FixYa.com
Tags:
Emerson EWV601 S-VHS VCR
Tape stuck in VCR, won't eject.
posted by Itch on Jan 24, 2007
I recorded a program on a tape. The following morning I tried to play it back. I hit Rewind and didn't wait for it to stop and pressed Play. The tape is stuck, won't eject and I'd like to get it out without damaging the VCR unit. Any suggestions?
Comment by Itch, posted on Jan 24, 2007
The suggestion work fine. The tape was extracted without damage. Now the Tape in indicator continues to flash, without the tape in the unit. The Cassette will not insert as usual. The motor driving the Black rubber belt does not run. How can I check the motor to see if it is defective?
With the Power on and the Power and VCR/TV indicators lit, I insert the cassette manually (altho it doesn't seat) and the two indicators go out and the tape in indictor begins to flash. Any other suggestions?
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
FixYa! (100)
repairguy
Rank:Guru Guru
Rating: 91%, 204 votes
depending on th einternal design of the vcr. look for the loading/unloading mech, by finding the blak rubber belt that is looped from the motor to a pully. now turn it one way. it may thak 25 to 50 complete rotations of the belt. try turning both ways, one will load & 1 will unlaod.
good luck.
Comment by repairguy, posted on Jan 26, 2007
you could put a small dc voltage to the motor, typically 5 to 8volts. the motor should turn one way or the other. but this would not indicate if the motor control ic's in the unit are working.and sorry but i do not know why the indicators are flashing.
Was this solution helpful? Show your Appreciation by rating it:
Can you Help with these VCRs problems?
VCRs
vcr
I got a stuck tape out of my... Answer This...
VCRs
toshiba urc 4220 code
hi,, I have a toshiba tv with... Answer This...
VCRs
Record from Panasonic...
First VCRs are hard to come by... Answer This...
VCRs
VCR eating tapes when...
Everything works fine on my... Answer This...
VCRs
setting date on my JVC HR 636U...
I cannot change the DAY on my... Answer This...
Repair Service
Find VCR Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
