Question about HP Pavilion dv2000t 14.1" Notebook Laptop PC (Intel Core 2 Duo T5500 1.66 GHz, 1GB RAM, 100GB HDD, D... PC Notebook
I cannot see the full height of the screen, the bottom one inch of screen has some icons on a black strip that runs the whole width of the screen.
  • Sueflay Feb 13, 2009
    My daughters comp is only 5 months old. You can not see 3/4 of the screen. I dont know if someone put some sort of pressure on it to cause this problem or if it is a mechanical problem
  • James Vernon
    James Vernon May 11, 2010
    Can you send me a screenshot to ElectronicCarpenter@gmail.com
    Genius:
  • HP Master
  • 1,102 Answers
Try your screen settings from keyboard or
open control panel display then settings afetr you check settings rhen you can hit advance and check those settings
Posted on Jan 28, 2009
  • DEKR
    DEKR Feb 02, 2009
    please don't forget to rate me
There is a small black outline going around my whole video screen.
I had the same problem but I had and still get a red line at the bottom of the screen. Best thing to do it crop it out or just add Pictue in Picture Video effect then set it to full screen then set the width and height so it can crop out it self...hope this helps
Nov 09, 2012 | Pinnacle Dazzle DVD Recorder
Tip
How to reset nokia mobiles life timer to ''0''
Nokia life timer is a counter that keeps track of the Total call time of your phone. It will show how much the phone has been used, and it?s the best thing to check if you?re planning to buy a used Nokia Mobile.
To see the Total Call Time or the life timer counter, On the standby screen type the following code *#92702689# (Easy way to remember this is ? *#war0anty#). And it will pop up a message that shows the life timer in hours and minutes.
Here is a detailed procedure to make this life timer zero.
REQUIREMENTS:
The following files are required to reset the life timer:
  1. Nemesis service suite link: Download from Here
  2. lifetimer.pm file: Download Here
PROCEDURE:
1. Download and Extract the lifetimer.pm file, and Download Nemesis Service Suite.
2. Install Nemesis Service Suite on your Computer, It won?t take much time.(select the first option)
3. Install Nokia Cable Drivers (No need to install, if you have Nokia PC Suite already installed)
4. Connect The Phone in ?PC Suite? Mode to the PC
5. Open Nemesis Service Software
6. Click on ?Scan for new Device? Button on Top right Corner
7. It Will take a few seconds to scan, and it will load up the software interface after communicating with the Phone.
8. Click the ?Phone Info? Button.
9. On the Bottom, Select and open the ?Permanent Memory? Tab, which is next to the Fbus info.
10. Click the ?Write? button on Below right, and open the Extracted lifetimer.pm file on your PC.
11. After the lifetimer.pm file is opened , it will immediately start writing it to the Phone?s EEPROM Area.
12. The Procedure will end when the progress bar reaches 20%. This is normal , and on the bottom right side, it will display its done.
13. Unplug the Phone, and Restart it.
14. After boot up, Check the life timer .
Note: This method has been tested on following devices: Nokia 6630, 6670, 6680, 5500 sport, 5700XM, 6110 Navigator, 6120 Classic, N70, N72, N73,N76, E50, E51, E61i, E65, N80, N91, N95, N95 8GB, 5800XM Mobile devices. If you want to try it on other S60v3 or S60v5 mobiles, do it at your own risk.
Caution:
  • Power Failure During Writing will cause damage to the Phone, And there is a chance that it might brick the phone as well.
  • Loose, worn out Data Cables Might fail the Writing process, and there are chances of damage to the EEPROM area of the phone.
  • Do not attempt this with phones that are not included in the confirmed list.
By:- Mohammed Abdulhadi
on Jun 21, 2010 | Cell Phones
Hi. I have a LG LD 460. How can i view movie video using full screen of 42 inch from the USB. what i mean is what is the size of the video file in width x height which when run from usb will use...
Hi!
you can convert the video to one of this sizes (1920x1080 or 1280x720) and it must fit exactly to your screen.
If the video is not panoramic (16:9 or 16:10), you may have to crop it to fit on the given screen sizes.
Hope this helps.
Mar 05, 2011 | Video Cameras
======== Exception Information
install Microsoft Runtime SDK 6.0 or up version first then run and install again your program.
Aug 10, 2009 | Systran Business Translator 6.0 Euro Full...
Strips of 2 inch wide black and white, running top to bottom
Definately a damaged screen, no way to fix it for less than the cost of a replacement screen sorry.
Jun 16, 2009 | Philips 200P4 (Silver/White) 20.1 in. Flat...
Image on 'normal' setting isn't using full height of tv screen.
What you will need to do is grab your remote that came with the tv - click "Menu">select "Settings">go down to "Screen" and make sure that:
1. Wide Mode reads "Full"
2. Auto Wide reads "On"
3. Display Area reads "Full Pixel"
Hope that helps.
Apr 06, 2009 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
Aspect ratio
this is normal as you are looking at WIDE screen aspect ..
Mar 27, 2009 | Proscan 32LA30Q Television
ILo-26HD Tv
take your set to a tech you are having problem in your vertical output circuit.leaky filter or coupling capacitor,or defective B+ regulator transistor or IC .buffer transistor or IC,or supply resistor, they need to be replace.good luck
Mar 26, 2007 | iLO 2600 Television
HP Pavilion dv2000t 14.1" Notebook Laptop PC (Intel Core 2 Duo T5500 1.66 GHz, 1GB RAM, 100GB HDD, D... PC Notebook Logo
91 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
