Question about LG LRSC26920TT Side by Side Refrigerator
Can't find compressor
Hi, I have LG reftregrator model number LRSC26920TT . The compressor model number EMBRACO model number EGZ90HLP in not working and I cant find it , is there another compressor which will fit.
  • 1,543 Answers
The compressor is LG part number 2521C-A7256 which they have in stock. I believe this unit has a 7 year warranty on the parts of the sealed system (which includes the compressor) but this is most definitely not a do it yourself repair. Only someone certified to handle refrigerants, has the proper refrigerant recovery equipment, and charging equipment (and knows how to use them) should ever attempt to replace a compressor. Compressor failures are rare, and the unit should be diagnosed by a professional service technician, as most often your problem will not be the compressor, but some other issue. Please do not rate this solution as anything but a FixYa lowers my score.
Posted on Nov 30, 2008
Need to identify the prongs on my compressor. embraco egy90hlp wiring diagram
PDF]General Index - Embraco
www.embraco.com/DesktopModules/.../Arquivos/MP01EG.pdf
EmbracoApr 7, 2011 - Figure 6b Series EM - Compressor Model Identification Code . ....Compressor Wiring Diagram T Series (electrical component with terminal ...
Embraco PW 5.5A compressor - pins layout? - Refrigeration Engineers
www.refrigeration-engineer.com > ... > Domestic
Sep 4, 2008 - 4 posts - ‎1 author
My fridge-freezer quit working tonight - it's probably over ten years ... It's an EmbracoPW 5.5A, and the pins form an upside-down triangle, ... So, I want to try hard-wiring it but I'm struggling to identify the compressor terminals.
Identifying Compressor Terminals: Start, Run, and Main ...
fixitnow.com/wp/.../identifying-compressor-terminals-start-run-and-main...
Sep 9, 2010 - Let's say you're gonna do some tests on your refrigerator compressor to see if it's okay. Or, you need to figure out how to wire up a generic ...
Refrigerator compressor electrical question - AllisChalm
Jan 18, 2016 | Refrigerators
Replaced compressor in g.e.profile refrigerator
HI,
I need a model number of the unit to assist you, this could be a fan wire or a compactor wire. So a model number is very important to know what you have and get you the correct information you seek. Thanks
Aug 31, 2014 | Refrigerators
My Gladiator freezerator GAFZ21XXRK has a Embraco EGZ90HLP will not cool down but fans run and compressor is warm humms and vibrates
You can test the electrical winding but not the mechanical possibility that compressor is worn out. There is a 3 n 1 that you can use that uses a run capacitor here=>SUPCO RC0810 Refrigerator Compressor Hard Start Kit
How to test windings
Unplug the refrigerator and remove the back panel that covers the compressor. There should be 3 wires going inside the cover of the compressor. Mark all 3 and mark their location so if compressor is OK you can put them back in same order. The plastic cover may snap on and you may need to squeeze the sides to unlock the cover and sometimes there is a metal clip holding the cover in place. Remove the cover. May look hard but it's simple. There will be three connections under the cover and 2 will go through the start relay. Unplug them leaving the three prongs exposed. They may be marked R =Run, S=Start and C=Common. Set your meter on continuity and then begin by testing 2 at a time until you have checked S to R and R to C an C to S and S to R again. You should get a reading all the way around. If no reading between any of the pairs as you go around you should get no reading between any two the compressor has an open winding and is defective. Then if it passes that test then touch one probe to R and the other to the copper pipes or clean metal on outside of compressor, then S to metal outside and C to metal outside. If you get a reading this way even just a little. The compressor is a burnout. Then let me know what you find. Thanks, Sea Breeze
Apr 02, 2013 | Whirlpool Refrigerators
Amana abb2224dew repairman installed part # 8201786. This was to replace the compressor start up. Worked for a week, then same buzz click sequence occurs. Looked up part number. Part is for mostly...
The replacement compressor kit is #12002633 from Amana (Now Whirlpool).
In this kit are the following New model compressor, relay/capacitor, jumper and instructions.
Kenmore does not make appliances rather all of the other manufacturers produce for them.
That part number is for Whirlpool Start Relay/Capacitor and as long as the compressor is the right horsepower for the relay it makes no difference who made it. (Techumseh or Embraco)
Apr 29, 2011 | Amana ABB2224DEW / ABB2224DEQ / ABB2224DEB...
Lg side by side model number lrsc23915sw how to turn off ice maker
I'm having trouble identifying that model number, but I can give you the generic answer. On most icemakers the "shut off" is lifting the wire arm to the up position. It should lock in that position. Lifting the arm shuts it off in the same manner that it stops the ice maker when too many cubes are in the tray. I have seen some icemakers that actually have a swich on the front side of them. But, they are in an obvious position so I'm guessing you don't have that style.
Hope this helps
Jan 28, 2011 | LG LRSC26920TT Side by Side Refrigerator
I purchased an Amana refrigerator that has been making a humming noise and will not keep food cold or frozen. what' wrong? The model # is ABB1924DEB, and I purchsed it in 2005. is it included in their...
The recall was for units that had embraco compressors. the relay would burn up and not start the comperssor. (hum and click) some amanas had tecumseh compressors. They would just scize up and not run (hum and click)No recall. remove the back cover and see what name is on your compressor. If its hot and trying to start, Embraco needs new relay, Tecumseh needs to be replaced with a embraco compressor.
Dec 01, 2009 | Refrigerators
FREEZER NOT WORKING
please switch off your refrigerator for at least 8 hrs. than again switch it on. if your problem is not cured than it is sure that you have your gas chockage for which the compressor is making noise and the refrigerator is not cooling....... please visit your service authority...........have a nice day:-)
May 14, 2009 | LG LRSC26920TT Side by Side Refrigerator
LG LRSC26920TT Side by Side Refrigerator Logo
584 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
