Question about Intel DG31PR Motherboard
Vga over heated
I have inno3D 8500GT 1GB DDR2 in some games after playing for 1m lead to over heat which lead to restart the windows
  • scarry_22_86 Nov 30, 2008
    i donot think so but also i have core 2 due intel
Have you tried a bigger PSU, i have exactly the same card, OC above 800MHZ Core and bang windows restart until clocks default. bought a  bigger PSU 1000W and its fine bit hot 80 degrees C but its 45 idle so not to bad considering the ammount it has been clocked
Posted on Feb 08, 2009
    Scholar:
  • 162 Answers
Your cpu fan not working correctoly. need to check it. if issue is presist add a heatsink on the chip .
Posted on Nov 30, 2008
My games are hanging in pc
You don't say what games you are playing. Check that the hardware you have is good enough to play the games. It will be written on the side of the box.
Mar 13, 2012 | Nvidia Inno3D nVIDIA GeForce GT240 (1GB...
I want to upgrade my computer specs... hope you can help me.. CPU: intel core2 duo E4600 2.4Ghz/800Mhz/2mb L2 cache/65MOnm MOBO: elite 945GCT -M2/1333 (v1.0), 1945GC/C2D/1333MHZ/DDR2 667/PCI-E memory:...
If you are a "gamer" and you have 1GB of RAM, and you have Windows XP, you probably need more RAM.
If you are a "gamer" and you have 1GB of RAM, and you have Windows Vista or Windows 7, you DEFINITELY need more RAM.
Some motherboards support "dual-channel" mode, when you have 2 or 4 _IDENTICAL_ sticks of RAM. What happens is that each byte written to the RAM is "split" into 2 halves; one half is written to the 'A' stick of RAM, while, simultaneously, the other half is written to the 'B' stick of RAM. Obviously, this takes 4 "cycles" of the RAM, rather than taking 8 "cycles", if there was only one stick of RAM. So, your RAM seems to run at "double-speed".
So, when you buy more RAM, either try very hard to "match" your current 1GB stick of RAM, or purchase a "2GB dual-channel kit", or two "2GB dual-channel kits", to upgrade to 2GB (or 4GB) of RAM.
Aug 04, 2011 | EliteGroup ECS 945GCT-M/1333 Motherboard -...
Hello.. can anybody help me with my problem, i have a inno3d gt240 ddr2 video card, the video card seems to be fine when the computer is newly turned on, but after about 30 mins. of using the computer, the...
My suggestion is when was the last time you took the side cover off your computer to check the fan on your video card. It sounds like the card is heating up and causing the computer to shut down. You can try blowing out the fan with air to make sure it doesnt have some larges peices of dust/dirt or that the fan isnt worn out. If the computer keeps running with the side cover off that would confirm an over heating problem with the computer. While you have the side cover off blow out the whole machine especially the power supply. Computers are dust magnets. While your using the computer if you have a video game that is graphics intensive run it and keep your eye on the fan of your video card to see if it stops turning at any point.I would also look really hard at the fan or fans on your computers processor to see if it is spinning freely. When your blowing out your computer with air blow air on the fans of your processor to make sure it has no dirt in it and it is spinning freely. If after 30 minutes your computer continues to run with the side cover off then either its time for a new video card or a new fan on your processor. Because one or the other is worn out.
I hope this helps you out.
Apr 01, 2011 | Nvidia Inno3D nVIDIA GeForce GT240 (1GB...
Computer restarts when playing high configuration games
This is because your computer is overheating and is shutting down to prevent the heat from damaging the components, refer to my tip on Comuter Overheating here http://www.fixya.com/support/r6789964-pc_overheating
In this tip I outline the problem as well as various solutions.
Nov 12, 2010 | ASUS GeForce 8500GT Graphic Card
Which card is better for gta iv? i want to buy a low price graphics card i have to option 1) Inno3d 8500gt (512mb 128bit ddr2) and another one is 2)Asus 8600gt (256mb 128bit ddr2) can any one tell me which...
I recommend you to buy ATI 4670 instead since it is much more powerful than you listed above & now the price should be around $64+
It is much better for GTA IV than those you listed.
Mar 25, 2010 | ASUS GeForce 8600 GTS, Graphic Card
I can't video cards that fit within the confines of my computer housing
Good morning! please try to check with your acer aspire x1200 supplier if they have a bigger case that will replace the 4 inches wide case, in order to install a new VGA card. best regards
May 03, 2009 | Acer Aspire X1200 Desktop PC - Athlon X2...
COMPUTER GOES SHUTDOWN WHEN PLAYING HIGH-END GAMES
If your mobo wasn't compatible with your video card, you wouldn't get a screen at all.
Yes upgrade your directx to 10
and yes upgrade your power supply to a 650Watt or greater.
The problem is most likely that you have a low wattage PSU and
when your vcard request more power to run higher graphic games than the
Windows Interface, your computer shuts down because it doesn't have enough power to give.
Oct 23, 2008 | Computers & Internet
Inno3d GeForce FX 5500 problems
try to re-seat your graphics card and install the latest drivers
Jun 01, 2008 | MSI FX5500-TD256 GeForce FX 5500, (256 MB)...
Intel DG31PR Motherboard Logo
50 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
