Question about Vizio L37 Television
None at present
Ex TV Maintenance Eng., now retired and not up to date with flat panel, LCDs. Would like o have an idea what I'm getting nto and how to go about lamp replacement in my Vizio that I'm quite satisfied with.
  • Circuit World
    Circuit World May 11, 2010
    TFT LCD, and Plasma tv's are much easier to troubleshoot than conventional CRT tv's. And the circuits are far more intuitive which helps a trained technician troubleshoot a fault faster. All flat panels use "service software" for test-mode. Some need a PC for test mode commands together with OEM software. Other's require shorting out and couple of points on the circuit and/or hidden key commands from the remote control.
    Provide the year and model number for the Vizio tv and I can try an locate a vender for your part. I'll also search my shop to see if we have one.
Thanks for your response. I don't actually have any problem. It's just that occasionally some program will seem to have less brightness and I'll start wondering if the lamp is getting ready to go. At least I think there's a lamp that could go. Have to admit my understanding of LCDs, Plasma, DLPs, etc. leaves a lot for me to study. Was hoping there might be an available service guide that might prepare me for that eventuality. Nice to know you're here to help when the time comes. I'll be doing some reading in the mean time. At one time I was confident I could fix anything in our studio or transmitter. Too many years ago. Sincerely, Dave
Posted on Dec 01, 2008
Tv has red tint in dark areas of the picture ( looks like scribbles across the screen )
If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy. Pull up older posts. Surf the site with patience. Do a search by type in the brand name of your device at its search box.
Screen-shots to defctive LCDs are given. You can see and compare it to that of your TVs' and can get an idea about the fault.
Jun 01, 2014 | Philips Televison & Video
Vizio L32 Not terning on orange led lights on
3320-0032-0150. Question - is this board in other 32" LCDs? I see the entire LCD all over EBay w/cracked displays for CHEAP biggrin.gif (since the LCDs are so pricey the unit is parts only). Thanks again! cheak out them on ebay try new board
Feb 08, 2008 | Vizio L32 32 in. LCD HDTV
Child maintenance
I'm sorry to hear of you problems, I would advise you will get more help with this problem if you post in the right section. This has been posted in the Flat Panel Televisions section.
Mar 20, 2014 | Televison & Video
No picture but has sound
Check the back-light is present. If not, check and replace back light inverter board. http://electronicshelponline.blogspot.com/. If you wish to get more details, check this link. It has details about Panasonic TC-26LX series LCDs. Pull up older posts.
Jun 15, 2013 | Panasonic TC-26LX20 26 in. HD-Ready LCD...
Turn o n the tv and it has a loud static hum that is ever present. it dims out a little but never goes away.
This can be cause by the inverters arcing or faulty insulation within the high voltage section of the power inverters; associated with the screen.
Tom Miller
Broadcast Eng
Mar 04, 2011 | Televison & Video
Sony tv mfm ht75w tv doesn't stay on, works for 10min sometimes,, other times only sec. i opened it all the caps seem ok, any ideas
Please clarify whether the entire tv powers off or only the screen turns off and you can hear the sound so that we can continue with the diagnosis. Sony LCDs are notorious for backlight inverter failures.
May 06, 2010 | Televison & Video
My television screen went black, but there is has sound
Make sure your tv is on the right input first of all. The newer flat panel lcds combine the componenent video (red , blue, green) with the composite video and audio (yellow, red, white). If your tv is on the component input then you hear audio from the composite input since the audio inputs (red, white) are shared. Look for a source or tv input button on your remote or the tv itself and try pressing this button unti you see a picture with sound.
Aug 15, 2009 | Televison & Video
PINK SCREEN ON DAEWOO PLASMA TV
Sounds like your panel might be going out or a faulty video card. This is the first time I have heard of a solid pink screen on a plasma. Usually this happens on LCDs, though they sometimes go white and stay white, which does signal a bad panel. tv needs repair
May 09, 2009 | Daewoo DP42SM 42 in. HD-Ready Plasma...
Panasonic Viera TV with black band on left hand side
disconnect the x and y sustain boards from the power supply. then check the flex connector to the screen and reseat them. check connections on c boards at bottom and screen connectors. reconnect the power supply only after all flex cables are reconnected or charge from supply will burn flex cables. if still preent replace correcsponding c board. if still no fix replace panel.
Apr 25, 2009 | Panasonic TH-42PX60U Television
Flat panel tv
Hi am roshan...the one who was chatting with you (TV)...there was drop in the server thats why we lost contact...the best chioce is buying a LCD.This is the reason
Apart from being price competitive, LCD has the edge over plasma in several other key areas. LCDs tend to have higher native resolution than plasmas of similar size, which means more pixels on a screen.
LCDs also tend to consume less power than plasma screens, with some estimates ranging that power saving at up to 30 per cent less than plasma. LCDs are also generally lighter than similar sized plasmas, making it easier to move around or wall mount.
i lost by payment due to that problem...at least if you can PLS rate as FIXYA...for my help..catch you later
May 26, 2008 | Televison & Video
Vizio L37 Television Logo
41 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
