Question about Honeywell Heating & Cooling
I'm trying to wire my honeywell t8011 thermostat
    Sergeant:
  • 217 Answers
Go to the breaker and carefully throw it fully to the off position, and then back on. Sometimes they look on, but are off. If it was already on, it should also reset anything that needs reset. Pull the thermostat off the wall, and check all the connections. Wiggle the wires around. Pay careful attention to the Red and white ones. One of them could be broken off inside the insulation. Look for a suspiciously flexible place in the wire. Red is power from the transformer, and white energizes the heat cycle. Enough power to run the thermostat bleeds through it.
You might look inside under the cover for the filters. If you see a red button, it may be the reset.
Usually there is a 24 volt AC transformer in the furnace with the secondary winding connected to a red wire running to the thermostat and a blue wire to the gas valve, A/C relay, and fan relay. From the thermostat there will be white wire to the gas valve, yellow to the A/C, and green to the fan. The thermostat is wired to switch the power from the red to the white, yellow, and green as needed with the blue completing the circuit. It may be wired to have the control wires return to the furnace and its controls and then a second wire goes to the A/C unit. Internal wiring may replace the green wire if the thermostat does not give you the option of fan only or continuous fan.
The W1, 2, 3 likely are for 2 stage heating replacing the W in simpler thermostats. C may be a hot common often labeled RC and jumpered to the R. The L, O, X, and E may be connect to an outside temperature sensor, logic on the furnace control board, or externals such as a electronic filter. If you didn't get any instructions with the thermostat, you have to check Honeywell's web site or call their tech service.
click this link for more help http://www.askmehelpdesk.com/interior-home-improvement/help-wiring-honeywell-t8011-digital-thermostat-8865.html
Posted on Nov 30, 2008
    Genius:
  • 1,142 Answers
Sir please specify your issue?
  • cmr4skulls May 30, 2011
    Well my heating & ac unit in my double wide home,the Ac will not cut on unless i turn it on emerg. air. Had a guy tell me it was my relay in the unit outside,if so how do i go about changing it??
Installed a rth6350 now no power
The RTH6350 is a battery-powered thermostat. Did you correctly install the AA batteries? Press down and pull the battery holder away from the thermostat on the right hand side. Try new batteries. Did you remember to secure the C wire with a wire nut and push it back into the wall. It should not be connected to the thermostat.
If you connected the C wire, you may have damaged the thermostat by providing too much current. Honeywell has the documentation for the RTH6350 on the product page: http://yourhome.honeywell.com/home/Products/Thermostats/5-2-Day-Programmable/RTH6350D.htm . The installation guide is here: https://customer.honeywell.com/request.cfm?form=69-2416ES . See page 23 and subsequent pages for the wiring diagrams.
I hope this helps.
Oct 11, 2014 | Honeywell RTH6350 5-2 Programmable...
Wiring with Honeywell RTH6400
I have the same problem. I am Trying to install a Honeywell RTH6400 but I only have a white and a black wire coming out of the wall. Do I have the wrong thermostat. The manual doesn't explain this siutation.
Thanks!
Dec 29, 2009 | Honeywell FF12HH Thermostat
Wiring honeywell to old landis thermostat
HONEYWELL WEBSITE:
Go to honeywell.com
Under red welcome sign
Bottom red highlighted box literature/image search
Type in thermostat model number
Click on arrow to right
Then click on the PDF files owners manual / installation instructions
Jul 08, 2009 | Honeywell Heat/Cool Thermostat
T8011 HONEYWELL THERMOSTAT TURNS OFF & ON
battier dead replace or their is a control wire problem check for loose connections. Tom
Jun 20, 2009 | Heating & Cooling
Honeywell RTH3100C
You need to go into the installer setting to change it from heatpump to single stage gas heat.Go to www.honeywell.com if youve lost them.
Dec 13, 2008 | Honeywell Programmable Thermostat Heater
I'm trying to wire my honeywell t8011 thermostat Replacing an old Honywell unit.
I hired someone................... Could you please refund my $? Thanks, Danny
Nov 30, 2008 | Honeywell Heating & Cooling
Replacing Round Honewell Mercury Thermostat
try to get one that is made for oil heat, the installation is easy only two wires, and the instructions make it easy.
Oct 23, 2008 | Honeywell Electronic Programmable...
Honeywell RTH230B
This my situation exactly.  Changing from a 6 wire manual round Honeywell thermostat to a 5 wire Honeywell programable.  Is there a way to maintain all functions?
Sep 21, 2008 | Honeywell Programmable Thermostat Heater
Honeywell TH8000 5 wire
7wires? wtf with that! how many things you got runnin there. you need to give way more info to get a decent reply.
Feb 04, 2008 | Honeywell Programmable Thermostat Heater
Heating & Cooling Logo
174 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
