Hub's are strictly physical devices running at layer 1 of the OSI Moldel. I therefore agree with clydeww. There is nothing to reset that turning it off and on won't do.
It is written in it`s mannual you can find it in attached link Motorola MOTOTRBO XPR 7550 User Manual or here is the video tutorial as well which is not for the same model but could may helps you
It's possible to reset the DTXPRESS electronic drum kit to its factory default settings by performing a Factory Reset. Here's how you can do it:
Press and hold the [DRUM KIT] and [SAMPLE] buttons while turning on the power switch. The display will show "FACTORY RESET OK?" Press the [DRUM KIT] button to execute the factory reset. The display will show "INITIALIZING" while the reset is being performed. When the reset is complete, the display will show "COMPLETED". Note: Performing a factory reset will delete all user kits, samples, and other custom settings that you have made. Be sure to save any custom kits or settings that you want to keep before performing the reset.
There are two types of resets that you can perform on nabi - forced reboot and factory reset. In the unlikely event that your nabi becomes unresponsive, you can easily perform a forced reboot. A factory reset is recommended when slow performance persists or if you want to wipe out all of your personal data and settings from nabi. Forced Reboot: To perform a forced reboot, hold the Power Button down until nabi turns off. When nabi is off, press the Power Button to turn on nabi again. Factory Reset:Caution! A factory reset is a very serious process because it will SYSTEMATICALLY WIPE ALL USER DATA from nabi. A factory reset will return nabi to its original factory settings.To perform a factory reset from Mommy/Daddy Mode, tap All Apps > Settings > Backup & reset > Factory data reset > Reset tablet > Erase everything. Please note: We highly recommend backing up your nabi prior to performing a factory reset. You can back up your music, videos, photos and apps with nabi™ Sync.
Performing a factory reset erases all of your settings and account information and restores your 1 Press home to go to the Home screen.
2 Highlight settings , and then press select to display the Settings screen.
3 Highlight factory reset, and then press select .
4 To continue with the reset, select factory reset. To cancel the reset, select back.
5 When prompted, highlight yes to confirm that you want to reset your player, and then press select
Sorry, There is NO factory reset - IT'S A HUB
