Question about Hitachi RAS-09UH Air Conditioner
Faulty air con or does it need to be regased
Hi my aircon light keeps flashing off amd on and thats all it does it was fine untill i took it down from my shop and then 2 weeks later insatlled it in my house all the wiring is installed correctly could it be that the gas leaked all out when i took the pipes off
  • jobojeth May 11, 2010
    How do you pump the system down?
    Problem Solver:
  • 6 Answers
Before you disconnected you should have pumped the system down, keeping all of the gas in to the outdoor unit. when you reinstalled you needed to vac the pipework then open the outdoor unit valves to let the refrigerant through. if you had disconnected the pipework without doing this you would have lost the gas, so yes a recharge will be required. hope this helps.
Posted on Mar 04, 2007
I have a split-type aircon (brand: LG) with remote control.It has power and display when i put on batteries. but the aircon unit does not respond to the remote control. what do i do to fix this?...
Lift the front cover of the air con, on the right hand side there is a button or a hole which has a button inside which you can press which is for manual starting of the air con. If this works, then you will know the remote is faulty, if it still doesn't work, check that the isolator switch for the air con hasn't been turned off. There will be 9Or should be) a switch outside next to the air con outdoor unit to switch power on / off to the air con. If not, there should be switch inside the meter box at the front of the house. Make sure they are switched on.
Apr 06, 2016 | LG LSC121PMA Split System Air Conditioner
My 2005 Audi A4 engine have idling problem when aircon is on
Sounds like the compressor is failing or seized (for the air con). This would put extra pressure on the system. It could be another fault with the air con system like the solenoids not opening up to allow the flow of gas in the system.
Feb 01, 2013 | 2005 Audi A4
I get a gurgling sound coming from behind the dash
Does the sound stop after a minute or two? IF so, this is normal. When the a/c is working, there is high pressure on one side of the expansion valve, and low pressure on the other. When you turn the a/c off, the pressures equalize. That's the noise you are hearing.
Feb 21, 2010 | 2004 Subaru Legacy
Aircon regasing
There is a specification plate on the base of the unit. It will have the refrigerant type and quantity listed. The leak should be found and repaired before re-charging with refrigerant.
1993 model could be r-12,r-22 or r-134a.
Oct 13, 2009 | Coleman Heating & Cooling
Engine keep turning off
It could be a part called the Idle control Valve. It regulates the Idle speed and keeps it smooth. If it is choked up with carbon gum or the little motor inside it is faulty then it will not allow enough air too pass for smooth idle. When you put your air con on the engine is under more load because it has too turn the aircon pump so it will stall. Also you have a little device on aircon cars that raise the idle a little to compensate for the extra aircon load. If this is not working it could be that.
Jul 06, 2009 | 1996 Mercedes-Benz C-Class
Jaguar xk8 air con light flashes then turns off but air con is on
this is most often caused by a slightly low charge of refridgerent, as the engine heats the system the gas expands and the light goes out.
Apr 08, 2009 | 1999 Jaguar XK8
KELVINATOR AIR CON
More than likely it is the remote sensor in the indoor unit. Then again I presume that it is the correct remote control. Sometimes a remote for one aircon may not communicate with another aircon even if they are the same brand.
Jan 24, 2009 | Heating & Cooling
I have a 1995 S420 U.S model, I am the first and only owner. the car only has 20,000 original miles. no accident or even a dint or scratch on the car,maintained regularly. never had any problem . The...
Di he put a tracer dye,usualy green,in when he recharged the aircon?It will usualy show a leak pretty quick,You may have a pressure safety switch thats faulty,usualy screwed into the aircon pump on the high pressure side and if it senses a low pressure problem it shuts the air con down to protect itself.It will have two wires running to it and joining the two wires will reactivate the aircon.Not advisable to leave wired up in this way as the air con charge also lubricates the pump and running it dry will require pump replacement if left running too long.Cant help with air con specialist as im in australia Good luck
Dec 11, 2008 | Mercedes-Benz 420-Series Cars & Trucks
Fan not turning off
You say that the air con is not cold, i think the problem would be the aircon will need regasing, if the gas has escaped from the system, the temperature in the aircon system will always be warm so the fan will continue working attempting to cool it down. It will need checking for leaks, most companies that recharge the system check the whole system for leaks first before refilling the system. If its the engine cooling fan it could be the thermo switch that is faulty,the way to check that is when the engine is cold disconnect the wires from the switch and put an ohms meter across the swith it sould not give any reading, it will only show a reading when the engine reaches operating temparature. hope that helps. regards Richard
Nov 01, 2008 | 2000 Jeep Grand Cherokee
Hitachi RAS-09UH Air Conditioner Logo
122 people viewed this question
Top Hitachi Heating & Cooling Experts
D. E. Hev
rugby prop
Marvin
Marvin
Are you a Hitachi Heating and Cooling Expert? Answer questions, earn points and help others
