Replaced spark plugs and wires,but still not getting fire from number 2 coil
SOURCE: 2.7 l misfire after changing plugs
From karjunkie:
If the plugs get wet, then you have a spark problem somewhere in the ignition system. Pull a spark plug and hold it against a ground while you turn the engine over. You need to see a fat blue spark. If not, check the distributor, spark plug wires and coils. An easy way to test for spark is with an inexpensive spark tester. This is a device that is readily available at most auto supply stores. If the plugs do not fire properly, check the spark plug wires for fraying or cracking. Next, you need to check the coil(s). If firing voltage is low (weak spark), measure the coil primary and secondary resistance with an ohmmeter. If it is out of specifications, replace the coil. Also, make sure the coil is receiving normal voltage from the PCM or ignition module. If it is low, check the charging system for anything that may be reducing alternator output (battery and alternator cable connections, ground connections and voltage output).
SOURCE: where is the body control module located on a 1997 town & country
It is located on the back side of the underdash fuse box (junction block). You remove the lower steering column cover and knee blocker reinforcement. Then remove two plugs from the bottom of the BCM.
Remove the bolts holding the junction block to dash panel mounting bracket. Remove the junction block from the bracket. Remove screws holding the BCM to the junction block. Slide the BCM downward to disengage guide studs on jb from channels on BCM mounting bracket
SOURCE: radiator fan relay,2001 chrysler town country
the relay is located in the power distribution box under the hood the relay will be a square black or gray cube just pull out and make sure you rerplace it with the same type relay. refer to your owners manual for any questions regarding the fuses and relays
SOURCE: spark plug firing order
Copy and paste this link into your browser. Firing order is 123456
http://autorepair.about.com/library/firing_orders/bl-fo-5203.htm
