to seven beeps. You can see the manual here.
  • andy kissan May 11, 2010
    HI can you use bios
  • Ismail Shifau May 11, 2010
    this usually indicates something wrong with the motherboard. can u check with another power supply?
  • Dell Master
  • 2,404 Answers
The light is orange instead of its normal color cause the motherboard is bad and needs to be replaced. It means its not recognizing either the memory or the cpu properly.
Posted on Jun 21, 2009
Orange led light ibm x3400 m3
The orange Led On the Server is letting you know that there is something wrong with a PCI. Check the pci card slot 1 and make sure they are all seated tight.
Sep 03, 2014 | IBM System x3400 M3 7379 Server tower 5U...
Will not power on
Try to change your power supply.
Jul 14, 2011 | Medion M3 Composer 5200 PC Desktop
It ask printer absorver full, contact with service center
Canon waste ink full
With the printer power turned off, while pressing the Resume/Cancel button, press and hold the Power button. (DO NOT release the buttons. The Power LED lights in green to indicate that a function is selectable.)
2) While holding the Power button, release the Resume/Cancel button. (DO NOT release the Power button.)
3) While holding the Power button, press the Resume/Cancel button 2 times, and then release both the Power and Resume/Cancel buttons. (Each time the Resume/Cancel button is pressed, the Alarm and Power LEDs light
alternately, Alarm in orange and Power in green, starting with Alarm LED.)
4) When the Power LED lights in green, press the Resume/Cancel button the specified number of time(s) according to the function listed in the table below. (Each time the Resume/Cancel button is pressed, the Alarm and
Power LEDs light alternately, Alarm in orange and Power in green, starting with Alarm LED.) [hth: I believe the power button has to be pressed once more after cycling the alarm button to complete the action. The power/resume-cancel button LEDs toggle to help you count.]
Time(s) LED indication Function Remarks
0 times Green (Power) Power off When the print head is not installed, the
carriage returns and locks in the home position capped.
1 time Orange (Alarm) Service test print See 3-4. Verification Items, (1) Service test print.
2 times Green (Power) EEPROM information print
See 3-4. Verification Items, (2) EEPROM information print.
3 times Orange (Alarm) EEPROM initialization [hth: does not re-initialize Waste ink counter]
>>>> 4 times Green (Power) Waste ink counter resetting
5 times Orange (Alarm) Destination settings [hth: not applicable]
6 times Green (Power) Print head deep cleaning (Cleaning of both black and color)
[hth: 7-10 not applicable]
11 to 13 times Orange, Green, Orange (Alarm, Power, Alarm) Return to the menu selection
14 not used in servicing
15 Orange (alarm) return to the menu selection,.
Note: If the Resume/Cancel button is pressed 16 or more times, the Alarm or Power LED lights steadily without
any changes.
Sep 01, 2010 | Office Equipment & Supplies
Waste ink is full how do i fix it?
www.fixyourownprinter.com/forums/inkjet/50418
all is revealed above.
1) With the printer power turned off, while pressing the Resume/Cancel button, press and hold the Power button. (DO NOT release the buttons. The Power LED lights in green to indicate that a function is selectable.)
any changes.
Mar 29, 2010 | Canon PIXMA MP780 All-In-One InkJet...
Orange flashing light on tower
There are a few lights on most towers one will mean that you are powering on your computer the other flashing orange as you say most likely is the hard drive activity light and is usually nothing to worry about. If there is some kind of problem you are having with computer light please feel free to repost and we will be glad to help you.
Thank you and if this helps answer your question that says (orange flashing light on tower) Please leave feedback or rating. Thank you have a nice day.
Jan 31, 2010 | HP Pavilion a1610n PC Desktop
My dell dimension 2400 goes on standby automatically.
If the power LED on the Tower is blinking amber, then most likely the power supply in the tower is failing. Replace the power supply.
Dec 31, 2009 | Dell Dimension 2400 PC Desktop
My vostro 200 slim tower wont turn on PLZ READ FULL
There could be a hardware problem on the computer if the power button led light is "Orange/ or amber", if you can open the computer, try removing one memory card at a time and see if the power button will change.
Dec 15, 2009 | Dell Vostro 200 Mini Tower With 20" Flat...
When I connect the ethernet cable to my tower, I gave an orange light. What could be causing this to happen?
What Orange light are you refering to? You have an orange and green LED on the block of the Ethernet connecter, if the cable is plugged into the plug and the other end is terminated into another deive such as a modem,bridge,router or switch the orange light(led) should come on as that indicates a valdi link hence being called the link light, the green light(led) indicates data being received or transmitted. If orange flash with sparks(bad) from the plug it means there is power on the cable..very bad as this could be due to the ethernet card that is faulty or the device on the other end of the cable is faulty.
Aug 01, 2009 | Intel Ethernet 10/100 Network Adapter
Printer Problem
This was not the sollution for my pinter..
My Magneta is half full and my error led is also blinking 15 times
I found this service manual for the IP4200 but this methode also doen not solve my error led..
Is their someone who has the sollution for this strange error?
selectable.)
resume/Cancel button. (DO NOT release the Power
button.)
Power
in
time(s)
setting) (THEN HIT THE POWER BUTTON >AFTER THIS< TO SET).
not installed, the carriage returns and locks in the
1 time Orange (Alarm) Service test print .
>>>>>>>>THIS ONE
4 times Green (Power) Waste ink counter resetting<<<<<<<<<<<<
5 times Orange (Alarm) Destination settings After
entering the destination settings mode, press the
to select the destination. For detail, see
"Destination settings procedures" below.
7 times Orange (Alarm) Reserved
8 times Green (Power) CD / DVD check pattern
9 times Orange (Alarm) CD / DVD print position
correction (horizontal: X direction)
10 times Green (Power) CD / DVD print position
correction (vertical: Y direction)
11 to 13 times Orange, Green, Orange(Alarm,
Power,Alarm) Return to the menu selection
14 times Green (Power) Left margin correction Not used
in servicing.
15 times Orange (Alarm) Return to the menu selection
Time(s) LED indication Destination CD / DVD print
0 times Green (Power) No change of the destination
1 time Orange (Alarm) Japan Supported
2 times Green (Power) Korea Not supported
3 times Orange (Alarm) US Not supported
4 times Green (Power) Europe Supported
5 times Orange (Alarm) Australia Supported
Oct 30, 2007 | Canon PIXMA iP4300 InkJet Photo Printer
Dell Inspiron 530 Desktop Computer (ddcwda1_7) IntelPentium dual-core processor E2140 (1MB L2,1.60GH Logo
315 people viewed this question
Brian Sullivan
Brian Sullivan
mukhtar21 shaikh
mukhtar21 shaikh
