SOURCE: Light brown algae(?), small 2 leafed clover growing in pool.
add a clarifier this will make particles bigger and will be more managable either through filter or vac
SOURCE: Pool had a lot of
First I'm assuming we're talking about a sand filter. Back washing is the right thing if pressure increases.A 8-10psi pressure increase is the magic number where you must backwash. Be sure to run a rinse cycle too before returning to filter. If you want to clean filter you can buy chemicals that you add to your skimmer as you backwash. Follow their directions. If you do want to drain the water, open your basket cover on the pump and remove plug, this will allow air to enter the filter, so it will drain. It drains slowly. Not really necessary, except to winterize.l
